1929 Ford Tudor Sedan Project. This is an all steel body with the running boards ,front and rear fenders and splash aprons. There is no rust through. The front floor piece and the tranny hump are from Direct sheet metal. I have the 2 rear metal floor pieces from Howell sheet metal. The metal insert is already in the roof. Super Bell 4" Drop Front End with Disc Brakes. Ford 8" Rear End with Coil Overs. Pete and Jake Ladder Bars and Pan Hard Bar on Front and Rear. 350 Chevy Motor with 350 Transmission.. New 1932 Ford Tank with Bracket to Mount to Frame including Stainless Steel Spreader Bar. Speedway Brake Kit. Drive Shaft needs to be cut and balanced. As I get more done the higher the cost. Good title. Call George at 979-324-4454. NO TEXTS. Consider trade for 1951-52 ford pickup.
I am getting ready to start working on this car so if you are interested best speak now. The more I do the more it will cost. btt
