Technical Guidelines: The Traditional Hot Rod Forum
Discussion in 'Traditional Hot Rods' started by Ryan, Aug 29, 2013.
  1. Ryan
    Ryan
    ADMINISTRATOR
    The Traditional Hot Rod forum is reserved for threads and posts pertaining to period correct hot rods only. Please use this forum for technical threads, build threads, historical threads, and feature threads only.
    We've set permissions so that you must chose a prefix for your thread. Those prefixes are limited to:
    1. Technical - This prefix is for tech threads and questions.
    2. Projects - Essentially, this prefix is reserved for build threads.
    3. Features - This is the prefix to use if you want to show off that super rare hot rod part or even a finished car.
    4. History - Reserved for threads focused on the history of traditional hot rods.
    For any other thread types (such as Event coverage, Art, etc...), please use the General Discussion forum located here.
    Note: If you would like to see all threads assigned to a particular prefix, just scroll down to the bottom of the forum to where is says "display options." Choose the prefix you want to limit the forum to and then click "show threads."
  2. Ryan
    Ryan
    ADMINISTRATOR
    To help sort of define what sorts of cars should be featured in this forum, I decided it might be beneficial to provide a definition of sorts. And rather than use words, I'll use pictures.
    This forum is dedicated to cars built in the vain of:
  3. Ryan
    Ryan
    ADMINISTRATOR
    And a few more:
  4. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
