Reply
Thread Tools Display Modes
Old 05-06-2013, 11:39 PM   #1
e-tek
e-tek's Avatar
Default Heat Shrinking Metal
A lot of times - when you are welding-in patches, or repairing damaged panels, you'll often have to deal with a stretched area in the metal that needs to brought back in line with the rest of the panel. Heat shrinking is a method of putting heat into a high spot, then using the hammer and dolly to work the area, thus "shrinking" that area back down. It's one of those "tricks of the trade" that is rarely talked about, but is critical to being able to get the panel straight enough to finish properly.
The attached video may help you understand the process better. It was taken by my 8 year old son, so I'll apologize in advance for the quality, but we had fun doing it. The key to shrinking is to use a neutral flame, heat a dime-sized spot to a dull red, then fairly quickly, with a dolly in behind, tapping the area just around and on the heat-point. This hammering, along with the cooling action, will pull the metal molecules tighter together, thus shrinking the metal.
When I was first taught this method - in the 70's - we used a wet rag to "quench" the area. This method has now fallen out of favor, due to the quenching causing the metal to become brittle and work-hardened. The heating, then hammering, does everything you need it to, so don't bother quenching it with water.
The other key point I'd make is to assess after your second or third shrink. Like anything, too much of a good thing can go bad. Too much shrinking will either over-flatten the area, or cause it to bow inward, when what you want is to just remove a bulge, leaving a smooth transition to the surrounding areas.
So take a peak at the vid and if you have any questions, fire away and I - or someone else - will help clarify the process.
Heat shrinking proud metal
offline   Reply With Quote
Old 05-06-2013, 11:54 PM   #2
rld14
Senior Member
rld14's Avatar
Default Re: Heat Shrinking Metal
Great video, thanks for posting that! Heck, even I can understand it
__________________
Good running 292 Y-Block needed!
Old 05-07-2013, 12:40 AM   #3
prewarcars4me
Old School HAMBer
prewarcars4me's Avatar
Thanks for posting that.
__________________
Some of you guys are so tight with your money, I bet you can stretch a penny to wire your car.
Old 05-07-2013, 05:49 AM   #4
chopolds
Old School HAMBer
chopolds's Avatar
Good idea, but the theory is wrong.
When you weld metal, you shrink it....there is no difference in apply heat to weld a panel, as it is to apply heat to shrink a spot.
When you weld a seam, you need to STRETCH it to get it back in alignment. You can work the weld hot, to flatten the seam, but as the panel cools, you begin to stretch it, if working hammer on dolly.
You can also do this cold, if you like, but you won't flatten the seam as easily, but it can be done. I prefer doing it cold, as you usually have more control, as it happens more slowly.
Good idea, and good work, but if you understand the theory better, you would have more options, as in cold stretching. This doesn't work as well with MIG welding, but it is fine with gas or TIG.
__________________
Finished The Kart
Proud Member: Gold Chainers CC
Old 05-07-2013, 07:55 AM   #5
ago
Senior Member
ago's Avatar
Good video,
I get my better half to hold the torch.
Ago
Old 05-07-2013, 08:02 AM   #6
Texas Webb
Alliance Member
Your son did a good job.
Old 05-07-2013, 08:58 AM   #7
larry k
Alliance Member
we all know that when you put heat into metal it gets bigger,and when it cools it gets smaller,well it gets 5 to 7 times smaller ,and it
also shrinks the same amount if it is cooled fast or let cool slow, the hammer and dolly are used just to align the metal..
Old 05-07-2013, 06:26 PM   #8
RMR&C
Senior Member
RMR&C's Avatar
Sheet metal can get stretched by collision damage and/ or some moron pounding out a dent with a ball peen hammer then finishing on-dolly.....
You end up with a big football in the panel. Shrinking is required, either by shrinking disc or the torch method shown. I've had to do it many times.
Nice video, and good to see you are getting the kid involved!
__________________
it's kinda like watching paint dry
Old 05-07-2013, 08:34 PM   #9
falconsprint63
Senior Member
falconsprint63's Avatar
I've had some good success using the little spot heat fixture on the stud gun to do this too. nice tech post.
Old 05-07-2013, 10:21 PM   #10
e-tek
e-tek's Avatar
Quote:
I've seen that method used too - looks like a good way to keep the heat where you want it. Thanks.
Old 05-07-2013, 10:38 PM   #11
George G
Senior Member
George G's Avatar
You don't quench it with water?
Old 05-07-2013, 10:42 PM   #12
Babyearl
Alliance Member
Babyearl's Avatar
That works for me,, finally something I can understand,, Thanks
Old 05-07-2013, 10:47 PM   #13
e-tek
e-tek's Avatar
I think my first sentence was just a little confusing (I fixed it). What I meant was that when you are repairing and/or cutting/welding in patches you can end up with stretched areas that need to be shrunk. The weld itself will cause a shrink area, but sometimes the patch itself may need a shrink or the areas around it. Regardless, the tech was how to shrink metal.
Quote:
We USED to quench it, but now we know that quenching causes metal to get brittle, making it hard to work. You get the same "shrinkage" without water anyway, so no need to.
My son will be thrilled to see the great feedback - cheers gents.
Old 05-08-2013, 09:31 AM   #14
castirondude
Alliance Member
castirondude's Avatar
Default
I had my driveshaft redone by a guy a long time ago and he insisted working it till the spin balancer read dead zero. Initially he would weld on washers, followed by extra little tacks. When he was really close he would hit the shaft with a torch and quench it with a wet rag, so probably a little less dramatic than pouring water on. Worked beautifully.
I really like the idea of doing little "tech articles"
Sent from my Verizon 4G LTE smartphone
Old 05-08-2013, 10:17 AM   #15
JYPSEA
Grenade Inspector
JYPSEA's Avatar
Good article. Your not left handed are you? Good job anyway. I can use that this afternoon. Thanks
__________________
ALZHEIMERS took my wife at 55. Join your local memory walk.
Life is to short to buy cheap beer.
Old 05-08-2013, 10:18 AM   #16
oldrelics
Senior Member
oldrelics's Avatar
Stud gun with shrinking tip, no water, very controllable. Trust me, I fix ALOT of my mistakes this way
Old 05-08-2013, 10:20 AM   #17
lht
Grenade Inspector
lht's Avatar
great you teachin your son, put them to work keeps em out of trouble
Old 05-08-2013, 10:25 AM   #18
bct
Senior Member
bct's Avatar
compressed air cools it nice .....enough to feel the results right after
__________________
a time to weld , a time to grind.
Old 05-08-2013, 10:27 AM   #19
bct
Senior Member
bct's Avatar
nice vid btw.
the guy that showed me used the edge of the hammer and left "donkey tracks" .....when he hit with the air nozzle you could see the metal pucker.
__________________
Old 05-08-2013, 02:01 PM   #20
OLDTGUY
Newbie
Thanks for the video, your son did a great job.
JJ
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
