Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 03-09-2006, 06:40 PM   #1
DIRTYT
Old School HAMBer
Default Delete
__________________
offline   Reply With Quote
Old 03-09-2006, 06:57 PM   #2
Hackerbilt
Old School HAMBer
Hackerbilt's Avatar
Default Re: TECH: Saab steering rack in a 50 chevy
Looks good...
Did you check it for excessive bumpsteer while the spring was out and you could lift up and down on the spindle?
(Those inner tierods are a hell of a lot further out than the original inners...)
__________________
Bill
Old 03-09-2006, 07:58 PM   #3
Hackerbilt
Old School HAMBer
Hackerbilt's Avatar
Quote:
Originally Posted by DIRTYT
the orig works off a bell crank and the inners are dead center. I drove the car last weekend and had it going 65 on the free way no problems zero bump steer. It works flawless.
Wellll....wouldn't be as noticeable on a smooth highway as on a choppy sideroad maybe, BUT the proof IS in the driving, and your driving it so I'm not gonna say your wrong!
I can't imagine you recommending it if you noticed any issues anyway.
Ford truck twin-I-beams have funky geometry and still drive fine due to the limited range of motion in the suspension and I suspect that helps here as well.
Looks like a very simple swap that can cure several ills those cars are known for...and makes the exhaust nightmare a non-issue too. If I were building a lowered early 50's Chevy without a subframe I'd certainly give that idea consideration.
Incredible that you didn't have to change the length of the inner tierods, the Saab outer tierods fit right up AND the bracket locations work out so well!!!
Just couldn't get a better layout for a swap into that chassis.
Excellent tech writeup too by the way!
__________________
Bill
Old 03-09-2006, 08:23 PM   #4
Rhino
Grenade Inspector
Very cool indeed!
This could help a lot of people!
Way to go.
Denny
__________________
Rhino
Old 03-09-2006, 09:44 PM   #5
chevysapper
FNG
Finaly a solution to my stering problems. Thank you.
Old 03-09-2006, 10:22 PM   #6
Hackerbilt
Old School HAMBer
Hackerbilt's Avatar
Haha...yeah, I guess Michigan would have the same basic issues our highways have!
Your right! ONE mile on a frost rutted highway will tell the tale! LoL
__________________
Bill
Old 03-09-2006, 10:27 PM   #7
a54Studebaker
Grenade Inspector
a54Studebaker's Avatar
I did a similar setup on my T-bird but I used a rack off a front wheel drive Buick Skylark because the center part of the rack moves and the outer part can be mounted securely to the frame, here is a link to see the tech article about it on the Y block site http://www.y-blocksforever.com/tech/html/rpinbird.html
notice the bracket that is mounted on the Fatman's kit on the 56 Fairlane(also shown here), This is something that I probably should have used/made to make sure my inner tie rod mounts were the same distance apart as they were on the original drag link - although I haven't noticed any bump steer with mine setup the way it is now. I have approximately 10,000 miles on the car since the install and tires are wearing great too.
Richard
Old 03-10-2006, 12:09 PM   #8
Hackerbilt
Old School HAMBer
Hackerbilt's Avatar
Richard
Thats a nice setup too...and closer to the stock pivot locations.
BTTT....
__________________
Bill
Old 04-13-2008, 10:29 PM   #9
franks52
FNG
Default Re: Delete
hey, do you have pics of this swap of the rack?
Old 04-13-2008, 10:32 PM   #10
franks52
FNG
Default Re: Delete
i have a 52 chevy hrdtp
Old 04-14-2008, 12:16 AM   #11
leaded
Grenade Inspector
leaded's Avatar
Thumbs up Re: TECH: Saab steering rack in a 50 chevy
Did a similar swap on my -50 Fleetline. I used an German built Calibra/Vectra rack, ( as the US. Cavalier..?) ,it has the connection of the steeringrods at the centermoving part, its even more similar to the original setup. Easy mount, even the steeringrods from the rack could be used. Only special was the need of fabricatng a connection between rods and rack, because of other angle of mount, so it could suit the angle as lower A-arm.
( similar as the part for sets from http://www.speeddirect.com/ )
Did a great change of driving habbit, and no bumpsteer.
Old 04-14-2008, 12:39 AM   #12
toddc
toddc's Avatar
Default Re: Delete
Quote:
Originally Posted by DIRTYT View Post
Where did the tech go?
Old 04-14-2008, 06:01 PM   #13
franks52
FNG
hey leaded any pics or tec info you could pass on
Old 04-14-2008, 06:09 PM   #14
rustynewyorker
Old School HAMBer
rustynewyorker's Avatar
Location: Upstate New York, watching my New Yorker Rust
Seems to me someone had copied the info and posted it as their own, so DirtyT removed it. But I could be wrong on that.
__________________
"That was a time when America was great.. when the chrome was thick and the women were straight" - Michael Savage
I have old cars for sale. PM me or check the classified.
Old 04-14-2008, 06:19 PM   #15
DIRTYT
Old School HAMBer
no i removed cause after i did it every one said it wouldnt work and would have to much bump steer... its a damn shame it worked perfect. so fuck em i didnt have a tech to figure it out. its not that hard and if you cant figure it out you really have no buisness changing something so important as your own steering any way right...
i used a 89 saab 9-2 manual rack.
__________________
Old 04-14-2008, 06:21 PM   #16
cretin
Alliance Member
cretin's Avatar
I've got a saab rack sitting in my garage. I've been lazy and haven't installed it. If and when I get around to it I'll post pics.
__________________
"There is no solution, we are the problem"
WANTED: Running/driving unrestored, stock Model A Roadster.
Rochester carb tech
Old 04-14-2008, 06:24 PM   #17
rustynewyorker
Old School HAMBer
Ahh. I remembered there was some sort of argument but not the details. I don't know why it wouldn't work as long as you can mount the thing so it's in about the same position relative to the tie-rod ends as it was in the Saab it came out of.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
