Reply
Thread Tools Display Modes
Old 05-25-2013, 09:07 PM   #1
chevymike
Grenade Inspector
chevymike's Avatar
Default Anyone Use A Threaded Insert In Block for Head Bolt
Hi all, I want to get a little advice from others who might have done this. My Chevy 250 inline 6 had a threaded insert in the driver rear head bolt location. It was not a heli-coil but a steel insert. I pulled the head for some work and found it was sticking out some. Needless to say, it would not torque up to specs. I was able to remove it. The hole in the block is at 5/8" (head bolt is 1/2").
I was recommended to use E-Z Loc insert which requires a 3/4-10 threaded hole for the insert to be used for a 1/2" thread.
So the question is, has anyone had any good luck with using any inserts for a head bolt location? If so, what did you use?
__________________
Hot Rod Haulers
1965 Chevy C10 Panel
1964 Chevy II Wagon
1968 Chevy C10
offline   Reply With Quote
Old 05-25-2013, 09:44 PM   #2
in2hotrodz
Newbie
Default Re: Anyone Use A Threaded Insert In Block for Head Bolt
We use Time-Sert products at the shop I work at and have zero issues. When installed correctly and using the correct torque for the bolt size the repair should be as good as new.
Old 05-25-2013, 10:07 PM   #3
Fogger
Senior Member
Fogger's Avatar
x2 on Time-Serts, I've been using them for over 30 years. Never had a problem!
Old 05-25-2013, 10:10 PM   #4
SAM123
Senior Member
SAM123's Avatar
heli- coil works for me
__________________
Generic response to any and all spelling Nazis, "Talk to my hand!"
Old 05-25-2013, 10:12 PM   #5
63comet
63comet's Avatar
I have a heli-coil in my block right now. It torqued up fine. Maybe whoever installed the insert in yours did something wrong?
Old 05-25-2013, 10:13 PM   #6
porknbeaner
Alliance Member
porknbeaner's Avatar
Keen serts wuill work if you have enough meat to drill and tap or you could just thread the other one back in with some red locktite and let it set up.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 05-25-2013, 10:16 PM   #7
spiderdeville
Senior Member
spiderdeville's Avatar
time cert is a GM approved [demanded/required] repair on the fantastic Northstar Aluminum V8
Old 05-26-2013, 01:12 AM   #8
cully33
Alliance Member
cully33's Avatar
Caterpillar also make good threaded inserts.
__________________
Not driving your ride so as to keep the miles off it, is like not having sex with your girlfriend so that the next boyfriend will appreciate it more.
Old 05-26-2013, 01:36 AM   #9
Citizen caine
Newbie
Citizen caine's Avatar
Many types of thread inserts.
Just make sure you buy one for your application.
Old 05-26-2013, 10:24 AM   #10
1971BB427
Old School HAMBer
1971BB427's Avatar
Just went through this last week when a stud pulled out the threads on my BBC while torqing the heads. I got a helicoil kit and put it in. Torqued right down to 80 ft. lbs. after install, and no problems.
online   Reply With Quote
Old 05-26-2013, 10:32 AM   #11
63comet
63comet's Avatar
I have a question to add to this... I'm going to do a head swap soon. What re the odds of that Heli-Coil giving me troubles during that?
Old 05-26-2013, 10:52 AM   #12
chevymike
Grenade Inspector
chevymike's Avatar
Thanks for all the suggestions everyone. They pointed me to a lot of different types I had not heard of. Here's what my research is finding...
Helicoil won't work as the original hole had been "fixed" with a steel insert that pulled out of the block. There is not enough to tap for the size Helicoil.
Time-sert had the same issue with size BUT they also make Big-sert which is basically the same but larger external diameter specifically for fixing holes that other inserts have pulled out of.
E-Z Loc have a large diameter insert so in this case it would work for fixing an already fixed hole.
Keen-sert (aka Caterpiller) are similar to E-Z Loc but also have 4 "locks" that help hold the insert into the hole.
