Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 10-04-2012, 09:13 PM   #21
Engine man
Senior Member
Default Re: cylinder sleeving
Diesel engines use wet sleeves running much higher compression than any gasoline engine will ever see. The only pressure the joint in the sleeve sees is cooling system pressure as the sleeve is sealed by the head gasket at the top. I've had several engines sleeved that had holes into the water jacket with no problems.
__________________
Anything dropped while working on a vehicle will roll underneath to the exact center.
offline   Reply With Quote
Old 10-04-2012, 09:38 PM   #22
RayJarvis
Grenade Inspector
had my 368 lincoln block resleaved to original . engine shop suggested full 8 resleave as wear had taken its toll. also helps with ballance. cost about 900.00 for all8 but she runs like a trooper.
Old 10-04-2012, 09:46 PM   #23
c-10 simplex
Senior Member
Quote:
Originally Posted by 53sled View Post
Sleeving is $125 per cylinder, and then finishing off the rest of the block is extra. You're into this block, alone, for $300. You obviously need a crank, piston and rods. Maybe more. You're now at $700. For an extra $150 you can get a reman 350 with a warranty.
I've picked up 305's for $100, thrown in some gaskets, timing chain and a new oil pump and been on down the road. Also roller cams don't need special oil.
OTOH, I did try to get a 455 olds sleeved, but again after looking I got a built short block for $100 more than the labor would have cost.
The thing is, i have everything except for one rod and piston---from that cylinder which got bent and cracked respectively, and the head(s) may be cracked/warped.
Would that change anything? Because in order to swap everything over to a "new" block all cylinders would have to be re-honed at the very least? Possibly the mains might have to be line-bored?
2) The oven is from 67---installed new in a Levitt home. The only reason we took it out and replaced it with a new digital kenmore unit was we thought it stopped working, but it turned out to be a defective fuse/switch. Still works pretty good. i still have it because i can't throw anything away----ties in with the theme of this thread. If it is not going to be more expensive than finding another block, i would like to use this one for, admittedly, psychological/frugal reasons.
Hey, i'm not hurting anybody (besides myself). And yes, i need help.
Old 10-04-2012, 09:52 PM   #24
1964countrysedan
Alliance Member
1964countrysedan's Avatar
Thanks for the update on the stove.
good luck with the block!
__________________
My cars have metal ashtrays.
Old 10-04-2012, 09:53 PM   #25
RayJarvis
Grenade Inspector
best ask a machine shop their opinion on a single cylinder sleave and cost. looks like you already have it stripped pretty good so hot tank and inspect it if it has sentimental value. best i can suggest. ray
Old 10-04-2012, 09:56 PM   #26
Engine Pro 5X
Old School HAMBer
Engine Pro 5X's Avatar
I had I had I did I did !!! Here is the long and the short of this story. You have to leave a step at the bottom of the cylinder for the sleeve to sit on. I can see that the crack is too close to the area where the ledge will be !!! This is a Big Red Flag !!!
And the thing about a wet sleeve !!! You already have a huge chunk that's going to fall out of the block !!! And the machine shop guy won't be happy when the chunk comes out while he's boring the cylinder cause it's most likely going to tear the shit outta his boring bar !!!
Now as much as I know it pains everyone on here to see another smallblock Chevy Die this ones Dead !!!
Oh yeah this is just my opinion but I do this shit for a living >>>>.
__________________
GET IN THE TRUCK JETHRO!!! WE'RE GOING TO CALIFORNIA!!! SWIMMING POOLS!!! MOVIE STARS!!!***CAN I SHOW YOU MY BEST KIELBASA ???
Old 10-04-2012, 10:32 PM   #27
GOATROPER02
Alliance Member
GOATROPER02's Avatar
^^^^^ Pro you act like you've done this before...trying to save one when you knew better....and then threw it away anyway...along with the broken carbide...lol
C-10...Im not picking on you personally..Anyone in the buisness will giggle because we face it daily.....Its human nature....Customers asks for advise, and then doesnt want it, because its not what they want to hear.
For the record...I vote...Throw the damn thing away......why put money and energy in junk...Its not like its some rare unobtainium block
Tony
__________________
Ross Racing Engines
1763 North Main St
Niles,Ohio 44446
330-544-4466 w
330-720-1282 c
www.RossRacingEngines.com
Ross Racing T-Shirts
http://www.jalopyjournal.com/forum/s...d.php?t=597973
Old 10-04-2012, 11:13 PM   #28
Rusty O'Toole
Old School HAMBer
That engine is junk. Buy a whole new engine. Do not try to build an engine out of that old junk and another block. Just buy another engine.
If you spent good money on a carb, intake, headers or cam OK swap those parts over to the new engine but that's it.
When I say "new engine" you have to use your common sense. It could mean a decent running used engine, a new Target Master, a rebuilt, it's up to you. Just don't try to fix the old one.
