I did an article for the first issue of Hot Rod Deluxe (1999?) covering tires, sizes, and styles. It was a neat little piece w...<P><P>To read the rest of this blog entry from The Jalopy Journal, click here.
The late model Vogue tire is a painted white wall. Gold stripe is also paint. Does anyone have any info on Vulcanized white walls ie. Process, Equipment. This would be the process of applying white to the side of a non whitewall tire. Would be using real white rubber, and heat and pressure to bond to tire. Thank You Cody
