Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 09-24-2012, 02:46 PM   #61
PatM
FNG
Default Re: Road Trip Revival: Part 2
I agree with the prior comment that the nailheads will hold up just fine. Water pumps, on the hand . . . I'd plan on bringing a waterpump, as well as a generator and voltage regulator. You're almost certain to lose one waterpump, and when the battery isn't charging, it's just simpler to replace generator and regulator, then polarize. Also bring along a complement of fan belts. They're cheap, and you'll need at least one. Lastly, be certain BOTH spare tires are ready to go. Because one of the non-spares is likely to . . . .
Lastly, though, I know you're gonna have a great time, see some interesting country, and keep yourselves safe. Best of luck to you both.
PatM
offline   Reply With Quote
Old 09-24-2012, 02:59 PM   #62
-Brent-
Old School HAMBer
-Brent-'s Avatar
Looks like what I would've mentioned has already been said, so, I'm thinking maybe one of the hide-away lights will stop working.
__________________
Pre-war 1920 Model T build Reassembly has begun!
WANTED:
- 1933/34 Drive Shaft and Torque Tube
Old 09-24-2012, 03:14 PM   #63
enloe
Alliance Member
enloe's Avatar
Plugged fuel lines
overheating (stuck thermostat or blown rad. Hose)
brake issues
rearend seals
radio quits working
i am so envious of you guys
__________________
I may be dumb but I can lift heavy things ...
Old 09-24-2012, 03:30 PM   #64
n847
Senior Member
n847's Avatar
I'm saying one belt will get eaten. One fuel system will crap out due to crap in the tank/fuel filter. One car will have a brake issue, either seized up at the wheel or a blown out seal. One of the cars (higher mileage car I'd bet) will have transmission slipping issue. There will most deffinetly be a charging issue at some point possibly just caused by a loose and or worn out belt!
I'd also like to say none of these issues will keep you stranded on the road for more than an hour, and likely not delay your return home by more than a half day!
Good luck, and remember we are all living viacariously through your adventure so document that shit like Bass did (the best road trip thread ever).
online   Reply With Quote
Old 09-24-2012, 03:31 PM   #65
n847
Senior Member
n847's Avatar
Quote:
Originally Posted by enloe View Post
Plugged fuel lines
brake issues
rearend seals
radio quits working
OOH...stuck thermostat thats a good one!
Old 09-24-2012, 03:35 PM   #66
n847
Senior Member
n847's Avatar
I'd also like to know what tools/parts you're taking not that it changes my decisions but I'd like to hear what the "experts" take in this instance!
Old 09-24-2012, 03:38 PM   #67
Chris
Alliance Member
Chris's Avatar
Fuel line plugs...even with new filters it plugs. No brake lights, power steering pump is "jerky" when turning and puking fluid. One flat tire, engine uses 7 quarts of oil on the trip...leaky rear main. While your fixing the rear main seal back home throw a front pump seal in the trans too because it leaks as well...three quartes of ATF lost
Oh, and Ryan forgets that reverse is all the way to the bottom if the shift sequence...has a hairy situation while trying some manual fast shift maneuvers!
This is on Ryan's car
The other Riv will have power window problems, charging issues and a vibration at high speeds...u joint.
Have fun boys!
__________________
Swenson's Early Ford Parts
Instagram pictures: http://instagram.com/swensons_early_ford_parts
THEE INLAND EMPERORS
Old 09-24-2012, 04:00 PM   #68
60'coupe
60'coupe's Avatar
The only problem you both will have is from some dodgy Mexican food from some roadside stand, then you will have starter issues from all of the code brown emergency stops.
60'
__________________
Suck it hippy SUCK IT !
Huell Howser
Old 09-24-2012, 04:03 PM   #69
Ryan
Administrator
Ryan's Avatar
Wow... By the looks of things, Norm and I are gonna spend quite a lot of time on the side of the road!
Really, the only thing we plan to do to the cars before we leave is change the oil and check everything else... Look for the obvious. I have a small tool kit waiting for me in MA that I shipped out earlier, but past that we are totally winging it and have decided to mostly prepare for adventure!
There's no telling what will go wrong!
