Reply
Thread Tools Display Modes
Old 09-02-2012, 09:01 PM   #1
Dirty Dug
Old School HAMBer
Dirty Dug's Avatar
Default One piece front crank seal for an 8BA?
After 3000 miles my AV8 is leaking like a sieve. I've seen those one piece front seals and before I tear into it over the winter I'm wondering if any of you have had any experience with these as opposed to the conventional rope seals.
offline   Reply With Quote
Old 09-02-2012, 09:46 PM   #2
Dirty Dug
Old School HAMBer
Dirty Dug's Avatar
Default Re: One piece front crank seal for an 8BA?
No one? Maybe it's a slow day for flathead guys, I'll wait for them all to come home.
Old 09-02-2012, 10:13 PM   #3
Vergil
Vergil's Avatar
I have two 8ba av8's, both with Reds Headers lip seals and have had 0 problems with them. I do use the thin stainless sleeves they sell to cover the spiral oil grooves on the cranshaft pulley.
Vergil
Old 09-02-2012, 10:29 PM   #4
wideglide74
Senior Member
wideglide74's Avatar
Can you post a photo of the AV8? I am just having my 59A assembled and was planning to use the rope seal as I have read they work well, maybe that move should be reconsidered.
__________________
WTB Very clean, rear mount, curved lense SW Fuel gauge...
Old 09-02-2012, 10:43 PM   #5
mtflat
mtflat's Avatar
I've been running them for 11 years in a daily driver 48 pickup.
There are two styles I'm aware of -
the simple seal from Red's
and the other that I'm more familiar with - it has an aluminum shell that encases the seal and is machined to completely fill the rope cavity. I smeared a little RTV on the shell and dropped it in and have had no leaks. A lot more expensive than the bare seal, but I think it was worth it.
__________________
They were right........the world IS flat!
Old 09-02-2012, 10:53 PM   #6
Doctor Detroit
Alliance Member
Doctor Detroit's Avatar
Quote:
Who sells this style? If anyone has pictures of these seals, please post them. This is good info for future reference.
__________________
My 1951 Mercury Build Thread:
http://www.jalopyjournal.com/forum/s...d.php?t=641282
1949-1951 Mercury Parts & Reproduction Parts List:
http://www.jalopyjournal.com/forum/s...d.php?t=331564
Old 09-02-2012, 11:27 PM   #7
Dirty Dug
Old School HAMBer
Dirty Dug's Avatar
Thanks for the replies. I've seen them from many aftermarket suppliers but don't want to do this twice. What makes the ones from a particular supplier better than another? Are they the best way to go? I have to replace the crank pulley as well so this isn't a stretch if it's worthwhile.
Old 09-03-2012, 12:21 AM   #8
lowsquire
Old School HAMBer
lowsquire's Avatar
Youll find the that the lip seal sold by flathead vendors is a standard size available at any bearing shop..
The problem is that it is actually slightly too big for the cavity which isnt actually sized to a standard seal size, and the cavity also tends to not be totally round,once you compress the pan gasket. What I have found is that as you tighten the sump down, it actually distorts the seal slightly oval.. and then it leaks. for this reason, I have gone back to rope seals. The last two engines I have done with rope seals leak less from the front than my car, which has the rubber lip seal. Make of this what you will.
__________________
www.ranchodeluxe.com.au
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
