-41 Chevrolet pickup truck cab, chopped floor and custom tunnel -custom made 2"x3" 3/16" thick z frame 5" drop in front 15" in rear. -1974 SBC 350, rebuilt 4 bolt main, new bearings, rings, high flow oil pump, new voodoo camshaft and lifters, new pushrods, new rockers, edelbrock intake, Holley 600 carb,new edelbrock fuel pump, new fluid dampener, new hi flow summit water pump, new summit starter, new alternator -new accel ignition coil , accel distributor, new 8 circuit fuse box -professionally rebuilt turbo 350 transmission, hurst stall converter Stainless block headers and a set of sprint headers -new aluminum radiator and electric fan with temp relay -new speedway 41 ford complete new front axle, spring and perches -32 Ford original all steel grill -41 ford split wishbones -40's ford front juice brakes new wheel cylinders pads fresh cut rotors, needs assembled and new springs -92 mustang 8.8 rear end new axle seals bearings and 5 lug axles, 3.27 gears, all new rebuilt rear brake drums -stock mustang driveshaft with new joints and conversion yoke -Jeep Wrangler rear leafs with new bushings and shocks -new reversed corvair steering box, new speedway steering column and u joints steering is finished -All brake lines and fuel lines finished in rear needs master cylinder and front brake lines finished -transmission cooler lines are run but need hooked up to cooler in radiator -custom made 57" bed -have all cab interior trim pieces including front windshield and rear window frame and both door latch window regulators -original dash and an extra one in great condition -frame was ppg epoxy painted and black ppg painted -suspension parts were all painted ppg black -spun aluminum 11gallon fuel tank -extra set of sprint headers -set of front shocks and mounts -have state of Nebraska title that came with truck and original cab tag let me know if you need more pics or have any questions. Engine was test fired last summer must be towed. Body is in good shape for being over 70 years old, bed and grill scell need mounted,both cowls need patched, small rust hole near back window but frame does cover, roof is wavy will help load. Asking $5000
