1932 5 window unfinished project. BeBop's 5 window body, steel drip rails, functioning cowl vent, exposed hinges, exterior door handles, and truck handle, aluminium windshield surround. Hoosier Hoods Stock Hood. Brookville grill shell. Steel aftermarket gas tank. ASC rails, chassis engineering x-member(installed first) then fully boxed, model A style front cross member, self made flat rear cross member. Front suspension: Unknown brand dropped 32 heavy Style axle, mono spring, new speedway spindle kit, completely brand new rebuilt F2 self energizing brakes, So-cal steering arms, split bones. Steering: Rebuilt F100 box, speedway column. Rear End: 9" all new rebuilt 3rd member, locker set-up with a 3:55 gear, 31 spine Strange Axles(brand new) all bearing, everything to complete. Self made P&J style ladder bars and cross member. Posies 40 Ford style rear spring with their Super Slide Kit. Drive Train: 5.0 302(held good oil pressure and didn't smoke when pulled), World Class T5 with S10 tailhousing conversion.(trans. was spotless inside) 39 pedal assembly being modified to use a Fox Mustang shortened clutch cable. All brake line finished accept for rearend housing. Probably forgetting a ton of stuff but those are the basics. The body is built like a Tank.
