36 ford 2-door flatback sedan. this appears to be an older hot rod--probably a late-60's or early 70's build that was "upgraded" in the early 90's. last inspected in 96. the PO started stripping the paint then got bored with it. there's a lot of "sculptural" bondo in this car. check out the fender flares and filled seams and I would replace the chassis. the original was grafted onto some sort of chevy sub-frame but it ain't pretty. the motor/trans and rear axle in the pic don't go with the car. just the rolling body. I plan to put a differnt rear end in it, but it really depends whether is sells before or after I make it to the pull-a-part.
ok--everything is worked out now and it is back on the market. there is no drivetrain in it currently (motor/trans/rear end). I also have another chassis and possies rear leaf springs that I could be convinced to sell with the car for an added fee.
back up. now has a 4 lug mustang rear sitting under the back now so it's mobil and ready for you to come get it.
had this sold and the buyer backed out on me so up to the top she goes. have a set of hood sides not, but no top. and an extra chassis available as well.
