Reply
Thread Tools Display Modes
Old 11-11-2005, 01:38 PM   #1
chopper daddy
Grenade Inspector
chopper daddy's Avatar
Default Unsticking a seized engine, tips?
My 49 Chrysler flat 6 recently locked up. I am still in the process of checking it over, and I plan on pulling the oil pan for a look next.
Here's my question, I read threads here before that mentioned using everything fro Diesel to Coke. My neighbor said he had heard that tomato juice works.
What do you think? I pulled the head off 2 weeks ago, and squirted some thin machine oil on the pistons, and all but 1 drained. Then I poured 10w40 and the same thing happened, but took longer. It's probably that one or maybe 2 that are sticking. Think I can free them up with one of these concoctions before I have to pull pistons out?
__________________
If it won't work, get a bigger hammer....
offline   Reply With Quote
Old 11-11-2005, 02:02 PM   #2
Paul
Editor
Paul's Avatar
Default Re: Unsticking a seized engine, tips?
"recently locked up", like it was running and stopped?
I would disassemble first, the cause will show intself
Old 11-11-2005, 02:03 PM   #3
hell_fish_65
Senior Member
hell_fish_65's Avatar
http://www.jalopyjournal.com/forum/s...ad.php?t=77566
__________________
Dustin C
Too Many projects, too little time(and cash and space and......)
Thunderbolts
Old 11-11-2005, 02:17 PM   #4
53sled
Old School HAMBer
53sled's Avatar
things to consider, when did it seize, running or rusting? either way, experience (my uncle is an old chrysler tech) says a hone job and knurled pistons will get it back going, but if you want to run it long term, machining will be necessary, ie oversized pistons.
once the pan is off, rods are un-done, pound each piston up and out with a wooden block and a dead blow. use some heat, like a propane torch, not a flame wrench, shouldn't do too much damage.
__________________
If only the good die young. I'll be here when you're gone.
Old 11-11-2005, 02:18 PM   #5
chopper daddy
Grenade Inspector
Talking Re: Unsticking a seized engine, tips?
Quote:
Originally Posted by hell_fish_65
It wasn't running yet, but I had backfires and was close. Then one day, nothin.
I read that tech post, and I think I'll try the Diesel. I thought I'd see if anyone had heard of the Tomato Juice idea though. It was new to me.
N8inks said to use "V8", and that'll make my 6 a better engine!
__________________
Old 11-11-2005, 02:19 PM   #6
chopper daddy
Grenade Inspector
It could also be stuck valves, so I think I'll try soaking everything first, then dig into the pistons if I have to.
__________________
Old 11-11-2005, 03:27 PM   #7
Snafu
Newbie
Snafu's Avatar
I use to pick up old engines from junk yards. I made a mixture or automatic transmission fluid and kerosene. Depending on how stuck the engine is, usually a 50/50 works well.
__________________
Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind.
Old 11-11-2005, 03:45 PM   #8
speedtool
I wouldn't recommend using tomato juice - it's very acidic. Might etch the crank bearings and cam surfaces.
Using diesel has a good reputation in these parts, as well as a product called "Knock'r'loose".
Might have broken a ring, too - that would require careful disassembly.
Old 11-11-2005, 03:58 PM   #9
35WINDOW
Grenade Inspector
35WINDOW's Avatar
A long time ago I found a '64 409 Impala with the engine stuck. I made a mixture of Penetrating oil and Lubriplate and dumped it down each hole 3 times over a week's time. At the end of the week I put a cheater bar with a socket on the crank and rocked it back and forth-it worked, and , when I sold the car it still ran good-(why did I ever sell it?
Craig
Old 11-11-2005, 04:27 PM   #10
Louver Dude
Senior Member
Louver Dude's Avatar
"Tomato Juice" ? Ya maybe if it locked up after hitting a Skunk !!! I have never heard that before...Doesn't meen it's not true, just hits me as funny !
__________________
[B][SIZE=4][COLOR=darkorange]Live Full, Die empty
Vagabonds CC
Old 11-11-2005, 04:38 PM   #11
chopper daddy
Grenade Inspector
Quote:
Yeah, I thought it sounded funny. That's why I threw it out here to see if it was valid.
Plus, the clean-up would be a mess!
__________________
Old 11-11-2005, 04:42 PM   #12
Louver Dude
Senior Member
Ya but it does give a whole new meaning to " I Could of had A V8 "
__________________
Vagabonds CC
Old 11-11-2005, 09:09 PM   #13
Joe T Creep
Alliance Member
Joe T Creep's Avatar
I heard this and used it once and it amazed the hell out of me. Filled the cylinders with coca cola. 25 years seized. 2 days free. Still running.
__________________
Stupid friends are worse than smart enemies.
R.I.P. Roderick Teague-My Dad
31 Ford Coupe
58 Ford Truck
Old 11-11-2005, 09:51 PM   #14
Dirty2
Old School HAMBer
Dirty2's Avatar
Quote:
That is what Hot Heades told me to do to my HEMI !!!
__________________
If it dont have 3 pedals it aint no HOT ROD !
If you didnt build it " Shut Up "
" I'm to old to get what I want and to young to give up trying "
me "
www.texasnostalgianationals.com
Old 11-11-2005, 10:35 PM   #15
junkyardjeff
Old School HAMBer
Were you trying to start it with starting fluid?,if you dont get the motor running soon it will freeze up due to the starting fluid taking all the lubrication from the cylinders. I had this happen to me as I was trying to start it in the fall and could not and when I went the next spring the motor was stuck so it got soaked and I got it unstuck. I bought a 65 galaxie parts car that sat for over 30 years to use the stick parts and the low mile 289 but during bumping the motor over to check the valve operation the bottom end siezed due to lack of oil even though it was full as oil never got up in the motor as the motor did not spin very fast. Jeff
Old 11-11-2005, 10:59 PM   #16
johnny bondo
Senior Member
johnny bondo's Avatar
a couple of my uncles old original greasy friends from back in the day had a stuck engine. they poured diesel in the cylinders let it sit for awhile then tryed it and i guess the hotter burning diesel fired it up. as far as i know the engine still runs to this day.
JR
Old 11-12-2005, 02:00 PM   #17
Joe T Creep
Alliance Member
Quote:
I used it once and 2 friends did it and its worked all of the times......
__________________
31 Ford Coupe
58 Ford Truck
Old 11-12-2005, 03:44 PM   #18
speaker
FNG
speaker's Avatar
I use Coke as the deruster on old tools.
Let them soak in it for a few days and the rust is gone.
Old 11-12-2005, 04:35 PM   #19
junk-junkie
Grenade Inspector
junk-junkie's Avatar
I've plugged off intake and exhaust and plumbed low pressure air into the spark plug hole to aid penetrating oil in a really stuck motor... PITA when you have a motor with too many cylinders.
__________________
Please return the stewardess to her original and upright position.
Old 11-12-2005, 06:35 PM   #20
Chili Phil
Old School HAMBer
Chili Phil's Avatar
Thumbs up Re: Unsticking a seized engine, tips?
Here's what I'd do. I'd squirt some Marvel Mystery Oil in the cyls, take the Tomato juice and make me a bloody mary. Let it sit all day (engine, not bloody mary) and into the night. Then I'd take the Coke and mix it with some rum. Then I'd use a breaker bar on the crank end and rock it to the music of your choice. Since you are into raiding the kitchen try some strong coffee and a cheater pipe on the breaker bar if the engine doesn't free up. Be sure to eat with all that drinking so you have the strength to bust it loose. Hope this helps, man.
__________________
The important thing is the obvious thing that nobody is saying.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
