Features Best sounding engines ?
Discussion in 'The Hokey Ass Message Board' started by OldColt, Jun 6, 2013.
  1. OldColt
    OldColt
    With all the threads on the Hamb, this may have been done before. Here's mine Most Musical are small block V8's wound up around 10K. Most entertaining sounding are the old nitro cacklers. Most impressive sounding are modern top fuel or funny car engines, and special mention goes to the raspy growling sound from the big Ford FE engines. I'm sure yall have many more favorites than these. --- Steve ---
  2. Maybe because it was the hot engine back in my early days but I always liked the sound of a Chevy 283 with a Duntov cam at idle.
  3. hoop98
    hoop98
    from Texas
    352 - 360 horse, Honda 305
  4. 117harv
    117harv
  5. F-6Garagerat
    F-6Garagerat
    Flatheads and Y-blocks with hot cams. The flathead in the Joe Nitti roadster is one of my favorites.
  6. Speedwrench
    Speedwrench
    A Novi at the end of the front chute at Indy.
  7. groundpounder
    groundpounder
    There's nothing like a Hemi Cackler!!!.......
  8. teddyp
    teddyp
    yes a y-block with glass packs for a true 50,s sound
  9. xix32
    xix32
    not automotive: but the Pratt & whitney R-985 radial ( 985 cubic inches) 450 H.P. at about only 1,700 R.P.M. with it's 9 cylinders barking away propelling a Beech Staggerwing quickly through the air as it makes a low pass over my rural location, where the airspace above me can still legally be utilized in such a way. Is a true artform for both the sight and sound of it.
  10. Rickybop
    Rickybop
    I was at a mudbogger meet years ago. I know, I know...but some of those guys run bad-ass engines. Anyway, this one unlimited entry sounded sooooooooo tough! I asked him what the engine was...I thought for sure he'd say a bigblock something. Nope...289 Ford!!!???
  11. oldiron73
    oldiron73
    from WISCONSIN
    Any Flathead V8.......
  12. kracker36
    kracker36
    2 of my favorite sounding engines have been 289's. One is a Super Stock 65 Mustang, and the other in a mud drag truck. Both not HAMB friendly, but the 289 is.
  13. samurai mike
    samurai mike
    eight in a row go man go!
  14. Dreddybear
    Dreddybear
    I thought I knew what a good flathead sounded like until I heard the Khougaz roadster at idle. It's pure sex.
  15. RichFox
    RichFox
  16. Cruiser
    Cruiser
    A Chevy 250 with Smitty's the rapping has always been a sweet sound to me. A Chevy 283 with the Smitty's sounds great too. :D
    CRUISER :cool:
  17. shawnspeed
    shawnspeed
    from Attica Mi
  18. That's easy....a cast iron '92 with a Keith Hampton on top and 90% inside....
  19. hoop98
    hoop98
    from Texas
    BTW, what we perceive as differences in a 283, 289, or a 279 is a function of the different cams, header diameters, compression ratios, and when revving in neutral rotating weight, each one tended to have.
    They all Fire LRRLRLLR, just depends on where you start the sequence. As a matter of fact a 289 and a 283 fire identically, just how they number the cylinders,
    Put the same cam (EVO at same piston position, same opening velocity), 10 - 1 compression and 1.625 headers they would sound near identical.
    Oops, unless its a Corvette, Thunderbird, or Cobra engine, that's different
  20. belair
    belair
  21. Perrorojo
    Perrorojo
    Kawasaki KZ 900 with the 4 into 1 exhaust and any built inline 6.
  22. hoop98
    hoop98
    from Texas
    Maybe the sound that was commonplace at certain peaks of a lifetime, like Dyno Don's Cammer at 10 Grand on the line, imagine those cam chains!!! Or a flat crank Hemi from S&M
  23. indyjps
    indyjps
    You Beat me to it, KZ 900 at rpm has a sound all its own, friend of mine had one stroked to 1375 with very high compression, amazing sounding
  24. CyaNide
    CyaNide
    from Texas
    Flathead 8 and sbf.
    CN
  25. kracker36
    kracker36
  26. winduptoy
    winduptoy
    A two six-bits Cummins under load at 1600RPM into a straight pipe.
  27. hoop98
    hoop98
    from Texas
    Stuffed and puffed 6v-92 !
  28. Sidewinder777
    Sidewinder777
    from Dayton,Nv
    I've always loved the sound of a 302 with a nice lopey idle and good glasspacks
  29. Adam Bahm
    Adam Bahm
    That Ford GAA tank engine. It's two thirds of a 60 degree vee twelve aircraft engine and has a unique sound. I can spend hours on U tube just for the vibes.