__________________
Ryan Cochran
"Skating the same line since 1976..."
www.jalopyjournal.com - www.garagejournal.com - www.gearjournal.com - www.fordbarn.com - www.DOGFIGHTmag.com
Old 09-24-2012, 04:10 PM   #70
-Brent-
Old School HAMBer
-Brent-'s Avatar
Looking at it like an adventure helps, for sure. I've had stuff go awry on cross country trips and always look back at the situations and their solutions with fondness. People think I'm crazy for it but I think the outlook has always helped.
I'll be living vicariously as your trip progresses. Hell, I'm excited for ya!
__________________
WANTED:
Old 09-24-2012, 04:16 PM   #71
1949*john
FNG
You won't have a single problem on your 2000 mile trip .
when you guys first start out your knuckles will be white for a while and watching the gauges as much as the road but you will calm down and have a wicked good trip .
honest .
Old 09-24-2012, 04:17 PM   #72
NoSurf
Alliance Member
NoSurf's Avatar
Quote:
Not that you won't- but be safe. Take lot's of pics. I am sure it will be a great drive.
__________________
Grandpa's Hotrod, a hotrod children's book for all ages.....Like on Facebook!
Old 09-24-2012, 04:18 PM   #73
Wowcars
Wowcars's Avatar
Ryan, I didn't search the all the threads to see if anyone else has posted this, but I thought it was really interesting....
Buick was thinking about a drop-top Riv.
http://psautomobilist.blogspot.com/2...ss-almost.html
Oh, and good luck!
__________________
She wasn't bad looking, for a girl. Personally I prefer a hopped up motor!
Old 09-24-2012, 04:28 PM   #74
plumbid
Senior Member
plumbid's Avatar
I say, good luck! That should be fun. I was thinking about how one Riv could pull the other???? Just a thought...
Old 09-24-2012, 04:39 PM   #75
oneyellowtub
oneyellowtub's Avatar
Default
Quote:
Originally Posted by hotrodladycrusr View Post
rear wheel bearing issue
No matter what car I'm driving always happens to me.
Good luck and if you need assistance on the road call night or day and I'll get ya the closest HAMB help I can find.
That means you literally drive the wheels off everything you own ; p "hell on wheels"
I guess a ground issue and no lights.
__________________
the Professor
poor boys tennessee
"I've been everywhere man..."
-J. Cash
Old 09-24-2012, 04:42 PM   #76
Malcolm
Old School HAMBer
Malcolm's Avatar
Quote:
60'
Damnit, I just read through this whole thread and towards the end you posted what I was thinking!
My guess was Ryan eating some questionable Mexican food and shitting himself, resulting in a soiled seat.
That's the only problem. The rest of the trip will be smooth sailing.
Malcolm
__________________
www.instagram.com/hoesing
Old 09-24-2012, 04:47 PM   #77
C. Montgomery
Senior Member
C. Montgomery's Avatar
you have prepared better than I did! We were picked up at the airport in the car, went to the mall of america and made the deal, checked the oil, filled her up and pointed her south. all we brought was a change of clothes, some money and an Ipod. had a blast though, as I'm sure you will.
__________________
www.babecoinc.com
Old 09-24-2012, 04:47 PM   #78
Ryan
Administrator
Ryan's Avatar
Malcolm
I NEVER eat Mexican food north of the Red River... I might be crazy, but I'm not stupid!
__________________
Ryan Cochran
Old 09-24-2012, 05:05 PM   #79
earl schieb
Old School HAMBer
earl schieb's Avatar
There's gonna be a lot of losers(non-winners?) in this thread, cause I predict clear skies and fair sailing
If I'm wrong ---I've got you guys covered all thru TN. Truck, trailer and shop on standby. Hell, y'all can even overnight here in the BenD suite. I'll leave the light on....
__________________
I'll paint your car GOOD, FAST and CHEAP!(pick any two)
Old 09-24-2012, 05:33 PM   #80
hillbilly4008
Old School HAMBer
hillbilly4008's Avatar
Now thats livin'!
My predictions:
-Several hundred miles with a hangover
-in atleast one of the two cars there will be a radio that just won't work
-faulty fuel gauge
-"Why yes officer, I know I was speeding. Thing is.....this is my first drive in the new car. I wanted to see what top end was."
Have a safe trip guys!
__________________
Slowly becoming a " hardcore anal traditionalist"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
