Hey, y'all heres just a fun little poll to see what's in everybodys Hot Rod. Flat Head (Ford) Olds Rocket Hemi (Early) Hemi (Late) Cadillac (OHV) Cadillac (Flat Head) Four Banger Strait Six Strait 8 Nailhead Y Block MEL Chevy 348-409 Ford V8 Chrys.V8 0lds V8 Buick V8 Pontiac V8 Cad V8 Other
You seperated early and late Hemis, you need to seperate SBC and BBC. Tip of the hat for pulling 409s out of the pile.
I thought about that but then i'd have to seperate out ALL the big blocks and small blocks. I know you get 75 choices but then the list would be a mile long.
Nailhead baby!!! Nice clean block, 30thou over 401, going together slowly but going together all the same! It will make its home in an A40 Austin Gasser. Doc.
29 Ford Business Cpe = orig 4 cyl 29 Ford Pickup =SBF 302 C-4 31 Ford Roadster = GM V-6 33 Ford Vicky Convert = SBF 5.0 H.O. AOD 48 Ford Cpe = SBC 400 TH 400 53 Cad Cpe = 331 Hydro
At one stage it was going to have a 53' Packard Straight 8 (327) but the deal on the motor fell through, but man it would have been cool!!! I guess Packard is no better than just a "Other" engine!! Doc.
Straight Six in the 50 Shoebox. Got a Windsor on the stand along with a C4 that I ripped from an LTD last fall. Hopefully I can dig into it this spring..
Currently nothing unless you count my bad westher willys as a hot rod. I was planning a rocket in my next comming up project, but I have to peddle it to pay off some debts so I will probably just use my old standby chebby. Most of the time I end up using a chebby unless I use something else that I just heppen to have lieing around. I have thought about using a 12 cylinder lincoln mill in my project but I just don't happen to have one lieing around. OK confused yet?