To fix that engine would cost more than buying another engine and it would never be as good.
I hope this is clear.
PS You can keep the old engine if you want. It's no good but you don't have to throw it away if you don't want to. Keep it in the garage next to the 45 year old stove.
__________________
Knowledge is power. Soup up your head.
Old 10-05-2012, 12:01 AM   #29
Ruggie
Grenade Inspector
Ruggie's Avatar
Even if you did save $ on a rebuild it's going to cost you way more in the future when it shit's it's self again, that block is junk bite the bullet and get another one.
__________________
Talking to you is like clapping with one hand....
Old 10-05-2012, 12:03 AM   #30
CGkidd
Alliance Member
CGkidd's Avatar
Looking at what I can see of the pictures I would say the block is toast. Hit a up a swapmeet or craigslist for another block. If you really have to use your rotating assembly I would definately look at getting the crank checked out. Then you will need to get a rod and piston to match your others, balance the assembly and assemble. um maybe you should just get another running engine.
__________________
Long Live Rocketeers.... COFFINS HOT ROD GANG
online   Reply With Quote
Old 10-05-2012, 07:33 AM   #31
porknbeaner
Alliance Member
porknbeaner's Avatar
Rusty,
He is actually in pretty fair shape of he wants to build an engine, he is short a piston and a rod for his lower end, they can be found.
Small block chevy blocks are a dime a dozen, the down side is that he will probably have to bore whatever he finds, which puts him back in good shape cause now he doesnt have to come up with one piston to match the rest.
granted I am a little off center but I would cabbage myself a rod and a block and go from there.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 10-05-2012, 07:55 AM   #32
CutawayAl
Senior Member
I wouldn't sleeve a block unless unless it was rare and/or expensive, or there was some special reason for doing it.
Old 10-05-2012, 10:02 AM   #33
treb11
Alliance Member
treb11's Avatar
Quote:
that's what it boils down to .
__________________
Only the good die young. If you want to live a long time, be an asshole.
" I am attempting madam, to construct a Nemonic memory circuit using stone knives and bearskins "
Old 10-05-2012, 12:00 PM   #34
56sedandelivery
Senior Member
I see nothing remotely special about this block, and the other damage described (possible cracked head, the rod/piston, probable crank damage, and who knows what else), tells me it's time for another engine. The TOTAL cost involved far exceeds anything else, unless this was a one of a kind situation. Also, this same post, including the same pics, is over on HotRodders.Com. I'm not sure how many different answers are needed; the only right one, in this situation, is a complete replacement. Butch/56sedandelivery.
Old 10-05-2012, 06:40 PM   #35
Rusty O'Toole
Old School HAMBer
Quote:
Originally Posted by porknbeaner View Post
Rusty,
If it was you or me, and we had half a dozen dead engines laying around, we could probably put together a decent runner in a day or 2 for the cost of a gasket set.
The questioner is more of a beginner, I don't think he has a spare engine pile yet, or the tools or skills. I still think he would be better off to buy another engine. It's not like they are expensive or hard to get. Aren't the Chevy guys always bragging that the big advantage of the Chev engine is that they are cheap and common? Why do things the hard way.
__________________
Old 10-05-2012, 07:20 PM   #36
RichFox
Alliance Member
RichFox's Avatar
Why do it the hard way? Because knowledge come from experience. I have had blocks sleeved. Don't think I would save this one. But saving as much as possible ans rebuilding it could be a good learning experience. Maybe that's what he wants.
Old 10-05-2012, 07:38 PM   #37
c-10 simplex
Senior Member
What i really want---provided sleeving is indeed practical and possible in this case AND the cost is not too much more than getting another block, is yes, mainly for the learning experience. But also for frugalness reasons; If i get another block i still have this one to get rid of etc. Space, like time = money.
The plan is not to hold on to this block if it is impractical to do so. Costs are a big concern here.
i will possibly provide much more detail to the complete story of this engine later.
Old 10-05-2012, 07:56 PM   #38
convx4
Newbie
convx4's Avatar
I know a rich guy that wanted to run a used NASCAR 426 hemi block that had thrown a rod. Well he ended up sleeving it 32 times. Each cylinders needed to be done twice to get to the size he wanted. Then after putting on a set of heads he found out that NASCAR blocks had different lifter bore angle. So all the lifters had to be sleeved. After putting a ton of money in it, he ran it hard with out any problems.
Old 10-05-2012, 08:31 PM   #39
shawnspeed
Grenade Inspector
shawnspeed's Avatar
Auto cast at the re-cycler here is 300 a ton...sheetmetal is 200 a ton ...sounds like to me , that block and 45 year old stove went to be recycled, you are 1/2 way to a replacement block off c-list....just my 2C...Shawn
Old 10-05-2012, 08:33 PM   #40
c-10 simplex
Senior Member
The stove works fine.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
