Reply
Thread Tools Display Modes
Old 12-10-2012, 06:54 AM   #1
bowtiespecialties
FNG
Default 1937 ford 4 dr glass install
Hello!!
I need some tech help. I am installing a power window set up form Nu-relics, looks like a very nice kit, in a 1937 Ford 4dr sedan. I am having trouble with the front door glass wanting to move to the rear of the door when it reaches the top. There are no stops to keep the glass from coming all the way up to the top of the inside of the door or to keep it from moving to the rear of the door frame.
I have never installed a power window kit in this era before.
Any help would be appreciated.
Tom
offline   Reply With Quote
Old 12-10-2012, 10:17 AM   #2
NONAME
Old School HAMBer
NONAME's Avatar
Default Re: 1937 ford 4 dr glass install
it's not the power window install. it's the stock window system with that roll back vent. what I normally do is change the factory half channels that are on the inner and outer frames with a later style chrome bead U channel and shim the slot in the rear of the door with a piece of wood that allows a 5/8 depth for the U channel.
that will allow you to have one channel that runs up the back across the top and down the front. and a section of the half channel on the bottom. so you keep the original look.
parts you need are the chrome bead channel Y-526-96 or Y-528-96. the 96 is the length in inches 8 feet
Ym3-96 is the half channel. you should be able to find those parts local at a better (older)glass shop
__________________
BLUE SKIES AND SUNSHINE, NEVER HAD A BAD DAY IN MY LIFE
www.oldcarglassguy.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
