Reply
Thread Tools Display Modes
Old 10-03-2005, 02:07 PM   #1
Action Girl
Action Girl's Avatar
Question Front end alignment specs
Here's the specs from the recent front end alignment we had on Faye. The steering is tight (won't return), and from what we can tell, the caster is wrong.
This is a mustang 2 front end. Can anyone tell me what this SHOULD be? The alignment shop seems to have it wrong.
I'd like to take the correct specs in with me when I take it to have it fixed.
Stacey
offline   Reply With Quote
Old 10-03-2005, 02:37 PM   #2
Kruzer63
Kruzer63's Avatar
Default Re: Front end alignment specs
I just went thru gettin a good alignment on my 53 pontiac which also runs a mustang 2 front set up. The alignment that the shop did on mine is excellent. I agree the caster appears to be wrong. I will send ya my specs when i get home from work today as i have the print out there and will dig it out for you.
__________________
...It's got a cop motor, it's got cop tires, cop suspensions, cop shocks...
Old 10-03-2005, 02:42 PM   #3
DrJ
Old School HAMBer
DrJ's Avatar
It doesn't look out of range to me, except I don't know what degrees relate to fractions of inches, which is the "old" way to measure toe in.
I also don't understand the toe in or camber being anything but 0 unless it's an independent rear end, or the rear axle is bent, or the measuring equipment is out of wack.
"thrust angle" to me just tells whether the wrench drove the car on the alignment rack straight or not... looks like he go it real close.
Those Fords calld for near 0 caster on most cars so you having 2.5 already may be an issue but I'd look at it being a sticky gear box first and sticking idler arms kingpins/balljoints whatever the linkage is second.If it's a R&P steering, maybe the pinion needs adjusting (or shimming, as the case may be) away from the rack a bit.
__________________
Not my fault, I was at camp.
Old 10-03-2005, 02:56 PM   #4
tommy
Old School HAMBer
tommy's Avatar
You want the castor to be a positive number for the steering wheel to return to center after a turn.
read about it here
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
Old 10-03-2005, 03:24 PM   #5
RacerRick
Old School HAMBer
RacerRick's Avatar
Castor is way off.
You should have positive castor - usually on late model cars, up to 5 degrees. Helps with stabilty at speed. I usually just try to get as much castor as I can. Anything over about 2 degrees is great for a cruiser. Your camber is a little excessive for a cruiser also. I would go no more than a half degree. I would also set the toe to about 1/8" or less.
My camaro road racer has a pretty aggressive street alignment - 1.5 degrees camber, 5 degrees castor, 1/8" toe in.
The race alignment is real aggressive - 5 degrees camber, 5 degrees castor, 1/8" toe out. Basically my castor is maxed out on my car all the time.
You need some positive castor for the from wheels to return to center. The more you have the greater the tendancy. A nice basic alignment specs that work for most cars is about 2-3 degrees castor, half a degree camber and real close to zero toe - usually just a smidge of toe in. This is assuming you are running radials - bias like different specs.
Old 10-03-2005, 03:44 PM   #6
Old School HAMBer
squirrel's Avatar
just as a point of reference, the specs for the MII and pinto cars were roughly
caster 1/2 to 2 degrees positive
camber 3/4 degree positive
toe 0 to 3/8"
I'd probably try for 1 to 2 degrees postive caster, leave the camber alone (set it back to where it is now after adjusting the caster), and set the toe between 1/8" to 3/16" (whatever that works out to in degrees?)
__________________
Jim Forbes
my shtuff
online   Reply With Quote
Old 10-03-2005, 04:18 PM   #7
Action Girl
Thanks!
Yeah, I knew the caster was off, but wasn't sure how much. Thanks for all the help guys, i'll be taking this to the shop to get it straightened out.
The odd thing is that they drove the car after the alignment and you think they would have noticed that the wheel wasn't returning AT ALL. Oh well, now they get to fix it.
Stacey
Stacey
Old 10-03-2005, 05:41 PM   #8
tommy
Old School HAMBer
tommy's Avatar
You may want to ask them to check the specs in the computer and has it been calibrated lately. That looks like a Hunter computerized print out. If so the computer stores all the specs. The tech. moves things around until the bar graphs turn from red (out of spec) to green (within spec). It would not be unusual for him not to pay any attention to the numbers or whether it is positive or negative. After you do a couple of hundred alignments all you want to do is to get everything in the green. If it's all in the green...it's aligned. unless of course the specs are inaccurate or the heads have been dropped. They come to trust the machine.
For it to be that far off the indicator light wouldn't even be on the bar graph scale.
__________________
Old 10-03-2005, 05:58 PM   #9
mikes51
Senior Member
mikes51's Avatar
Quote:
Here is what autocad shows me. For tires with a diameter of 26", if each tire is angled .09 degrees, the centerlines of the front side of the tires are about 3/32" closer than the centerlines of the rear side of the tires.
Old 10-03-2005, 06:37 PM   #10
muffman58
Senior Member
muffman58's Avatar
Tommy, Most of the CUSTOM alignment I do have to be entered into the computer manually becuase you cannot align a car with mustang II front end by spec, unless its a mustang II! I do Cobras,Hotrods, etc.. Most people bring the specs that they want to go with, or that the manufacter supplied with the kit. It looks like -2.0 degrees negitive caster to me in the pics, That will not work. The others suggest 2 degrees positive which is better, but It depends on the car, and how it is to be driven. The more caster the better as far as making the car go straight down the road. Mercedes want as much as 10-12 degrees caster! This was designed into them for Autoban speeds. These cars will almost pull the wheel out of your hand after cornering. More caster equals more return!
Old 10-03-2005, 07:16 PM   #11
Old School HAMBer
squirrel's Avatar
yeah, they ought to change the caster and go for a drive with AG driving and see if she likes it! if not maybe add some more.
When I got my 55 aligned the guy put in some car models that would be close, I think he punched in an early Camaro, because his computer only went back to the mid 60s. But then he also knew what he was doing, unlike some techs.
__________________
Jim Forbes
my shtuff
Old 10-03-2005, 07:36 PM   #12
RacerRick
Old School HAMBer
RacerRick's Avatar
My road race car only will go to 5 degrees castor unless I change the upper A-arms. I would love more for high speed stability. I would have to use shorter arms (about 1/2" ) with the ball joint moved towards the rear of the car.
Most of those old cars are hard to get more than 2 degrees of castor on.
Old 10-03-2005, 07:40 PM   #13
Kruzer63
Kruzer63's Avatar
I PM'd you with my specs directly off my sheet.
__________________
Old 10-03-2005, 08:15 PM   #14
enjenjo
Senior Member
I just had one done with a Mustang front end. I had it aligned to the specs that generally work best for me. camber .5 to 1.0 degrees positive, caster 5 degrees positive, more if needed. Total toe in .060 inch.
__________________
You can't be part of the elite unless you have someone to look down on.
Old 10-03-2005, 08:15 PM   #15
DrJ
Old School HAMBer
DrJ's Avatar
Quote:
WHAT?
Are they too "secret" for the rest of us to see?
__________________
Old 10-03-2005, 08:41 PM   #16
tommy
Old School HAMBer
tommy's Avatar
Quote:
Yeah the G-111 that I had has a custom setting that we put in it for mid-60 Chevelles when I was into them. The machine needs to know what it's looking for before it can tell you what to do to get there. it shouldn't be looking for neg. 2.5 deg. caster.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
