1929 ford model A closed cab pick up. frame up build with custom built boxed frame (original was not usable) original steel body, bed, fenders, running boards and aprons and grill. built 73 Chevy 350. camel hump heads, crane cam, erson roller rockers, edelbrock 1406, block hugger headers with dual exhaust and moroso mufflers. new hei, new starter, new fuel pump, new plugs & wires. alternator. dual electric fans on thermostat. th350 tranny w/ lokar shifter 9" ford rear end w/ coilovers. dropped front axle, short shocks, 4 bar, ford disc brakes on non boosted master. rear drum. dual saddle gas tanks on frame under splash aprons. new 15" vintique smoothie rims powdercoated red. with new beauty rings and caps. 4 brand new Firestone wide whitewalls bias ply. 7:50 rear and 5:50 front new black single stage paint (has some orange peel) pinstriped lines by carl abejon brand new cobra grain vinyl top with padding and hide em welt. new matching upholstered visor. new black pleated marine grade upholdstry on new panel boards. heat pad under new carpet. new seat frame and springs with flip up bench and tilt forward back. seat done by sagonas in Burbank with red and black vinyl tuck n rolled with all new burlap and foam. Rod factory 12v wire harness dynamated interior, floor, firewall, doors. spoon gas pedal. tilt gm column mooneyes red metalflake wheel fiberglass 32 dash with all working gauges. momentary key start in dash hidden gas tank toggle for switching tanks electric aoogah horn diamond plate steel bed painted black lots of new little pieces like tailgate chains and hooks, windshield hardware, taillight, top of door window channels, cowl & shell lacing, ign switch, rear view mirror, rear window glass, titled in CA with pink slip registered with original 1929 ca plates currently Insured and reg up to date. turn key running and driving hot rod $22,000 located in sunland/los angeles
probably gonna add some lake style headers and Smitty dual exhuast to it. may raise the price when it happens. so....bump! offers?
