Reply
Thread Tools Display Modes
Old 01-22-2006, 08:22 PM   #1
Kevin Lee
Super Moderator
Kevin Lee's Avatar
Default What does a burned exhaust valve look like?
I know you can read spark plugs. Wondering if there's a similar technique for valves?
Popped the heads on my flathead and noticed the exhaust valve in #1 looked grey. Basically a sort of "fogged" greyish white around the outside of the valve. I've heard before how the no. 1 cylinder sometimes runs lean and in turn gets hot, causes problems with soft header bolts, etc.
It doesn't really look like it's in bad shape - but definitiely looks different than the other fifteen.
__________________
Learning the hard way since '72
offline   Reply With Quote
Old 01-22-2006, 08:25 PM   #2
Old School HAMBer
squirrel's Avatar
Default Re: What does a burned exhaust valve look like?
A burned valve has a notch or flat spot at the face (the part that contacts the seat), so it does not contact the seat at the burned part.
__________________
Jim Forbes
my shtuff
Old 01-22-2006, 08:25 PM   #3
Tman
Old School HAMBer
Tman's Avatar
Any degradation or pitting of the seat area?
__________________
www.compulsionrodandcustom.com New website up! Product listings updating weekly!
Old 01-22-2006, 08:26 PM   #4
Old School HAMBer
squirrel's Avatar
heres one I found with google image search....
__________________
Jim Forbes
my shtuff
Old 01-22-2006, 08:31 PM   #5
Steve Ray
Steve Ray's Avatar
The valves in my Alfa Romeo motor actually turned black-they had a charred appearance and one was cracked with a chunk missing. Yeah they looked like the picture.
I did see a set of burnt flathead valves once-similar appearance and the edges were crumbled away. A burned valve will eventually lose big chunks so if you have any doubt replace it.
Old 01-22-2006, 09:07 PM   #6
Old School HAMBer
squirrel's Avatar
Sounds like no 1 is running properly, and the other 7 cylinders are running a tad rich.
Normally the exhaust valves will be white, grey, or tan, if the fuel mixture is right and the engine isn't burning a lot of oil.
__________________
Jim Forbes
my shtuff
Old 01-22-2006, 09:07 PM   #7
51 MERC-CT
Senior Member
51 MERC-CT's Avatar
Here's a really bad one out of a flathead.
Old 01-22-2006, 09:16 PM   #8
Kevin Lee
Super Moderator
Kevin Lee's Avatar
I can live with this explanation. The rest of the cylinders did have a pretty heavy carbon buildup. I'll try to get pictures later.
__________________
Old 01-23-2006, 11:54 AM   #9
Bruce Lancaster
Alliance Member
Also might just have lots of pitting on seat without any big area gone.
__________________
Bruce
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
