#@%*August 2013 Banger Meet #$^&
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Aug 1, 2013.
  1. Crazydaddyo
    Crazydaddyo
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.billsbangers.com
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
  2. Crazydaddyo
    Crazydaddyo
  3. Checking in...
  4. BCCHOPIT
    BCCHOPIT
    Thanks DaddyO...
  5. ThrottleJockey
    ThrottleJockey
    I think I can hang out here now......:D
  6. Old-Soul
    Old-Soul
    I feel the mysterious powers of the banger calling my name again...
  7. Bluto
    Bluto
    Soon we return to the USA
    This weekend we'll see the 5-Main and HAL scans
    Then waxes and off to casting
  8. MATACONCEPTS
    MATACONCEPTS
    Im Bang'N Agian!!! After playing "Musical 4-Banger" with 3 motors got tiring, I jumped to the 28rpuV6 to start driving that, got it running but hit a roadblock with that, "Shit, I got to change the cam." Back to "Musical 4-Banger". I'm on Engine#3. Got it running Saturday after down for 4 weeks. I was riding my DYNO to work. After dicking with Enigine#1, putting it in & out cause it was more than just a Headgasket, I was so close to SBC'g the fucker. It's Running Now. . . So Far.
    Now Im back on the 4 others cars in my backyard I got to get running. I think I'm driving this Model A a little too hard.
  9. SJR
    SJR
    can we discuss heads? comp ratios, brands, alloy or Iron ?
  10. racer32
    racer32
    Banger newb here...picked up a 31 coupe. Trying to get it running.
  11. I'm with SJR....I need to know more than I do on Banger heads! Who's had what head, and what were the results and opinions?
  12. Bluto
    Bluto
    The best heads got two cams in em!
  13. been playing with a old head casting on the flowbench. much work to do as it really likes more than .600 lift on the goes-inta side (OHV)
  14. August already!!
  15. noboD
    noboD
    Which side of the Mississippi ?
  16. Brendan1959
    Brendan1959
      165.7 KB
  17. colinsmithson
    colinsmithson
    I am in looking forward to hearing more banger talk;)
    Colin
  18. Brendan1959
    Brendan1959
    Colin
    Did I see your A at Bonniedoon pub a couple of months back?
    I cant quite make it out from your avatar.
    Post a pic of your car.
    Brendan
  19. colinsmithson
    colinsmithson
    Hi Brendan yes I was at the Bonnie Pub good club run we went on to the grass driving event
    Good to see you hear :)
    Colin
  20. colinsmithson
    colinsmithson
    I have tried
    Stock A head=smooth nothing special
    Modified A head =as above
    Stock B head smooth may 10% more power
    Modified B head =as above maybe extra 2% power
    Winfield Cast Iron Red Head = Great power smooth runs cool
    Winfield Aluminium 8-1 Great power gasket need to be copper timing needs to be spot on runs hot
    Winfield Aluminium 6-1= good power can run a little warm
    Lion speed head mk 4= ok power runs cool
    Thomas head =Good power need relief back of valve runs cool very smooth
  21. Brendan1959
    Brendan1959
    Colin
    Give us a run down on your engine and drive train, I seem to recall an aluminium flywheel housing?
    Brendan
  22. youngsspeed
    youngsspeed
    bluto, what are you up to ? are you going to be selling HAL heads ? keep me tuned in
  23. Bluto
    Bluto
    We have no plans to make whole HAL conversions only the bare Model A HAL head castings and 5 main OHC blocks....... no sales planned sorry
    Remember we are doing this to fix my wife's car It's not a business
  24. Interesting! Didn't Ed Winfield say "Cast iron's for racin'; aluminum's for cookin'!"
  25. Crazydaddyo
    Crazydaddyo
    Here are some pictures of the different combustion chambers:
    Cyclone 8-1
    V V V V V V V
    Aluminum 7-1 Winfield
    V V V V V V V V V V V V
    Cast iron 7-1 Winfield
    Thomas 6-1 (aluminum)
    VVVVVVVVVVVVVVVVVVVV
    7.5-1 Weiand (the one I run now)
    VVVVVVVVVVVVVVVVVVVVVVVVVV
  26. Was the 7:1 Winfield flycut? I'm pretty sure they were originally flat over the pistons. That one looks identical to my 6:1 'Yellow Head'.
  27. Crazydaddyo
    Crazydaddyo
    Not originaly. I cut it to fit on my 30 tudor.
  28. colinsmithson
    colinsmithson
    Brendan the set up you saw was my old faithfull A model engine Used it to try out different ideas it has count crank, insert bearings, pressure mains, 34 flywheel,l olds pistons cam by clive 350x270, Chevy 305 valves, Thomas head relived and decked 0.125? cast headers MSD dissy 2 inch exhaust, single or twin 97 Stromberg depends on distance and drive style
    Drive train aluminium housing Mike Davidson adaptor 5 speed box open drive to 8 inch diff
    how about yours last I heard you setting up twin SUs what size and which needles jets did you finish and which set up (head cam ect ) do they match
    Colin
  29. RoddyB34
    RoddyB34
    Hi Colin ,,,did you do your engine yourself ?,was it locally machined ? i am going to try and do an A engine for my sons 28 coupe ,,would like machining to be done by someone who maybe has done one before,,,i am in Geelong so not far from you ,,,,Rod,,
  30. RussTee
    RussTee
    Thanks Dan plenty to think about there a good collection of examples. Heads are still being developed as we understand these motors better and apply modern tech to them .
    One example I like the look of is Pat Garys BHT8BALL on here. He has combined a design with some of his other products to produce more swirl in the combustion camber its a good example of a modern head moving these motors into the present day.
