Reply
Thread Tools Display Modes
Old 01-07-2013, 01:26 PM   #1
model A hooligan
Senior Member
model A hooligan's Avatar
Default spark plug wire ohms
So after sitting a month my sbc powered hotrod has a dead cylinder.it has HEI and I testedbthe ohms of the wires only 2 was bellow 11, 000..I had to as high as 16, 000.
What's the limit here?
__________________
The best i can with what i have.
offline   Reply With Quote
Old 01-07-2013, 01:30 PM   #2
325w
Alliance Member
325w's Avatar
Default Re: spark plug wire ohms
I stuffed some HEI wires in an original style early GM wire holders. Ended up cutting the wire and breaking it down eternally. Caused the plugs to fail to fire.
Old 01-07-2013, 01:32 PM   #3
hotroddon
Old School HAMBer
hotroddon's Avatar
Most good plug wires are around 500 Ω per foot - do the math for your length
EDIT: A little quick checking on an old Motors manual and I see that 3,000Ω per foot was not uncommon for stock wires back in the 60's and 70's. I think you can run up to 20,000 Ω and it will still run OK, not as efficient as say 1000Ω but no problems either if the rest of the ignition system is up to snuff
__________________
As I hurtled through space, one thought kept crossing my mind
every part of this rocket was supplied by the lowest bidder. ~ John Glenn
Old 01-07-2013, 01:33 PM   #4
model A hooligan
Senior Member
Well mine arnt in holder's.I'm just asking if these numbers are really high.I though anything over 11, 000 was high but I want to confirm that.
BUT one of mine burned pretty bad on my lake header.it ran fine before line that but maybe the cold helped ruin it
__________________
Old 01-07-2013, 01:34 PM   #5
DoubleJ52
Alliance Member
DoubleJ52's Avatar
1000 ohms per foot is the general rule for most plug wires, unless you use Moroso, MSD, etc that are rated at 40-50 ohms per foot.
online   Reply With Quote
Old 01-07-2013, 01:34 PM   #6
model A hooligan
Senior Member
Quote:
By that formula mine are hardly able to pass as a wet stick!
__________________
Old 01-07-2013, 01:40 PM   #7
model A hooligan
Senior Member
Alright I guess these are really bad then.I'm debating on getting the Taylor's at summit or just some regular ones since I seem to burn them once a year
__________________
Old 01-07-2013, 01:49 PM   #8
hotroddon
Old School HAMBer
hotroddon's Avatar
If you burned them there is a good chance that they are "leaking" - letting the spark jump somewhere to ground instead of firing the plug. Path of least resistance and all that.
__________________
Old 01-07-2013, 02:26 PM   #9
porknbeaner
Alliance Member
porknbeaner's Avatar
Yea, a plug wire can check out well OHMs wise and still be leaking like a sieve.
ModelAhooligan. Get that sucker in the dark and light it iff now look for sparks.
Anther thing you can do it lift the wires one by one while it is running so that they are not touching anything and see if the miss goes away. Sometimes it is best to use a pencil instead of your hand for this procedure.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 01-07-2013, 03:49 PM   #10
model A hooligan
Senior Member
Haha I was messing with it the other day and got shocked.my magneto go kart hurts a lot more tho! I'll probably cap the lake pipes and see if I can fire it tonight
__________________
Old 01-07-2013, 03:59 PM   #11
birdman42
birdman42's Avatar
I have also used a spray bottle with water and sprayed the wires to test for spark leaks.
__________________
How exactly does a positrack rearend on a plymouth work
Old 01-07-2013, 04:03 PM   #12
model A hooligan
Senior Member
Would this cause one cylinder to not fire at all? It ran fine last month, now it won't idle itself and at about 1500 rpm it's deffinatly not running on all 8. And I changed NOTHING
__________________
Old 01-07-2013, 04:25 PM   #13
hotroddon
Old School HAMBer
hotroddon's Avatar
Quote:
if you got shocked while the wire was still on the plug, then it's a bad wire.
__________________
Old 01-07-2013, 07:16 PM   #14
model A hooligan
Senior Member
Haha, good point
__________________
Old 01-07-2013, 07:28 PM   #15
BORRACHO13
if the short is bad enough it can cause a cylinder to basically not fire at all. i would repl wires and go from there. how are your plugs? maybe getting fouled by the bad wires... just a thought
Old 01-07-2013, 07:34 PM   #16
plumbid
plumbid's Avatar
http://www.jalopyjournal.com/forum/s...d.php?t=734270
Just read this the other day...............
__________________
I just build cars. It's worked out pretty good for me this far...
-Dave Shuten
Old 01-07-2013, 08:19 PM   #17
Thunderroad312
Grenade Inspector
I have had wires that checked OK with the ohm meter,but would still miss under a load. sometimes just moving a carbon filled wire will make it separate internally.
__________________
"When his engine roared, they called the highway Thunder Road"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
