Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
FNG
Have a 79 Camero sub frame in my 47 Ford, with the original type power GM steering box. Car is powered with a late 80s Ford 5.0 using the standard ford power steering pump. Had looseness in steering and installed new Ford power steering pump and new GM steering box. Still have looseness (about 1" play at steering wheel). Am wondering if the Ford pump, which originally powered a rack unit, does not produce enough pressure for the old style GM steering box. Any suggestions?
#2 |
Old School HAMBer
is the play in the box, or the steering shaft, front end etc..?
__________________
my favorite color is rust! |
#3 |
FNG
It's in the box
#4 |
Senior Member
how do you think the pump is going to effect play in the input shaft?
__________________
Get the early ones, they are thicker, more material to work with, less flex and better handling. |
#5 |
FNG
I don't know, just trying to diagnose the problem before pulling and returning the rebuilt GM steering box. What I do know is that power rack units such as the late 80s Ford operate on less pressure than the old GM boxes used in the 79 Camero. Also, there is no play in the steering box input shaft - it's a direct connect to the rag joint and I can see it turn as the steering wheel turns.
#6 | |
Alliance Member
Quote:
There's adjustment mechanism built right into the thing.. Oh yea no E in Camaro
__________________
Thank you, I will be installing a breathalyzer on my keyboard the hamb relay network http://www.jalopyjournal.com/forum/g...hp?groupid=214 |
#7 |
Senior Member
With the engine off and the car on stands is there still play? If yes, then check the box or steering components, if no, then suspect the pump.
__________________
MainfraiM Habitat for Art, giving old junk a second life. www.mainfraim.com |
#8 |
FNG
Tried adjusting the old one by loosening the lock nut and screwing in the allen screw at the top of the box. Resulted in same play, but overly tight steering. Is that the right adjuster?
| Thread Tools | |
| Display Modes | |
