Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
Has anyone used a small sandblasting unit, like the ones at Harbor Freight? I removed the from clip from my car, and want to clean up the entire area. They seem pretty cheap ($60-$199).
Thanks |
#2 | |
Senior Member
If you mean the pressurised pots, yup, and they work good. I do it in a corner of brick walls on a concrete slab. Once I'm empty, I sweep up, filter through a screen and on my way again.
Quote:
#3 |
Alliance Member
Be careful reusing media, you may be embedding oxidization into your panels.
__________________
Road Devils - Texas RDFL |
#5 |
Grenade Inspector
I have bought 2 of them one pressure pot type and one that just sucks from a hopper. the pressure pot or tank one will not work with play sand not even when i use bigger tips. so its useless to me the other one wtih the hopper and tube works some times with the sand. guess if i pay the big bucks for some media blast shit the pot will work. but if you plan on using play sand it sucks.
#6 | |
Guest
Posts: n/a
If you already have an air compressor, etc. Lots of dust, therefore outside is best. Media isn't cheap, Playsand is okay if you keep the pressure down, otherwise one shot turns it to dust. You can re-use industrial grade grit, sift the turds out, but it costs more. If you expect to use a lot over the next couple of years, have a 1/2 ton bag delivered. Front clip, figure two days. Mine is in the corner gathering dust, use it for real small jobs, I take fenders to the industrial blaster, about $40 per on the average.
Quote:
#7 |
Grenade Inspector
I used one to blast my entire A-sedan. I worked well with Silica Sand (Very Fine Sand) and I recycled it multiple times by vacumming and sifting. Make sure you use protection though ie charcol respirator. The whole process made a huge mess in my garage but it worked.
Make sure you have a big air compressor, they like a lot of cfm... In hindsight I should have taken the body to the local media blasters. They are surprising cheap.
__________________
To every good project, a little blood must be donated. |
#8 | |
Alliance Member
Location: Pinellas County - the skin tag on the underside of America's wang, Florida
Quote:
#9 |
Grenade Inspector
i bought a cheap one from harbor frieght and some glass media, it worked great. the glass took the paint off and left the metal smooth as a baby's ass.
#10 |
Grenade Inspector
Thanks for the feedback, my first step looks like I need to get a bigger compressor.
#11 | |
Quote:
__________________
#12 | |
Senior Member
Quote:
Mine did'nt work well at first either. I've used the play sand from Home Depot and it clogged alot. I have found if I sift it through a peice of screen first that helped alot. I was also getting moisture from my line that would cause it to clog. I bought one of the disposible in line filters at Harbor Freight for a couple of bucks and put it on the end of the hose right before the tank and everthing works great now.
__________________
"THEM" It's more than just a big ant movie |
#13 |
I have a 40 gallon pressure pot from Harbour Freight and found a few things from using it everyday. Like said before, make sure the air coming in is very dry.I replaced the dryer that came with it with a better brand. The first one broke in one week anyway. I use number 4 grit silica sand which is labeled as blasting sand on the package. It comes in 80 pound sacks and is as cheap as the smaller Home Depot play sand. The business I buy it from is a masonry supply company. Replace the ball valves as just about all of the ones on mine have fallen apart. I use the largest nozzle that came in the package, but i adjust the bottom pot valve down as not ot waste too much sand. This keeps the pressure up and cleans just as well. Also down the road you might want to get a dead man valve, I can't stand fumbling with the cut off when wearing heavy gloves. By the way Tractor Supply carries a brand called Clarke that might be a little more but already comes with a dead man.
Sandblasting is the worst part of the job, but all that clean metal sure is sexy. |
#14 |
Grenade Inspector
I bout a 40 lber fron Harbor Freight, and it works great!!! I used to to blast my entire 34 Plymouth Coupe, and frame!!!!!! I actually ended up replacing the baster nozle with a clarke unit and modified the bottom valve cause it sucks ass. it would clog and give me all sorts of problems so I enarged it and took out the check valve so when its on...ITS ON. Also use an after market air dryer as recomended, by others. The stock one stucks...as usual. STOCK usually sucks.
I used 80lb bags of sand from Home Depot however I found a nice screen off an old window and sifted the sand twice to remove all the bigger media which would clog and be overly abrasive. I also bought bagged play sand and aluminum oxide from ACE hardware. The paysand from ace was too wet, so I dried it out on some 4x8 tarps and emptied another into a drywall style bucket in the shed to help it dry out. The Home Deopt sand works the best. You may have to sift it but its definately dryer. I found the cheapest and dryest way was the Home Depot sand mixed with aluminum oxide. WORKS WONDERS. THE Car turned out great!!! Screw taking it to a blasting company. Its about the same after all is said and done. Besides you did it yourself. What can be more satisfying???? Blood, Sweat and Dust!!. LOL!!! ~Rusty
| Thread Tools | |
| Display Modes | |