Full-Torque seem to be the top ones on the market as the design actually helps hold the tighter the torque of the internal bolt. This is the only one that will allow a hole with a crack (actually helps pull the crack closed) or even partial hole exposure. Downside is $$$.
Many options...
__________________
Hot Rod Haulers
1964 Chevy II Wagon
1968 Chevy C10
Old 05-26-2013, 11:24 AM   #13
rld14
Senior Member
rld14's Avatar
I used to work on OT cars where the head studs would strip out of the block.
I used time serts and never had a problem.
__________________
Good running 292 Y-Block needed!
Old 05-26-2013, 11:35 AM   #14
noboD
Old School HAMBer
ChevyMike, as you noted you are already beyond useing either heli-coils or Timeserts which both use an STI thread. I've used KeenSerts many times in both aluminum and cast iron with good results. McMaster-Carr sells them.Good luck.
__________________
Hot snot, NOW we're back in business!! Doc Hudson
Old 05-26-2013, 12:08 PM   #15
Wolfcreek-Steve
Senior Member
Wolfcreek-Steve's Avatar
I would look into why yours failed a second time!
I haven't had the need to do thread repair for a long time and don't remember brand names, but at one job I had we inserted threaded holes in injection molding machine tables. The initial threaded hole in the table would pull out in a few months of operation, but after inserting them they lasted for years. I've seen them fail from repeated use (wear) but never a "pull-out" IIRC we got them from McMaster-Carr.
Old 05-26-2013, 12:40 PM   #16
Jethro
Alliance Member
Jethro's Avatar
Chevy 250's have a problem with the four corner head bolt holes cracking . Sometimes the crack goes to the cylinder sometimes to the outside of the block. Check for cracks before you spend the time on a repair.
Old 05-26-2013, 01:26 PM   #17
TR Waters
Senior Member
Quote:
Especially the front bolts cracking to the waterpump.
__________________
TR Waters Early Hemi Parts
Early Hemi to SB Mopar Trans Adapters
www.trwaters.com
Old 05-26-2013, 05:52 PM   #18
chevymike
Grenade Inspector
chevymike's Avatar
No cracks in the block or head (had checked).
I think it was an issue with the original install of the rebuild company. When I pulled the head, it was already partly pulled out and looks like the top of the insert was "flattened" like it was pulled up when they torqued the head originally. I looks like a bad install to me.
I am going to talk to the machine shop on Tuesday and see what they use.
My only issue with doing it myself is getting it squared to the block.
__________________
Hot Rod Haulers
1964 Chevy II Wagon
1968 Chevy C10
Old 05-26-2013, 08:55 PM   #19
chevymike
Grenade Inspector
chevymike's Avatar
Figured I would post a couple pics of what's going on.
This was ground flush before I started the torque sequence and this was at 75 ft/lbs.
The insert that I removed
__________________
Hot Rod Haulers
1964 Chevy II Wagon
1968 Chevy C10
Old 05-26-2013, 09:49 PM   #20
97
I have a 400 smallblock that I used to run in a race car 25 years ago. It pulled a head stud , which like yours had been repaired before I got it, the resultant hole was too big for the available inserts back then.....and in New Zealand 400 blocks were hard to find and real expensive .
So I made my own insert from a piece of cast iron bar. Turned it to a suitable size, bored it and , then turned a fine thread on the outside. Drilled and tapped the block and screwed it in with 680 Loctite . Then using a block of hardwood for a guide I tapped the insert to correct thread.
For the guide I just faced the block of wood and bored a hole in it then ran the tap in while it was still on the lathe. Once I had it located on the block,the tap ran straight into the hole....probably wouldn't be any good for multiple uses, but it worked fine for the one I needed.
The repair worked fine , reused the block in the racecar and when it was retired from there , it did about 50000 kms in the tow truck, before I converted it to diesel.
It is still sitting there on the shelf waiting for another day..
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
