Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 10-04-2012, 03:26 PM   #1
kimlaqua
FNG
Default "Lady in Destressss"
HI everyone, new 2 this site, but seeking advice, i have a 1960 cadillac coupe devile, she over heatered a few weeks back, like u c in the movies, steam everywhere under the hood. took her home and waited a day then tryed to start her again, she turned over but nothing, i think i stuffed the engine, still thinkin what to do?. might have to rebuild or exchange/swap,
this is where i need the advice, if i was to swap what is a good size engine
for my 1960 cadillac. "lady in destresssss"
offline   Reply With Quote
Old 10-04-2012, 03:30 PM   #2
black 62
Senior Member
black 62's Avatar
Default Re: "Lady in Destressss"
to start a car you need spark, compression, and fuel----wet ignition ?
online   Reply With Quote
Old 10-04-2012, 03:32 PM   #3
53CustomlineFlathead
Grenade Inspector
53CustomlineFlathead's Avatar
The engine may be perfectly fine. You need to determine that first.
__________________
My car is like a BIG BLACK DILDO... Most run away but a few people really get off on it!
Old 10-04-2012, 03:32 PM   #4
porknbeaner
Alliance Member
porknbeaner's Avatar
Quote:
^^^ Yep
Trouble shoot before overhaul. pretty hard to toast an old 390 cad.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 10-04-2012, 03:35 PM   #5
HOTRODPRIMER
Alliance Member
HOTRODPRIMER's Avatar
I would add some water to the radiator and look for leaks first,,trouble shoot all the previous suggestions also. HRP
__________________
Tradition without intelligence is not worth having. T.S. Eliot
'54 Ranch Wagon build photos
Old 10-04-2012, 03:35 PM   #6
F&J
Old School HAMBer
Get a compression test first.
I find it hard to think that a boil-over would ruin the rings.
Even if it needed rings, I would not swap a different type of motor in it, as it is too much work, and will cost a lot for all the mods to make it work.
Old 10-04-2012, 03:45 PM   #7
servi53
Grenade Inspector
servi53's Avatar
may have just blown a head gasket, check the easy stuff first
Old 10-04-2012, 03:53 PM   #8
scharleyride
scharleyride's Avatar
start off by checking the coolant level then check the oil, make sure it is oil and not a milky looking mess. then find some one who can help with the no start. just because it over heated does not mean you have killed the motor. Don't want to start guessing as what is wrong but could be simple and then it's back to riding. Good luck and keep us up on what you find.
__________________
It is what it is and it ain't no more so lets go.
[462X0 forever]
Old 10-04-2012, 03:56 PM   #9
manyolcars
Old School HAMBer
manyolcars's Avatar
Quote:
This guy is right.
Put water in it,
notice that water is coming out of the top hose.
Replace the top hose,
go riding
Old 10-04-2012, 04:08 PM   #10
FRANKENSTEIN1313
FNG
FRANKENSTEIN1313's Avatar
I agree check all your fluids first. Thats a pretty solid motor.
Old 10-04-2012, 04:11 PM   #11
Snarl
Senior Member
Snarl's Avatar
After you have checked the oil to see if it has coolant in it, and you have topped off the coolant level and fixed any hoses, etc... then,
when you steam up the engine compartment, you often will get coolant residue all over the electrical connections and inside the distributor cap. It won't like that, so make sure you check over and clean everything and then check for spark. You should also do a compression test to make sure you didn't pop a head gasket.
__________________
Aluminum without fins is like a Playboy without pictures...
Old 10-04-2012, 04:28 PM   #12
HOTFR8
HOTFR8's Avatar
Location: The Hot Rod Centre of Australia - Castlemaine
What is your location ? Some one closer to you may be able to help you easier.
__________________
Help the Environment. Drive a Hot Rod.
Vehicle Recycling Perfected.
Old 10-04-2012, 04:36 PM   #13
Traditions Racing
Old School HAMBer
Traditions Racing's Avatar
Quote:
Originally Posted by manyolcars View Post
This guy is right.
Put water in it,
go riding
" tryed to start her again, she turned over but nothing "
Old 10-04-2012, 10:42 PM   #14
manyolcars
Old School HAMBer
manyolcars's Avatar
Quote:
Probably water in the distributor cap. Use Water Displacement 40 (WD40) inside the cap. Spray liberally
Old 10-04-2012, 10:50 PM   #15
Onemansjunk
Grenade Inspector
Onemansjunk's Avatar
X2x2x2x2x here here
Old 10-04-2012, 10:59 PM   #16
Rusty O'Toole
Old School HAMBer
60 Cadillac had a very durable motor, about 10 times better than the ones they make today.
Unlikely you did any permanent damage if you shut off the engine at the first sign of trouble. If you held your foot to the floor until it clanked to a halt, that is different.
Some very sound suggestions here. You may want to have a good mechanic look it over as well. 9 chances out of 10 he can have you back on the road, good as new, in a few hours.
__________________
Knowledge is power. Soup up your head.
Old 10-04-2012, 10:59 PM   #17
Rickybop
Old School HAMBer
Rickybop's Avatar
Remove the distributor cap...leave the plug wires in place. Dab out the inside of the cap with toilet paper. Then use a hair dryer to finish drying. Replace the cap. It'll probably start. Happy happy. Shut off the engine. Now find the coolant leak and fix it.
__________________
Garage Sale Vintage Parts
Priced To Sell!
http://www.jalopyjournal.com/forum/s...d.php?t=801976
Old 10-04-2012, 11:12 PM   #18
BrandonB
Alliance Member
BrandonB's Avatar
Good idea^^^^^^^^^^^^^^^^^ using a hair dryer to dry out the distributor cap.
__________________
CANCER SUCKS, FUCK CANCER!!!
Old 10-04-2012, 11:38 PM   #19
TheEngineer
Grenade Inspector
TheEngineer's Avatar
Default
How does it crank? Maybe the battery got wet and shorted out. It might have enough juice to turn over slow but not fast enough to start? Did the air filter get wet?
Old 10-04-2012, 11:54 PM   #20
Don's Hot Rods
Old School HAMBer
Don's Hot Rods's Avatar
Rather than spending a whole lot of money swapping something else in there, spend a hundred or so and let a qualified mechanic diagnose it first. Sure will be a lot cheaper and easier. You might have something very simple wrong, which a good mechanic can find, and you are thinking the worst.
Don
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
