Another 54 chevy build
Discussion in 'The Hokey Ass Message Board' started by LOW1954, Jan 2, 2013.
  1. LOW1954
    LOW1954
    Here are some photos of the triangulated four link with air ride that I made.
  2. LOW1954
    LOW1954
    Worked on the chassis as I had time. Here I'm fabricating in the drive shaft hoop
  3. LOW1954
    LOW1954
    The body after I had pulled it off of the chassis, and set it on a dolly. Its a original California car, but has some rust to be repaired.
  4. LOW1954
    LOW1954
    Made the rear brake lines out of stainless braided line, and stainless hard line.
    I also started making the 3/8 air line for the rear air bags, as it is easier to do it now then with the body on.
  5. LOW1954
    LOW1954
    The chassis, as complete as need be for the body to be put back on.
  6. That's some clean ass fab work holmes!! I like it. Clean as hell!
  7. LOW1954
    LOW1954
    The day I had been waiting a couple years for. The body back on the chassis, after some sheet metal had been removed.
  8. LowerthanLife
    LowerthanLife
    nice work. running the brake line like that is a slick idea. what are your plans for the body? chopping, sectioning, stock?
  9. LowerthanLife
    LowerthanLife
    i also dont see any engine mounts....are you going to run the original 6 or a small block?
  10. LOW1954
    LOW1954
    I'm in the process of finishing up welding in a custom recessed firewall, toe boards, and floor boards. I have not fabbed up the motor mounts yet, cause I'm going to run a Chevy 348, and it would be in the way to finish weld the panels. I do have plans to chop its, but I'm slowly working my way there.
  11. yetiskustoms
    yetiskustoms
    Nice Work man. Very clean.
  12. jwl53
    jwl53
    from So cal
    Looks great. Keep up the good work!
  13. eastcoastdoug
    eastcoastdoug
    from Tampa, FL
    Great looking 54 build!! Love the cahssis work? who's suspension front and rear did you use?
  14. LOW1954
    LOW1954
    East coast Doug, I used a TCI mustang II kit, and the
    Rear is a currie ford nine inch housing, third member,
    And axels. The triangulated four link, is something I made
    On my own. I designed the four link brackets on Solid
    Works.
  15. LOW1954
    LOW1954
    Thanks for all the compliments, there are a lot
    Of talented people here on the hamb, and it's great
    To see everones work too, and get ideas.
  16. LOW1954
    LOW1954
    Suspension all set up, just need to fab in my rear sway bar from
    Speedway engineering. Anyone have any knowledge as to how long or short to have the sway bar arms. I'm running a sway bar like the one in the picture, with straight arm.
  17. 53chevtrev
    53chevtrev
    from Langley BC
    Beautiful chassis work there! What are your plans for the body?
  18. LOW1954
    LOW1954
    Im going to nose it, and deck it to get the flow of the body, and eventually im going to chop it, using the stock shaped back glass, just cut a repop glass to fit the chop. Not sure how much im going to chop it, I dont want it to look smooshed. I think I will make cuts till Im happy with it. Any suggestion?
  19. LOW1954
    LOW1954
    53chevtrev, your up there in langly BC right? Have you come across the ROADMEN CAR CLUB. Awesome looking 53!!!!
  20. LeftCoastCruiser
    LeftCoastCruiser
    from So Cal
    That chassis is looking great, nice work.
  21. LOW1954
    LOW1954
    My new column is finally in. I will soon be able
    To steer the car again.
  22. KenCrete
    KenCrete
    from Milwaukee
    Awesome work!! My 54 has been a driving project doing a little at a time. You are giving me the itch to start tearin shit apart!! PS I don't know if the trees would laugh, but I sure did when I read your quote!!! -Kenny
  23. 53chevtrev
    53chevtrev
    from Langley BC
    Firewall looks awesome. I am part of the Kingsmen Vancouver and we know the Roadmen CC
  24. LOW1954
    LOW1954
    Your build, is the type that keep my inspiration
    Going, during times I have no time to be out in the
    Shop. Awesome fabrication skills. I was up in Langley last
    Summer with my club The Roadmen, maybe we will
    See you guys up there this summer. Keep up the great work
    And posts.
  25. california_valley
    california_valley
    from Merced, CA
    Nice work can you do my car? Just kidding
  26. LOW1954
    LOW1954
    Kenny, do it start having fun and tearing into things.
    The only thing I would suggest is keep it a driver as long as
    You can. I have not been able to drive mine for a long time. We live and learn
    I guess. That is unless you have another hot rod to drive while building
    The other. Think that's the reason I tore mine so far down. Thanks
    For the compliment.
  27. LOW1954
    LOW1954
    California valley. Ha ha ha I wish I could help out with your
    Build, only thing is Washington isn't too close too California. Have fun
    With your car and take pictures and post them, so you can keep the rest
    Of us motivated when the weather goes to crap.
  28. LOW1954
    LOW1954
  29. LOW1954
    LOW1954
    Steering column installation under way!!!
