Go Back   THE H.A.M.B. > The H.A.M.B. Marketplace > Classifieds > eBay Ads & Links
Reply
Thread Tools Display Modes
Old 09-20-2012, 09:54 PM   #1
Sh1fter
FNG
Sh1fter's Avatar
Default 1937 Fiat Topolino For Sale -Steel Body, titled & tagged
http://cgi.ebay.com/ebaymotors/Fiat-...item1e72572d48
1937 Fiat “Topolino” 500
Titled, tagged & regularly driven in Colorado
Original Steel body & suicide doors
Original steel gullwing style louvered hoods
One-off fiberglass grill, also have spare (new) stock dimension shell
Interior:
Bucket seats
4 Point Roll bar
Factory sliding glass side windows
Removable soft top (factory option)
G-Force 3” lap belts
Mark Williams quick release steering wheel
AutoMeter:
Monster Tach w/ recall & shift light
Oil, Water, Voltage, Fuel pressure gauges
Motor:
327” SBC
Early Double hump heads
Victor Jr. Intake
Chrome accessories
Chrome Headers with removable mufflers or muffled turnouts
Cooling System:
Mechanical and electric fans
Gonzo Aluminum recirculation can
Fuel Delivery:
750 cfm Holley dual feed, double pump, choke milled off
NOS Big Shot nitrous oxide system
Holley Blue Fuel Pump
Petersen Fluid inline billet filter
Aeromotive regulator
Hobbs fuel safety switches
AutoMeter Fuel pressure isolator
All stainless AN lines and fittings
K&N air cleaner
Custom aluminum fuel cell
Ignition:
Accel electronic distributor
Mallory coil
Electric:
Master kill switch
PowerMaster starter
Chrome Alternator & low mount kit
Rear mounted battery (New & new cables)
2/0 welding cables
Battery Tender charge leads
Dietz headlights
Impala tail lights
Transmission:
T-350 Manual valve body
TCI Street Fighter 3500 rpm Converter w/ anti-balloon plates
Hurst shifter with quick release cover
Deep pan with cooling tubes
HD remote cooler
Frame/Suspension:
2x3 square tube frame
Front:
Dropped tube axle with hairpins
Early GM spindles and brakes
MG knee action front shocks
Transverse leaf
Every heim joint replaced in last 100 mi.
Rear:
Narrowed 8-3/4 Chrysler
4.10 ring & pinion with Sure-Grip posi in "489" dropout
New Mark Williams axles/studs/bearings
New rear 11” brakes
Ladder bar & panhard with coil over shocks
Axles & drums drilled for Chevy or Ford patterns
Tires/Wheels:
Front:
M&H tires with 15x4 polished Centerlines on 5x4.75 BC
Rear:
M&H 27x14.5 tires with 15x12 polished Centerlines on 5x4.5 or 5x4.75 BC
Front & Rear magnesium wheels available at additional cost to vehicle buyer. (Not to be sold separately)
Click image for larger version
Name:	DSCN0378 (2) (1024x768).jpg
offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
