*** June 2013 BANGER MEET ***
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Jun 1, 2013.
  1. Crazydaddyo
    Crazydaddyo
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.billsbangers.com
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculatorfin.jsp
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
  2. Crazydaddyo
    Crazydaddyo
    I getting ready for this tomorrow:
  3. Sweet! Looking forward to a full report!!
  4. Crazydaddyo
    Crazydaddyo
    Here is a picture from a couple of years ago. Can't wait to see how the engine does!!!!!
  5. Bluto
    Bluto
    OK I'm awake!:D
  6. RussTee
    RussTee
    Good luck Dan keep us up with the play and how the engine performs.
  7. BCCHOPIT
    BCCHOPIT
    Go get them....
  8. noboD
    noboD
    How's the snow situation?
  9. Crazy
    Thanks for the clickable link.
  10. Wow June already!
  11. I'm in, unloading camera card for pics tomorrow in Irwindale.
    J
  12. Is it tomorrow yet?
    We want pics :D
  13. Crazydaddyo
    Crazydaddyo
    The tech inspection line
  14. chopo
    chopo
    mallory distributor question. i got one for my a. my old dist. has a one piece shaft. will the stock 2 piece drive from an a engine work with the mallory dist?
  15. Crazydaddyo
    Crazydaddyo
    Fastest time so far 10.158 @ 68 MPH 1/8 the mile.
  16. Well done! Need more pics!!!
  17. skryla
    skryla
    from Brick, NJ
    subscribed
  18. Phred
    Phred
    from IL
    I'm fiddling with a Demon 98 carb on my Model A banger.
    Does the Demon 98 side bowl gaskets interchange with Holley gaskets?
    If so, which Holley carb gasket?
    Thanks in advance
  19. Crazydaddyo
    Crazydaddyo
    My quickest pass of the day. 10.146 @ 67.17 mph.
    Sorry, I was too busy to take pictures.
  20. Outstanding! Thanks for taking us on the ride!! No purer sound than a flathead 4 with a healthy cam - just the way the Good Lord intended.
  21. The '27 in the left lane was a "B" motor also with a little help (turbo). Mancias?
    I was looking for CDO in the pits but never found him.
    John
  22. Great ride video
  23. well im back on the banger team
    31 vicky
    plans are pretty simple
    drop the front with 33 axle perches spindles and reversed eye spring
    drop the rear with a t spring and a few leafs removed
    engine is getting a cam head intake header and ignition
    and she got new shoes today too
    tk
  24. Thanks for the ride CDO, I had planned on running my car. Ordered a new crank in February Got a refund of my deposit last week along with apologies but that don't make the car run!
    What Is that cam you have in your engine? Like the sound!
    Looking for shop that can straighten my old crank It mags good now but might not after straightening. Could be ground 020 to centers and be straight and clean but who grinds to centers anymore? #4 seems to be off and I think it is in the web, sound familiar? We put it on V blocks and it showed .008 off at center main so put it on the press and bent it back to .0015 - but checked next AM and it was out .0035 at center. So thats when I put it between centers
  25. Crazydaddyo
    Crazydaddyo
    Yes, that was the Mancillas modified. Flathead B with a turbo.
    Thanks.
    Were you trying to buy a Scat crank? Was it something other then standard stroke?
    The cam is a Brierley M-28 T.
    I'm really happy with the cam!!!!!!!!!
    Thanks Jim.
  26. Were you trying to buy a Scat crank? Was it something other then standard stroke?
    Yes and yes
  27. Crazydaddyo
    Crazydaddyo
    Why couldn't they deliver?
  28. Crazydaddyo
    Crazydaddyo
    I found a good video of the Antique Nats here:
  29. Time for some cheater slicks!
  30. Crazydaddyo
    Crazydaddyo
    Then wheelie bars. :rolleyes:;):D
