Reply
Thread Tools Display Modes
Old 03-30-2013, 05:01 PM   #1
1twisted1
Grenade Inspector
1twisted1's Avatar
Default 63 fairlane build **Camshft 1-3 build starting on pg 4**
So i have read just about every post online regarding this issue and I still do not know if i should use this camshaft in my build. build info.
289 .040 over
289 heads with 1.84,1.54 valves 53cc
10.05:1 CR
C90X intake
Autolite 4100 1.12
Tri Y headers
Motors going in a 63 fairlane with 10T 4speeed with 3.50 gears. Possibly going to 3.80,4.11 if needed.
The cam in question is the c7fe-6250-a Lemans cam. I have a TRW\Speed Pro version of it already.
Can I get some real world advise from guys who have run this cam and why they Loved it or hated it.
Car will be a Friday Night\weekend warrior car. Might drive it to work once and a while.
Thanks in advance
Click image for larger version
offline   Reply With Quote
Old 03-30-2013, 05:12 PM   #2
FityFive
Grenade Inspector
FityFive's Avatar
Default Re: Sbf 289 Camshaft Question
I would like to see what the "experts" say as well.
Old 03-30-2013, 05:18 PM   #3
mustang6147
Senior Member
mustang6147's Avatar
Which 351 W valves did you use ? How big is the chambers?
Old 03-30-2013, 05:41 PM   #4
Deuces
Old School HAMBer
He said 53cc's......
__________________
***** God Bless the U.S. *****
Old 03-30-2013, 06:42 PM   #5
hoop98
Alliance Member
hoop98's Avatar
Not a very good choice in my opinion, 3500 - 7200 RPM cam very rough idle, 430 gear or more.
Something like this would make more sense, similar lift, better lobe, much less duration.
Old 03-30-2013, 07:56 PM   #6
saltflats
Senior Member
saltflats's Avatar
I would go with the one you have looks good and should have that classic sound.
Old 03-30-2013, 08:06 PM   #7
1twisted1
Grenade Inspector
1twisted1's Avatar
Valve size and headers added.. Have contacted Comp Cams and worked out a custom grid Solid lifter also.
Specs are
110 Lobe Sep
Dur@50 230 IN 236EX
valve lift .522in .536ex
But already have the above stated cam(in OP) and have heard so many conflicting story's regarding the Le-mans cam.
Hoop98 Is the 282S a modern version of the HIPO cam
Old 03-30-2013, 08:07 PM   #8
Don's Hot Rods
Old School HAMBer
Don's Hot Rods's Avatar
If the car is going to be a weekend warrior, I would go deeper than 3.50's in the rear. 4.11-4.30 would be my choice (and was in my 27). It let's the engine get into it's power band like immediately.
Don
online   Reply With Quote
Old 03-30-2013, 08:12 PM   #9
hoop98
Alliance Member
hoop98's Avatar
Quote:
Specs are
110 Lobe Sep
Dur@50 230 IN 236EX
No that's the C30ZS.
Old 03-30-2013, 08:32 PM   #10
1twisted1
Grenade Inspector
1twisted1's Avatar
Don the car has 3.50 in the rear stock! so that s what I'm working with already. Maybe I will have to do the T5 swap after all and run a set of 4.30's would make the car i little more useable.
Old 03-30-2013, 10:17 PM   #11
derbydad276
Senior Member
derbydad276's Avatar
why would you want a solid cam on the street ???
go hydraulic set it and forget it
I would use the comp cams xe268h with upgraded springs
and roller rockers
600 cfm holley or edelbrock carb
with a performer rpm intake or F4B intake
engine will make great power from about 1500 rpm to 5800 rpm
4.10 gears and hang on!
__________________
your kids can have their own race car...
www.aasbd.org
Old 03-30-2013, 11:02 PM   #12
Fuzzy Knight
Senior Member
Fuzzy Knight's Avatar
That cam is designed for a light car. 2000 lbs or less and a rev limit of around 8500. It will be a bitch on the street to keep cleaned out. It is also designed for lots of CFM. Fords 2x4 set that was used on that cam was 2 - 600 holleys.
__________________
1928 Lowboy,
1953 Ford Club Coupe,
1963 Fairlane 500 SportsCoupe,
1963 1/2 Falcon Ranchero, Original factory V8 - 4 speed, Factory Tri Power.
If it's Bitchin it don't have to be Perfect !!!
Old 03-30-2013, 11:27 PM   #13
Nailhead Jeff
Grenade Inspector
Nailhead Jeff's Avatar
Good friend of mine drove a 67 Mustang coupe daily with a 302 and a Lemans cam. ( About 7-8 miles to work and back, it was his only car at the time, we were 19) I built the engine for him Torker 1, 650 Holley, 3.55 gears 2400 stall in the C4. Heads were ported 289 w/ 1.94x1.60 valves. Car ran 13.10's on street tires 12.70's with a 100hp plate shot. Run that cam you will love it.
Old 03-31-2013, 01:15 AM   #14
HemiDeuce
Alliance Member
HemiDeuce's Avatar
I've used the Ford Muscle Parts C90Z-6250-C, hydraulic version of the 271 HP solid lifter cam, and it works great.
__________________
How to set-up a Winters V8 Quick Change.
http://www.jalopyjournal.com/forum/s...d.php?t=225131
Old 03-31-2013, 01:21 AM   #15
marknkimberlys29
Alliance Member
marknkimberlys29's Avatar
Its been years since I played with sbf, but mine always ran good with split lift/dur, favoring the exhaust as they are very weak on the ex...
Old 03-31-2013, 01:49 AM   #16
Deuces
Old School HAMBer
Cool Re: Sbf 289 Camshaft Question
Quote:
Or maybe a setup like this one......
__________________
Old 03-31-2013, 01:54 AM   #17
Deuces
Old School HAMBer
Question Re: Sbf 289 Camshaft Question
Is the Lemans cam same as the "GT-40" version???.....
__________________
Old 03-31-2013, 07:20 AM   #18
1twisted1
Grenade Inspector
1twisted1's Avatar
Hey Deuces looking to sell that tri power?? your not downriver are you??
Old 03-31-2013, 07:37 AM   #19
Deuces
Old School HAMBer
Not mine, sorry!..
I took a picture of it at an all Ford swap meet at the Ford World HQ in Dearborn....
__________________
Old 03-31-2013, 08:32 AM   #20
1twisted1
Grenade Inspector
1twisted1's Avatar
Guess I should have put this in the first post also, Heads have been opened up to 2.10 x 1.28 on the intake side and 1.60x1.20 on the exhaust, bowl blended with screw in studs and roller rockers. Pistons a forged flat tops, rods are are C3AE's that have been shot peened and magnefluxed fitting with ARP bolts and the whole assembly has been balanced. Along with the fact that i will be running a 24" or 26" tire which will put me in the 3000rpm range all day with the t10 in third at 45 to 50mph
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
