Reply
Thread Tools Display Modes
Old 08-03-2013, 04:20 PM   #1
53GeeGee
FNG
Default Broke down - metal grinding after shifting to 3rd.
Any one have any thoughts on a 53 chevy grinding metal noise after switching into 3rd gear. Pulled off to the side of the road literally on the nm co border. Waiting on tow truck. Trying to brainstorm. I see no oil. No smoke at time of incidence. Coolent cap is still hot but he level was fine when we left about 15 miles back. filled gas tank just before colorado border. pulled out of parking lot and less than 2 miles, metal grinding noise. Any thoughts. sucks.
Click image for larger version
offline   Reply With Quote
Old 08-03-2013, 04:47 PM   #2
tfeverfred
Old School HAMBer
tfeverfred's Avatar
Default Re: Broke down - metal grinding after shifting to 3rd.
Bttt
__________________
My avatar is Candy Barr.
https://www.youtube.com/watch?v=HmhXdqajVaQ
Old 08-03-2013, 04:49 PM   #3
296ardun
Senior Member
296ardun's Avatar
Where does the noise come from? My first thought was transmission, if it happens after you shift into 3rd (assume it's a 3-speed). If the engine runs, drive it slowly and see where the noise seems to come from, if it is below, probably trans or drive shaft? Assume the trans and rear end have not leaked fluid?
__________________
Caution: We are the people your parents warned you about
Old 08-03-2013, 04:50 PM   #4
n.z.rodder
n.z.rodder's Avatar
Where's the grinding noises coming from, Gearbox/ clutch, diff, engine???
Scotty
__________________
Don't get on it if you can't stay in it!
Old 08-03-2013, 04:51 PM   #5
1964countrysedan
Alliance Member
1964countrysedan's Avatar
Need more information.
What does it do out of gear? Other gears?
__________________
My cars have metal ashtrays.
Old 08-03-2013, 04:52 PM   #6
flatford39
Senior Member
What was the free play like in your pedal?? More than an inch?? My guess is throw out bearing beat the dust. Could be a worn out pressure plate as well. Pretty easy fixes unless you still have the torque tube in it.
__________________
Looking for a decent 32 Ford V8 radiator. Let me know.
Old 08-03-2013, 07:39 PM   #7
F&J
Old School HAMBer
There was a tread on this with a 53 ? Chevy a few weeks ago. Same issue. Turned out it was the common failure on higher mileage cars, of the syncro hub falling apart.
Old 08-03-2013, 10:45 PM   #8
53GeeGee
FNG
Hi all,
Not sure really at this point. Just pushed it into the shop after finally getting over some depression. It shifts into and out of gear without problems. It's not running.
I tried to start it up while waiting on a tow. wouldnt start, but i am having to pour a little gas in the carb anyway to start. I'll try to start it up in the morning.
My guess is tha it may be engine related. Car has 66,000 mile on it but hasn't been driven in 30 years. Just got it going and had it tuned up before the Farmington car show. It was running great two weeks ago and I did a similar stretch of road on Thursday. There were some slight inclines in the road we were hitting as we climb elevation entering Colorado. Maybe I stressed something?
There was/is no signifocant free play on the pedal.
It was like I start getting momentum after leaving the gas station, switch in the 3rd (three on the tree standard) and then something popped and that's when the grinding started. Wasn't loud cause my wife didn't hear anything (but she wasn't paying attention either). I know that by the time I got off the road, I don't remember cutting the engine but it was not running when I stopped.
I'll see if I can't crank it up in the morning and then post an update,
Thanks for the input. I'm sure ill be posting future threads on the outcome shortly and seekin advise.
New to this.
Kevin
Old 08-03-2013, 11:39 PM   #9
Alliance Member
Mr48chev's Avatar
If you have to pour gas in the carb to start because the carb hasn't been rebuilt or the fuel pump is suspect I would imagine that there are a number of other things on the car that are rather suspect and the cause of the pop and grinding may be one of them.
Damaged clutch linkage or clutch pieces such as the forks or fingers on the clutch or the throwout bearing. Internal damage to to the trans. U joint? Something in the third member such as the pin holding the pin the spider run on allowing it to slip one way and catching the housing and breaking and causing a grinding. Had that happen on a 55 Buick.
We are all assuming that this car has a stock drivetrain. is that correct?
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 08-04-2013, 11:03 PM   #10
53GeeGee
FNG
Wont turn over this morning I suspect it is now engine related (?). Still, checked the coolant level and it was fine and oil looks clean and full. I need to get a buddy over to listen.
Its all stock. Standard three gear on the column. Ran great. Great grandma (GeeGee) took great care of it almost to the day she passed in the early 80's. Ive tried to think of everything before road testing it, knowing that I really need to go ahead and rebuild the engine, rebuild some more....
Guess I'll start troubleshooting all these items from everyone posting above and give an update.
Thanks for the suggestions.
Old 08-04-2013, 11:39 PM   #11
n.z.rodder
n.z.rodder's Avatar
Clutch/flywheel, something came loose (grinding) and has now locked the engine. Is there an inspection cover on the bellhousing? Pull it and check for fillings.
Scotty
__________________
Old 08-05-2013, 12:43 AM   #12
wheel28
FNG
wheel28's Avatar
Sure sounds like clutch or transmission. Put the trans in neutral and try to start it, not just push the clutch in. The motor turns over you know its the clutch locked up. If the motor is still locked jack up the rear and try to spin the driveshaft with the trans in neutral. If the drive shaft won't spin its in the trans.
Will
Old 08-06-2013, 09:40 PM   #13
53GeeGee
FNG
Great advise. Will try in the morning and post an update.really appreciate ya'lls time
Old 08-06-2013, 10:05 PM   #14
tjet
Alliance Member
tjet's Avatar
I have to agree - sounds like a clutch problem. I had a clutch fail like that. Another prob it may be is the harmonic balancer. I had one that the outer ring slipped and moved back. Grinded big time on the timing chain cover
Old 08-22-2013, 10:53 PM   #15
53GeeGee
FNG
Nothing new to report. Work got busy. Had to come back and look at tfeverfred's picture.
I have it on ramps now and will try to check out all suggestions first starting with bell housing.
Thanks
K.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
