Reply
Thread Tools Display Modes
Old 12-23-2012, 05:21 PM   #1
Hyfire
Senior Member
Hyfire's Avatar
Default Sun Tach Transmitter (Batteries?)
Hello guys,
My car has a Sun Tack from 1958. I was told there may be some kind of battery inside. Does this sound right?
Is there anything inside this box that needs service after sitting a long time?
Also, does the tach need any lubrication?
Thanks for the help!
offline   Reply With Quote
Old 12-23-2012, 05:52 PM   #2
fenderless
Senior Member
fenderless's Avatar
Default Re: Sun Tach Transmitter (Batteries?)
There is two batteries innside, but the problem is that they are discontinued. If i remember right, they are connected in serial.
Each battery is rated 1.35Volts. Combined it's 2,7volts.
I made a external powersupply to give exact that power.
When opened up, you should also messure the capasitors.
Taildragger&fenderless
Old 12-23-2012, 05:53 PM   #3
Lobucrod
Alliance Member
Lobucrod's Avatar
Quote:
Originally Posted by Hyfire View Post
Hello guys,
Also, does the tack need any lubrication?
There are two 1.3 volt mercury cells inside. If they are still there and have been leaking you have a problem. If not then you can use 1.5 V AA alkaline batteries. It will make the tach read about 10% high. There is a company that puts new guts in the old senders that makes the tach read right and its all solid state and runs off of 12V so no batteries. THey also can put new guts in the meter head itself so the sender isn't needed. Both are $200 or so. You can check the meter with a 1.5V battery to see if its good. Just connect a 1.5v battery to the + and - terminals on the back of the meter. No lube required on the meter.
__________________
Makin it Git with Old Shit
Old 12-23-2012, 05:55 PM   #4
wbrw32
Old School HAMBer
wbrw32's Avatar
Yes,there is batteries inside..called a "Mercury Battery"..no longer available..
The transmitter box you have shown needs to be matching to your number of cyl and voltage.. Williamsons in Chester Ark.does a fantistic job on bringing these back to working order
Old 12-23-2012, 07:14 PM   #5
Dick's Beaters
Grenade Inspector
Dick's Beaters's Avatar
Would make a great little Tech Thread
__________________
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
Old 12-23-2012, 07:30 PM   #6
bcowanwheels
Grenade Inspector
The arkansas guy does super work
Old 12-23-2012, 07:36 PM   #7
MercDeuceMan
Senior Member
MercDeuceMan's Avatar
try this link:
http://www.jalopyjournal.com/forum/s...er+tachometers
__________________
"Steel cars do not stink on a hot day"
www.indyroadrockets.com
Old 12-23-2012, 08:05 PM   #8
39 Ford
Senior Member
There is a ton of information here, please just search.
Old 12-24-2012, 12:37 AM   #9
Hyfire
Senior Member
Hyfire's Avatar
Quote:
Thanks guys....
I will crack it open and see what I've got.
Old 12-24-2012, 01:14 AM   #10
Kramer
Alliance Member
Kramer's Avatar
Quote:
Originally Posted by MercDeuceMan View Post
Or theses two:
http://www.jalopyjournal.com/forum/s...d.php?t=747081
http://www.jalopyjournal.com/forum/s...d.php?t=173589
__________________
"YOU haven't been around here long enough to give ME shit,,,,,,so back off dude" . hotrodladycrusr
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
