Reply
Thread Tools Display Modes
Old 11-11-2005, 11:22 PM   #1
bigrig
FNG
Default driveshaft knock on lowered biscayne
last week i replaced the center support for the driveshaft because it had completely ripped off it's base(i found this out only after i pulled the driveshaft off the car) it was making a really HARD knock at low speed when i was slowing down just before i was stopped or when i would leave from i complete stop, worked fine for about a week but i hear the noise coming back not as loud or as hard but it is coming back. the car is lowered alot, do you think that i changed the driveline angle so much that it keeps ripping that center support off?
should i try a shorter driveshaft?
anyone with a x frame chevy had this problem?
it's a 64 biscayne with a 230 inline 6
offline   Reply With Quote
Old 11-11-2005, 11:49 PM   #2
bigrig
FNG
Default Re: driveshaft knock on lowered biscayne
here's a pic
Old 11-11-2005, 11:49 PM   #3
DrJ
Old School HAMBer
DrJ's Avatar
Pontiac put a slip joint in the second/rear shaft so the movement of the rear end wouldn't push the bearing out of the rubber bushing. Chevy was too cheap and just hoped it would stay together till it was out of warranty (3 months).
Most driveline updates for those '58-'64 X frame Chevys include cutting and turning one of the front yokes 90 so they are in phase and adding a slip joint to the rear shaft.
(I got this done on my '60 with new U joints for under $300.
I don't have it done and on the road yet though, so I can't tell you how it works.)
Also, when lowering the car sometimes the center support needs to be shimmed up, or the trans tailshaft eeds to be shimmed up or the pinion angle needs to change to keep it all in phase.
There is a "black magic" service manual formula for all the included angles on cars that are stock height, but they start out with "make sure car is stock height" and if the car is always carrying a heavy load (lowered) it's an adjust and road test till the vibration goes away black magic trick.
The pinion angle is adjusted by shimming that single upper control arm at the frame. If the rear bushings are shot, start by replacing them because the rear end is twisting all over the place if they are worn and letting the rear end move.
If they had CV joints instead of U joints, none of this would be a problem....
__________________
Not my fault, I was at camp.
Old 11-11-2005, 11:51 PM   #4
bigrig
FNG
another look
Old 11-12-2005, 06:15 AM   #5
KING CHASSIS
Senior Member
KING CHASSIS's Avatar
By lowering the car you have shortened the distance between the carrier brgn. and the rear end. When you are jacking up the car and putting it on jack stands, put them under the rear axle. This way the springs are loaded like it is sitting on the ground. Take the shaft out and measure under the car from the center of the rear carrier brgn. mount hole and the center of the u-joint on the rear end. And compare the difference with your driveshaft on the ground. I think that you will find that the rear shaft needs shortened a little. Also some one sells a carrier brg for those cars with poly "cushion" in stead of the rubber that is easily torn out. I worked in a driveshaft shop for 13 years and i have fixed this problem a "few" times. As to who makes the poly one that has slipped my mind i have been out of that business for about 4 years. But you could probably check in JEGS or with PST (they have them full page ads usualy on the back cover of car mags and they sell poly suspension stuff). Hope this helps
online   Reply With Quote
Old 11-12-2005, 06:18 AM   #6
KING CHASSIS
Senior Member
By the way bitchin ride.
Old 11-12-2005, 06:34 AM   #7
epinut
Your Biscayne looks really clean. I'll squint my eye's & imagine a set of astros or chrome reversed with bias plys...
Old 11-12-2005, 11:29 AM   #8
bigrig
FNG
thanks for all the help, i found what i need (i think).
here's a link if anyone else has this problem.
www.dicksdriveshaft.com/partsdeptlowriders.htm
Old 11-12-2005, 11:54 AM   #9
Randy D
Grenade Inspector
Randy D's Avatar
in addition to the mentioned solutions above, you might check to be sure you didn't spit out a snap ring allowing the U joint to move side to side with the cup out of place. Not likely the problem, but it was on a 60 impala i worked on earlier this summer. Nice car, BTW.
__________________
Go 'til panic, then back off.
Emperors
Old 11-12-2005, 11:56 AM   #10
mazdaslam
Old School HAMBer
mazdaslam's Avatar
Nice car! You could also slot the bolt holes in the frame for the bearing mount.Slot them towards the front of the car.Then you can slide the whole shaft assembly foreward to make up for the rear being lowered.I did this on my old 64 Impala after ripping up a few bearings.I never had another problem after that.
__________________
Andy Dunn, Hot Rodder, 14. R.I.P
"MONSTERFLAKE"Kicks ASS!!!
50 Merc.....ON THE ROAD!!!
40 Merc,NEXT!Thanks Clark !!
Old 11-12-2005, 04:56 PM   #11
b29chevy
Guest
Posts: n/a
I screwed that up, didn't finish the thought, I'll try again; Rise-'er up 'til the driveshaft don't knock, it'll look better with a little rake anyhow.
Quote:
Originally Posted by b29chevy
Rise-'er up 'til the driveshaft don't knock.
Old 11-12-2005, 10:37 PM   #12
bigrig
FNG
it's got a pretty good rake right now
i'll post my results after the install-hopefully this will solve all the driveline problems i've been having,nothing like having a car you love driving and hating it for all the misery it brings you at the same time........
Old 11-13-2005, 12:54 AM   #13
Brandy
Old School HAMBer
Brandy's Avatar
Lowering your X frame Late Great even slightly will throw the entire shiteroo out of whack. My 58 Biscuit is only lowered 3 inches and it ticks that bearing off something TERRIBLE.
Easy fix for that is to take it to a driveline shop and have a slip yoke installed. That will allow the shaft to travel without eating the bearing. Something else that will allow you to maintain your bearing a lil longer is to install it properly, ie. have the car up off the ground all the way round and level. Also if you like, fill the holes in the bearing rubber with black urethane. It gives the rubber a little more substance. In the meantime if you feel like spending the money, buy a poly bearing from Inland Empire Driveline. They also sell a one piece driveshaft if you are feeling creative and cut the X center out and install new members.
xxx
Brandy
http://www.iedls.com/
__________________
Let the douchebaggery begin............oh wait, it already has.
Old 11-13-2005, 01:01 AM   #14
Kev Nemo
Old School HAMBer
Kev Nemo's Avatar
Yeah-me, too, except I have a lowered '62 Imp. Found out about the drive shaft at the Day of The Drags when the Christmas tree guy went 'Goddamn, something is bouncing pretty fierce in the rear of your car!'. No more runs after that
I'm getting it fixed soon-maybe I'll get some pix????
Oh yeah-sweet car, by the way
__________________
Destroyed by Design since 2009: http://www.fallingapartart.com/
Old 11-13-2005, 09:56 PM   #15
Eagletucky
Eagletucky's Avatar
Keep the updates coming. I've got the same problem. Will probably go with the poly driveline/ driveshaft. Unless they want a fourtune for it.
We'll see.
Timmy
Old 11-13-2005, 11:56 PM   #16
bigrig
FNG
will do, should get it around wednesday or thursday.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
