Reply
Thread Tools Display Modes
Old 08-28-2013, 05:30 PM   #1
vetteson
FNG
Default plymouth 259 pistons in a 241 Dodge hemi
Will 259 Plymouth pistons clear the valves in an over-bored 241 Dodge hemi (using stock cam)? I see that the pistons in the 241 are notched.
offline   Reply With Quote
Old 08-28-2013, 05:51 PM   #2
snaptwo
Default Re: plymouth 259 pistons in a 241 Dodge hemi
I would think that the Mopower engineers put those eyebrows in for a reason don'cha think.
Old 08-28-2013, 05:57 PM   #3
TR Waters
Senior Member
The notches in a hemi piston are directly across from one another. The notches on a poly piston are offset from one another. With a bone stock cam, you should be able to get away with it. Other than that, I would consider massaging the notches to replicate the hemi piston. Keep in mind that in stock form, these are very low compression engines.
__________________
TR Waters Early Hemi Parts
Early Hemi to SB Mopar Trans Adapters
www.trwaters.com
Old 08-28-2013, 07:18 PM   #4
wbrw32
Old School HAMBer
wbrw32's Avatar
Pistons MUST match bore and stroke ..IF those are the same then the pistons will work..albiet the tops will look different..
online   Reply With Quote
Old 08-28-2013, 08:17 PM   #5
73RR
Old School HAMBer
73RR's Avatar
That is a pretty big cut...suggest that you sonic check the cyl walls as a first step.
As Tom suggests, if you use them, lengthen the eyebrow a bit. It sounds like a stock-sorta rebuild so balance should not be an issue.
In the FWIW department, for a couple hundred more dollars you could have some decent compression...
__________________
www.qualityengineeredcomponents.com
Early Hemi Parts, Pieces, Tech
Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series
http://www.discoverthenetworks.org/Articles/Hansen.pdf
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
