Reply
Thread Tools Display Modes
Old 11-10-2013, 12:30 PM   #1
Baumi
Alliance Member
Baumi's Avatar
Default Buick guys:401/425 Nailhead and Parts interchangeability questions
I īm planning to run a 425 nailhead in my future drag rod project. I already have a beautiful std bore 425 block and a good crank, but the rods and pistons were not with the engine. Some my question is, can I use 401 rods in a 425 block? The stroke is identical at 3.64" but I donīt know if the 425 has the same rod length and compression height as the 401?
I couldnīt think of a reason why it shouldnīt be identical, but I just canīt find anything about that.Iīm dreaming of running a blower with mechanical fuel injection on it. I think a little boost would really help with these small valves and intake/ exhaust runners. How strong is the bottom end on these engines? How much abuse can the nailhead rods take?
Are there other weak links?
Thanks for your help! Chris
__________________
Kronz`nīDungle Hi Performance Exhausts
offline   Reply With Quote
Old 11-10-2013, 12:34 PM   #2
BOBCRMAN
Default Re: Buick guys:401/425 Nailhead and Parts interchangeability questions
Rod length is the same. Block was raised for the longer stroke of the 425
Old 11-10-2013, 01:16 PM   #3
Baumi
Alliance Member
Baumi's Avatar
Thanks! So the 401-425 blocks are taller than the 364?
__________________
Old 11-12-2013, 01:11 PM   #4
CTFuzz
Old School HAMBer
CTFuzz's Avatar
Location: the smallest town in the smallest county in the smallest state
401/425 have the same stroke, blocks are the same for your purposes. Yes, deck hight is more on the 401/425 than the 364. I wouldn't worry about the bottom end of a Nailhead as long as the boost isn't crazy high.
Good luck with the project.
__________________
http://jalopytimes.blogspot.com/
Pictures of Great New England Cars
Old 11-14-2013, 04:01 AM   #5
Baumi
Alliance Member
Baumi's Avatar
Thanks for the good info! All I have left to do is collecting parts, hahaha
__________________
Old 11-14-2013, 08:09 AM   #6
models916
Grenade Inspector
you should be here
http://nailheadbuick.com/nailing-down
Old 11-15-2013, 07:12 PM   #7
hidez57
Alliance Member
hidez57's Avatar
Quote:
Originally Posted by models916 View Post
and here www.v8buick.com
Old 12-14-2013, 10:43 PM   #8
4284555sd
Newbie
Buick Rods and crank are steel with small mains. Strong lower end. Worry more about pistons. Getting the right piston is getting hard. They move the pins up to lower the comp. Egg is bad about this. You'll have to have some made. Try not to use cast.
Old 02-14-2014, 05:38 AM   #9
telriv
Newbie
I've spent close to 2 yrs. coming up with a universal FORGED piston for the 401/425 engines. It has finally come to a reality. $795.00 includes pins, locks, pin fitting & 1/16th. or 5/64ths. standard ring combos. Taking deposits now. Once I have ALL your specs. will be 5-8wks. Each set is custom made for each particular set-up. Can read MUCH more about this on v8buick.com search Tom Telesco
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
