Reply
Thread Tools Display Modes
Old 02-13-2006, 12:02 PM   #1
thehazmatguy
Grenade Inspector
thehazmatguy's Avatar
Default 55 chevy radius wheel opening
This may be a rookie question.. I did try to do a search in the archieve before I asked. My appologies if this has been covered before.
How did the old school guys get that nice flare on a 55 chevy wheel opening when they did a radius job?
I see that in most pictures the wheel opening is simply cut and left alone, I don't think that looks so hot. The nicer jobs I have seen have a perfectly round opening with a simple flare that matches the flare of the front wheel opening. At first I thought they were using a panel from a 55 nomad, but the wheel opening on a nomad has the same overall shape of the front wheel opening.
( I know I might not be explaining this well. Basically, I want the opening round but with the same flare/lip shape as the front fender.)
So, how did they do it? Did they shape the opening by hand? Did they find a donor fender, then "cut and paste" the opening on the 55?? Or did they weld a rod to the edge of the opening and use lead to make the flare??
I really like the rear fender on this car, to the uneducated eye this fender looks stock:
http://members.aol.com/falfa55chevy/falfap1.html
__________________
offline   Reply With Quote
Old 02-13-2006, 12:07 PM   #2
Gotgas
Alliance Member
Gotgas's Avatar
Default Re: 55 chevy radius wheel opening
Here's a link.
http://www.jalopyjournal.com/forum/s...ad.php?t=57437
And yes, that AG '55 Chevy looks phenomenal...
__________________
Good hands. BAD taste in cars.
online   Reply With Quote
Old 02-13-2006, 12:10 PM   #3
porknbeaner
Alliance Member
porknbeaner's Avatar
2 ways that it happened in the back yard.
One way was to take a pair of pliers and work aroung the wheel opeing pulling it up and out, then smoothing tje work out afterward.
Another way was to bend a piece of brake or fuel line to the shape of the opening then tack it on and finish it with lead or bondo.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 02-13-2006, 12:27 PM   #4
thehazmatguy
Grenade Inspector
Quote:
Originally Posted by Gotgas
Here's a link.
Crap! I looked, I swear!!! :-)
Thanks. The string/sharpie makes perfect sense for the initial cut.
I was planning on cruising a junk yard looking for suitable donor fenders for the flare. The tip for using the VW fender makes perfect sense for a smooth look.
I'm not sure about the rod and fill method, that is the method my father suggested. It seems like you could have a lot of filler on there to make it look right, and then I would worry about long term durability.
__________________
Old 02-13-2006, 12:31 PM   #5
chopolds
Old School HAMBer
chopolds's Avatar
EASY......use 55 Nomad quarter panels!
__________________
Finished The Kart
Proud Member: Gold Chainers CC
Old 02-13-2006, 12:36 PM   #6
thehazmatguy
Grenade Inspector
Quote:
One way was to take a pair of pliers and work around the wheel opeing pulling it up and out, then smoothing tje work out afterward.
Something like the plier method was what I had in mind. Maybe rough out the shape by pulling the metal out, then tack weld a metal rod to the inside of the fender to give the edge a finished look?
__________________
Old 02-13-2006, 03:42 PM   #7
RodLand
Grenade Inspector
RodLand's Avatar
I used 66 mustang front fender flairs once. They were from a frontended reck, and when mustangs were a dime a dozen. You should still find something like this, late model, in a salvage yard. Probably fronts will be the best bet for large flairs.
__________________
I don't care how rich people do it!
My forgetter's getting better,
But my rememberer is broke.
Old 02-13-2006, 04:21 PM   #8
Old School HAMBer
squirrel's Avatar
Be carefull about using the wheel opening flare from another car....guys who know cars will be able to spot it a mile away.
__________________
Jim Forbes
my shtuff
Old 02-13-2006, 04:37 PM   #9
SamIyam
Old School HAMBer
SamIyam's Avatar
Quote:
Exactly! The '55 Nomad ones being the easiest to spot. The look ok on a street rodded '55... but if you're after something old looking, DIY.
Here's a pic of mine.
The original builder told me how they (him and a friend) did it.
He said they took a pencil and some string and laid it out on the quarter panel. Tie the string to the pencil, and hold the other end in the center of the axle... then, strike the arc.
Once laid out, they cut it out with aviation snips...
Then, to get the nice rolled edge towards the center... they took a body hammer and a dolly with a nice radius on it and hammered it over. He said it was easier than it sounds, and everyone always comments on the nice job they did (back in the 60's).
FWIW, in this picture, the rear end is not centered because they had moved it backwards on the spring for some reason. But when it is lowered down where it will be, and the rear end in the correct spot, it looks perfect.
To me, the rolled in lip looks the best... to do a lip on the outside... you either have to do a lot of welding, or use a lot of filler.
But the easiest was to do that is to bend some thin-wall 3/4" round tubing... some guys call in conduit, but when I think of conduit, I think of that galvanized crap at the hardware store... bad shit to weld... and find out how the finish will stick to it before you proceed...
But you can bend the shape, tack it in place (using the string method to get it right) and THEN cut the fender out... roll the edge around and finish welding. Fill the gap at the top with a metal filler piece or BONDO... I'd use metal.
Sam.
__________________
Check out my updates on Instagram... Under the name Strubillicious
Old 02-13-2006, 08:06 PM   #10
Doc.
Alliance Member
Doc.'s Avatar
The body guy who did my '55, made little pie cuts in the metal (in the proper radius) and then welded up the area between the cuts. He then did the metal work with a hammer and dolly. You can run your finger all the way around the lip and it is only 1 layer of metal thick. Turned out pretty good. The guys on the two lane blacktop board talk about useing some model of volvo front fenders. It's a pretty popular topic there, and I'm sure they could clue you in to the donor car they are useing.
Doc.
Old 02-14-2006, 10:20 AM   #11
John_Kelly
John_Kelly's Avatar
Simply pulling and bending with pliers will pull the quarter panel out of its original contour. To get that little reverse flare lip, you need more surface area...that is why pie cuts and adding extra metal is done...a better way is to stretch the existing metal to get more surface area. This takes practice. To stretch, first you need to thin the metal more at the edges, and less as you get more into the body. Tons of work, but if you want to try it on a scrap fender first, I'll help with advice.
John www.ghiaspecialties.com
Old 02-14-2006, 10:43 AM   #12
Steve
heres mine:
It was done by the prior owner and I'm not sure how they did it. I'm sure it was done with tubing and either a lot of filler or fiberglass.
Old 02-14-2006, 11:03 AM   #13
atch
Old School HAMBer
atch's Avatar
i always heard that buick wheelwells worked well when grafted in. anyone got a pic of one done that way?
__________________
atch (Mike Atchley)
MO hambers - join Missouri H.A.M.B.ers and check out this thread
Old 02-14-2006, 05:54 PM   #14
overspray
Alliance Member
overspray's Avatar
I took an old set of rusty front 55 fenders and cut out the radius and spliced it to the rear quarters. There was a little massaging to do to get the lip to line up at the rear. It turned out nice, kinda like using Nomad quarters but lots cheaper.
overspray
__________________
A professional painter DOES NOT get "RUNS"--They are called "FLOW CHECKS."
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
