1941 Ford Deluxe Coupe This very solid mild custom 41 was restored for the 1986 Street Rod Nationals and it has held up extremely well. The metal on this car is in extremely good condition. I purchased the car a few months ago and I have gone through the car in order to make it safer and more reliable. If you have any questions please give Stephen a call at 860-214-7413 24 Stud Flathead with Offenhauser Aluminum Heads Rebuilt Single 94 Carb 3 Speed Column Shift Mallory Dual Point Distributor Reversed Main Leaf Front and Back Tube Shock Conversion Front and Back New Pilot Bearing, Throw Out Bearing and Universal Joint New Shifter Bushings New Radiator Hoses New Radiator Cap Flushed and Pressure Checked Radiator Converted to 12 Volt System with Original Style Generator Optional Heater New Electric Fuel Pump, Fuel Pressure Regulator and Fuel Filter New Brake Shoes and Wheel Cylinders Front and Back Cleaned and Repacked Wheel Bearings with New Front Seals New Coker BF Goodrich Silvertown Wide White Bias Ply Tires on Original 15" Merc Steel Wheels New Baby Moon Hub Caps Original Style Fender Skirts (not pictured because they are getting paint matched) Amazing Naugahyde Interior with Color Matched Carpet Finished Trunk Area Spare Tire (not shown) NOS Front Passenger Fender Grill Just Installed Issues: The paint is looking tired and could use some touch up or respray The trunk lid is showing signs of having old lead body work bubbling back to the surface Only rust on the car is in the lower rear tool tray where a previous owner used some fiberglass Passenger side vent window is cracked A previous owner drilled a hole in the cowl for an antenna and I currently have a black plastic plug covering it up (see pictures)
