Reply
Thread Tools Display Modes
Old 03-19-2006, 04:32 PM   #1
blown240
Senior Member
blown240's Avatar
Default 51 chevy Door Glass Installation
Does the door glass go in before the division bar and vent window, or does it go in last? and do you put the bottom channel on the glass while it is out, or once its in?
Thanks!
offline   Reply With Quote
Old 03-19-2006, 04:41 PM   #2
50chevy
50chevy's Avatar
Default Re: 51 chevy Door Glass Installation
Pretty sure the glass goes in last.
Check out the manual here for some step by step instructions:
http://chevy.tocmp.com/1949_53shop/01body/1_04.HTM
I would put the bottom channel on the glass first, will probably be easier that way.
Old 03-19-2006, 04:59 PM   #3
paulweldit
paulweldit's Avatar
Location: Hurst,Texas (west of Dallas & east of Ft.Worth)
Put the bottom channel on the glass first, then put the window in the door and hook up the window to the track system , then install the division bar and wing glass last.
__________________
Hot Rod Louvers
BAN LOW PERFOMANCE DRIVERS
NOT HIGH PERFORMANCE CARS
Old 01-11-2013, 02:19 AM   #4
shortcut76009
FNG
shortcut76009's Avatar
Quote:
Thanks!
Have you figured out the install? I'm having the same issue
Old 01-11-2013, 06:40 AM   #5
Dano382
FNG
Dano382's Avatar
I just did my driver door glass on my coupe. I dropped the glass into the bottom chanel first. Make sure to use adhesive or the glass might come out of lower channel after you put it all back together, happend to me.
Then put in your division bar/wing window in and adjust the lower channel adjustment screw to make sure it cycles up and down smooth without binding up.
I don't think you can get glass out or in with the division bar still in place.
Also left the glass holder on it's track because I installed new scrapers and it would pass thru with it attached to glass. Helps if you have another person to assist you.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
