Go Back   THE H.A.M.B. > The H.A.M.B. Marketplace > Classifieds > Cars For Sale
Reply
Thread Tools Display Modes
Old 05-31-2013, 12:04 PM   #1
Blofeld
FNG
Default 1927 Model T Tudor Hot Rod / 2 door Sedan
FOR SALE
1927 Ford Model T - Tudor -(2 door sedan)
AWESOME LOOKING HOT ROD. GETS PHOTOGRAPHED EVERYWHERE SHE GOES. RUNS AND DRIVES GREAT. HATE TO GET RID OF HER, BUT I NEED THE ROOM. I'VE DRIVEN HER ALL OVER LONG ISLAND AND BEYOND THESE LAST THREE YEARS & HAD A TON OF FUN. ANY QUESTIONS FEEL FREE TO CALL. LOTS OF EXTRAS INCLUDED. SURFBOARD IN PIC NOT INCLUDED. I HAVE ANOTHER ONE THAT WILL GIVE YOU.
JOE (516)-647-8787 cell. Call Anytime.
1927 ALL STEEL TUDOR BODY CHOPPED 4"/ CHANNELED 6"(little bit of rot in rear corners. Nothing a few small patch panels can't handle. It's on my list of things to do.)
CUSTOM CONDUIT SPIDERWEB ON ROOF FOR GREAT LOOK & SUPPORT
2"x3" CUSTOM MADE STEEL TUBE FRAME
400ci SMALL BLOCK CHEVY, MILD CAM, HOLLEY 650 4 BARRELL CARB
CUSTOM HEADERS, (additional set of tall polished aluminum zoomies included)
REBUILT TURBO 350 TRANS W/ BRAND NEW REAR SEAL
BRAND NEW REINFORCED TRANNY CROSSMEMBER WITH RUBBER MOUNT
FORD 9" REAREND
BRAND NEW DRIVE SHAFT
40'S STYLE STEEL WHEELS
BRAND NEW HUB CAP'S & BULLET STYLE LUG NUTS(set of 4 of both included to change back & forth)
BRAND NEW COKER WHITEWALL RADIAL TIRES UP FRONT
ALMOST NEW BFG SILVERTON WW TIRES ON REAR
NEW CARRERA REAR COIL-OVER SHOCKS
NEW FRONT SPRING
NEW RADIUS RODS FRONT AND BACK
BRAND NEW RUBBER MOTOR MOUNTS
NEW STARTER
BRAND NEW ELECTRIC FUEL PUMP
NEW WATER PUMP
BRAND NEW GEL BATTERY
BRAND NEW GAS PEDAL AND CABLE
BRAND NEW BRAKE LINES, HOSES & CORRECT MASTER CYLINDER
BRAND NEW RESIDUAL VALVES & PROPORTIONING VALVE
NEW B&M CABLEMATIC SHIFTER
NEW OIL & WATER GUAGES
NEW ALUMINUM RADIATOR WITH TRANS COOLER
1929 MODEL A HEADLAMPS WITH HALOGEN CONVERSION KITS
NEW 1959 CADDY REAR TAIL LIGHTS
NEW 8 GALLON POLY GAS TANK WITH BRAND NEW CUSTOM MADE VENTED ALUMINUM GAS CAP
PROFILE MANUAL STEERING GEAR BOX MOUNTED UNDER DASH W/ NEW PITMAN ARM OUTSIDE
ALL BRACKETS NEW FROM SPEEDWAY MOTORS
CUSTOM STEREO SET-UP WITH A ALPINE AMP WIRED WITH AN 1/8" CONNECTION FOR IPOD OR PHONE & OUTDOOR STEREO SPEAKERS.
BRAND NEW HIGH QUALITY HIGH DENSITY FOAM SEATS 3" THICK
BRAND NEW CUSTOM MATERIAL ON SEATS.
BRAND NEW HIGH QUALITY ALUMINUM VALVE COVERS & AIR CLEANER
CUSTOM COPPER SURF RACK ON TOP WHICH DETACHES FROM ROOF SO YOU NEVER KNEW IT WAS THERE.
FRESH PLUGS, WIRES, OIL & TRANNY FLUID.
Click image for larger version
ID:	1947393   Click image for larger version
ID:	1947394   Click image for larger version
ID:	1947396   Click image for larger version
ID:	1947397   Click image for larger version
offline   Reply With Quote
Old 06-03-2013, 09:15 AM   #2
Blofeld
FNG
Default
Bump
Old 06-09-2013, 10:39 AM   #3
Blofeld
FNG
Default SOLD!!! 1927 Model T Tudor Hot Rod SOLD!!!
SOLD!!! Thanks Joe. Take Good Care of her.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
