Reply
Thread Tools Display Modes
Old 09-16-2012, 08:19 AM   #1
cvtech107
FNG
Question 1937 oldsmobile IFS
New Guy
I just bought a 1937 F-37 2 door sedan Slantback Oldsmobile. Has anyone upgraded the front suspension on one of these? I would like to put a chevy smallblock in it, but I need a more modern frontend. Fatman Fabrications makes an IFS, does anyone else?
offline   Reply With Quote
Old 09-16-2012, 09:07 PM   #2
oldspert
Senior Member
Default Re: 1937 oldsmobile IFS
Read the article in the November issue Rod & Custom. They rebuilt a 55 Olds with later components. The suspensions are basically the same set up.
__________________
one driver, two in the back seat, three on the tree, four on the floor, and a fifth under the seat.
Old 09-16-2012, 09:51 PM   #3
olds vroom
olds vroom's Avatar
Default
I don't know about updating the suspension but you can put a sbc in with the old stock suspension in place I did on my 41 olds.Click image for larger version
ID:	1742142Click image for larger version
Old 09-16-2012, 10:22 PM   #4
55olds88
Senior Member
Quote:
is that 2012 November ? if so I will need to keep an eye open for when it gets here, would be very interested to know what they did.....
Old 09-17-2012, 09:20 PM   #5
oldspert
Senior Member
My mistake, it was a 50 not a 55, but the same suspension design.
__________________
Old 09-18-2012, 05:06 PM   #6
55olds88
Senior Member
thanks sure it will still be worth taking a look at when the mag surfaces down here (shoulda kept up my sub....)
Old 09-18-2012, 07:50 PM   #7
cvtech107
FNG
Thanks guys, I wasn't on line for a couple days so I'm just getting back to you. Olds vroom, did you also lower your car? And what did you use for motor mounts? Looks Good!
Old 09-19-2012, 08:50 AM   #8
olds vroom
olds vroom's Avatar
Default
Still at stock Hight but I made mounts to hook to the stock frame mounts
Old 09-19-2012, 09:26 AM   #9
porknbeaner
Alliance Member
porknbeaner's Avatar
Quote:
Originally Posted by cvtech107 View Post
New Guy
PM El Polako. He does a real sweet Dakota front end. And while lots have had good luck with fatman's stuff it isn't any better if it is even as good as Steve's stuff and doing business with steve will keep it in the family.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 09-19-2012, 09:47 AM   #10
terryble
I put 56 Olds front suspension on my 37 coupe many years ago, had to cut out the top of the spring area on the frame to accomodate tube shock and I used the 37 spring. It was a bolt in except for the shock mount that had to be fabricated and it had much larger drum brakes with more common, larger and readally available shoes and other parts. Olds went to ball joints in 57
Old 09-20-2012, 07:20 PM   #11
cvtech107
FNG
Thanks Guys!!
Jerry
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
