Go Back   THE H.A.M.B. > The H.A.M.B. Marketplace > Classifieds > Parts For Sale
Reply
Thread Tools Display Modes
Old 08-04-2013, 07:52 AM   #1
daredevilcustoms
Grenade Inspector
daredevilcustoms's Avatar
Default 1923-25 Steel Model T Ford Roadster SCTA, Dry Lakes project
1923-25 Steel Model T Ford Roadster SCTA, Dry Lakes project, Whippet Grille Shell, Franklin Front Axle and Steering
Included are most of the main components to rough in a Dry Lakes style roadster (engine and transmission not included). The body is a real steel 1923-25 Ford Roadster with turtle deck. It does appear that the left body panel may be from a low cowl hood model while the rest is the later high hood style. Look at the pictures carefully they best describe the condition. It is rough, but I've seen worse used. The front grille is the mandatory Whippet. Front axle is a tube Franklin. The steering is a Franklin converted to center steering. The frame is a late 20's Chevy three springer, the bottom of the front horns are thin but restorable. No front springs. Front cross member is a Model A ford. Rear axle is a Model A Ford with hydraulic backing plates (no drums). Also included is a rear cross member from a late Model T Ford. Rear spring is either a Model T or A, missing a number of leafs.
This will make a period looking car without the hassle if searching out all the right stuff.
Below is a Youtube link that walks around the car. Sold as is, if you have questions ask before you bid. No returns.
http://youtu.be/eyov-WUPzoU
Buyer must make all arrangements for shipping. I can box, and strap to a pallet if needed.
Would entertain trade for Model T & A speed equipment or a running Model A engine
Click image for larger version
ID:	1996053   Click image for larger version
ID:	1996054   Click image for larger version
ID:	1996057   Click image for larger version
offline   Reply With Quote
Old 10-09-2013, 06:47 PM   #2
daredevilcustoms
Grenade Inspector
Default Re: 1923-25 Steel Model T Ford Roadster SCTA, Dry Lakes project
Body and frame left @ $450
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
