Reply
Thread Tools Display Modes
Old 12-02-2005, 11:07 PM   #1
Barn-core
Barn-core's Avatar
Default Quick ques, 16" Ford wheels, years, and bolt patterns.
What years did Ford make a 16" solid steel, rim? (they did make them didn't they?) Also, what was the bolt pattern, and are they hard to come by. Thanks Barn-core.
__________________
Barn-core, contra mundum with a vengeance!
offline   Reply With Quote
Old 12-03-2005, 12:13 AM   #2
beatnik
Senior Member
beatnik's Avatar
Default Re: Quick ques, 16" Ford wheels, years, and bolt patterns.
Quote:
They started making the 40 Ford style wheel in 1940 5x5-1/2" bolt pattern. They all have 4 slots where the centers meet the hoops. As far as I know Ford never made what the aftermarket calls the Solid wheel.
16x5" and 16 x3-1/2" are the hardest to come by.
1940 V8-60HP =16x3-1/2" Steel
1940-1941 V8-85HP =16"x4" Steel
1942-1948=16x4-1/2" steel
1948-1953 P/U =16x4-1/2" and 15x5"
1954 P/U = 16x5
Ford parts book:
Format is Part number, Size, Year/Application
#91D 1015 - 16 x 5 - 3/4 ton truck 39-47
#11A 1015 - 16 x 4 - Pass 40-48, Commercial 40-42
#8C 1015 - 16 x4.5 - Commercial 1945-47
#022A1015 - 16x3-1/2 - 1940 60 HP Passenger
#19A 1015 - 16 x 5 - 1941 95HP Passenger
16x5 - 41 Mercury and P/U to 1956
Click image for larger version
Old 12-03-2005, 01:48 AM   #3
50Fraud
Old School HAMBer
50Fraud's Avatar
1954 P/U = 16x5
Ford parts book:
I believe you'll find that the 3/4 ton truck wheel (#91D 1015) is a wide 5 -- 5 x 10 3/4 bolt pattern, different centers than '36 - '39 passenger and quite rare. Wide 5 in 4" width is quite common, and has bottle-cap scallops around the center. 3 1/2" width was also made but is rather scarce.
16" wheels were also used on low-end '49 (perhaps later) passenger cars; bolt circle 4 x 4 3/4??
Old 12-03-2005, 06:33 AM   #4
Levis Classic
Old School HAMBer
Levis Classic's Avatar
"16" wheels were also used on low-end '49 (perhaps later) passenger cars; bolt circle 4 x 4 3/4??"
49 Ford shoebox - 4 1/2"
Old 12-03-2005, 10:17 AM   #5
286merc
Senior Member
The 16" was standard on the entry level Mainline thru 53; I junked a 52 a few years ago but kept the wheels.
Ford built military jeeps were also 16" well into the 50's; if I remember they had a different appearing hub but were the 5 1/2" pattern. A lot of those went to the surplus market and wound up on trailers. They may also have been the solid version mentioned.
Old 12-03-2005, 11:09 AM   #6
Barn-core
Barn-core's Avatar
Thanks for the info guys. When I said I was looking for a solid wheel I just meant not wires. Did Ford ever make any 17's? And how about the wires, how big did those come?
__________________
Old 07-07-2008, 01:15 AM   #7
alvisoroadsters
Grenade Inspector
if i recall, ford made the model a and prior wires, but kelsey hayes made a 17" ford pattern wire wheel, basically, what you end up seeing anymore for that traditional look.
__________________
viva alviso roadsters!
Old 07-07-2008, 01:18 AM   #8
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Read this:
http://www.jalopyjournal.com/forum/s...d.php?t=115542
__________________
Daddy always said, If yer gonna be dumb, ya gotta be tough! - And I'm one tough sumbitch!
T5 Tech
Old 07-07-2008, 03:27 AM   #9
50Fraud
Old School HAMBer
50Fraud's Avatar
According to Wheelkid in his 6/16/06 post, "Ford Steel Wheel Tech", early Lincolns did use clips -- unlike Ford and Merc wheels of the era. I believe him.
Old 07-07-2008, 06:07 AM   #10
dutch deuce
dutch deuce's Avatar
Ford 17 inch wire wheels were used in 1933 and 1934 (5 x 5,5)
Ford Europe also used 17 inch wires on there Model Y that was made
from 1932 to 1937, these wheels look like Model A wheels and also
are 5 x 5,5
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
