Reply
Thread Tools Display Modes
Old 10-12-2005, 07:08 PM   #1
chromedRAT
Senior Member
chromedRAT's Avatar
Default please help me ID my saginaw 4 speed...
tried to buy linkages from Jegs tonight and learned that there are apparently a gazillion different cast iron saginaws and half a gazillion different hurst competition plus shifters. dude asked me what i was putting it in, no help there as i read that saginaws weren't put in 65 impalas from the factory. also asked me where the trans came from. under this dude's bench in his garage apparently isn't enough info. took some numbers off of it, here they be:
on the gear box itself, passenger side:
GM 3925656 (or 3925856, casting is rough)
on the side cover, driver's side:
GM 6261888
Tail Shaft:
287 on driver's side, 362264 (the 6's might be 5's or 8's) on the passenger side.
the side cover has seven bolts, and the tail shaft is drilled in a triangular pattern to accept the shifter.
as far as the shifter goes, there's no damned numbers on it. all it says is hurst competition plus and a single patent number.
any help would be appreciated. i spent a year finding the parts to put a 4 speed in this thing, i was actually looking forward to just calling them up and waiting for my damned package. thanks fellers...
__________________
Too busy enjoying raising the kids to do much in the way of shifter knobs for now.
offline   Reply With Quote
Old 10-12-2005, 07:49 PM   #2
SimonSez
Senior Member
SimonSez's Avatar
Default Re: please help me ID my saginaw 4 speed...
So you have a trans with shifter attached, but there are no linkages, right ?
Does the trans have the shift arms on it ?
If it does, you should just be able to measure how long the linkages need to be. Might make it easier to order the linkage, or you could make your own linkage using heim joints.
Put the trans in first and the shifter in first and measure the distance between the holes on the shift arms and the shifter. To double check, put them both in second gear and the length should be the same.
Do the same for third/fourth gear, and also reverse and you should get all the lengths.
If the shifter is not attached yet, make a bracket to put it where it needs to be first, then measure the linkage.
GM 6261888
Tail Shaft:
Old 10-12-2005, 08:51 PM   #3
choprods
Alliance Vendor
choprods's Avatar
Location: Elmer,Mo.USA All the COOL... people on the HAMB have already been here,why haven't you?
How many GROOVES are machined around the front INPUT shaft?
__________________
Running in place, will never get you the results that running from a Lion will.....
Old 10-13-2005, 07:46 AM   #4
chromedRAT
Senior Member
chromedRAT's Avatar
three grooves around the input, pretty sure about that, but i bought it a couple of months back.
there's no shifter on the trans, and trans is bare. the shifter was bought seperate and has linkages for a muncie on it.
__________________
Old 10-13-2005, 01:00 PM   #5
muffman58
Senior Member
muffman58's Avatar
Sounds like a Vega trans.
Old 10-13-2005, 02:28 PM   #6
atch
Old School HAMBer
atch's Avatar
check this; i don't believe that the grooves have anything to do with strength; i think they only delineate the ratios of the gears inside. i'll keep looking, but i've got other sites bookmarked that go into more detail than this one.
__________________
atch (Mike Atchley)
MO hambers - join Missouri H.A.M.B.ers and check out this thread
Old 10-13-2005, 02:29 PM   #7
atch
Old School HAMBer
atch's Avatar
found another site.
__________________
atch (Mike Atchley)
Old 10-13-2005, 02:30 PM   #8
atch
Old School HAMBer
atch's Avatar
check here for identification help.
and here.
and here.
__________________
atch (Mike Atchley)
Old 10-13-2005, 03:00 PM   #9
chromedRAT
Senior Member
chromedRAT's Avatar
pretty sure it isn't vega, as i've heard that their shifters mounted directly to the floor and that they had no provision for a shifter on the trans, no drilled holes, etc, whereas this one does. could be wrong. guy i bought it from held his shifter bracket up to it to show me how it went together. he had promised the shifter to someone so i couldn't get it or the linkages he had. i'd just like to know what to tell the dude on the other end of the phone because they won't let you buy anything without knowing what it came out of anymore...
anybody know what differences there are in the cases and etc of saginaws??
__________________
Old 10-13-2005, 03:30 PM   #10
chromedRAT
Senior Member
chromedRAT's Avatar
or let me ask you this... are the transmissions different at all (aside from some being drilled in the back and some not), or is it just that the shifter is mounted at diferent heights and etc. in different cars, like console vs no console, etc?
i can't find a damned thing on this anywhere besides the gear ratio.
if the transmission end is the same in all of them, and the height and location of the shifter is the thing that varies in each shifter kit, i'll just wing it and say 70 chevelle.
__________________
Old 10-13-2005, 06:27 PM   #11
jerry
Alliance Member
You should be able to get away with calling it a 70 chevelle.
The only difference is in the gear ratios insidw the trans. The 3 ring input shaft is a 3.10 low gear.
I have a mount for a hurst shiter that mounts to the tail housing bolts and has a clamp that goes around the tail shaft by where the seal is. If I can get it back from ENFO in Tucson.
jerry
__________________
"Home of the free, because of the brave!"
Lt. Col. Luke Fitzpatrick, IRAQ
Old 10-13-2005, 07:33 PM   #12
choprods
Alliance Vendor
choprods's Avatar
Its a 4 cyl trans -the floor mounyed shifters were installed on the same transmissions that had a tail mount for a shifter too.....
it has a 3:50 to 1 first gear....ideal really it will take more abuse and will also give you both ends...more out of the hole power and ability to use it with a "hi" rear ratio ,such as a 2:73
__________________
Old 10-13-2005, 11:30 PM   #13
chromedRAT
Senior Member
chromedRAT's Avatar
ah, so it's a chevy II trans then?? should i just call the sonofabitch a "70 chevelle" anyway because it's a bit closer in size to my impala? (in case it makes any difference at all where the shifter ends up...)
thanks fellas...
__________________
Old 10-14-2005, 12:50 AM   #14
ENFO
Grenade Inspector
ENFO's Avatar
Hey Jerry Im still working on making a copy. SORRY!
__________________
Making Tucson the tiresmoke capitol of the world...... one BURNOUT at a time.
online   Reply With Quote
Old 10-14-2005, 07:54 AM   #15
jerry
Alliance Member
Not a problem guy!
jerry
__________________
Old 10-15-2005, 03:59 PM   #16
chromedRAT
Senior Member
chromedRAT's Avatar
broke down bought a new 4 speed indy universal shifter since my comp plus is apparently "too old" to find parts for in this day and age, or flat out doesn't exist according to the jeg's phone jockey. thanks for the help anyway.
__________________
Old 10-16-2005, 07:04 PM   #17
Model A Vette
The case number was used 76-80.
The side cover number was used on "H" bodies (Vega & Monza) 76-78.
__________________
Ed
Old 10-17-2005, 08:45 PM   #18
chromedRAT
Senior Member
chromedRAT's Avatar
good to know, man. first time playing with a 4 speed, i'm looking forward to it.
__________________
Old 10-17-2005, 10:06 PM   #19
muffman58
Senior Member
muffman58's Avatar
Quote:
Told you so ! I just had to say it.
Old 10-17-2005, 10:39 PM   #20
choprods
Alliance Vendor
choprods's Avatar
I've had several and was not kind to any of them- they will be allright!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
