Reply
Thread Tools Display Modes
Old 09-01-2012, 07:00 AM   #1
Deuces
Old School HAMBer
Cool SBC 350 connecting rods...
Anyone ever use the chevy truck "X" rods for their 350 engine build????...
These rods have an "x" forged into the beam and are beefier than the car style rods...
Post pictures if ya got'em!!..
Thanks guys!..
__________________
***** God Bless the U.S. *****
offline   Reply With Quote
Old 09-01-2012, 07:05 AM   #2
ididntdoit1960
Grenade Inspector
ididntdoit1960's Avatar
Default Re: SBC 350 connecting rods...
Ive used em - they are the same as pink rods without the extra magnafluxing and inspection thus no pink paint
Old 09-01-2012, 07:13 AM   #3
Deuces
Old School HAMBer
Yep!.. Those "pink" rods went through a longer shot peening cycle after the "mag" test proccess..
__________________
Old 09-01-2012, 07:18 AM   #4
26 T Ford RPU
Senior Member
26 T Ford RPU's Avatar
When i was building V8s in the eighties i knew them as Z28 rod also, i think, it was while ago.Good rods,just what a 350 needs with its rod/stroke ratio.
Old 09-01-2012, 07:25 AM   #5
outlaw256
Senior Member
outlaw256's Avatar
ive read somewhere and i cant remember where but those pink rods are a joke,they were colored for some assembly reason. again i cant remeber but they arent what we always thought they were.now i gotta spend a few days going thru some old magazines!! im not sayin they are a joke im just saying that they werent what we thought them to be. i can rememeber that much of the damn article anyway.lol
Old 09-01-2012, 07:27 AM   #6
Deuces
Old School HAMBer
The "x" rods that I used came from the '70-'71 Chevy/GMC 350 4-bbl pickup engines... Those also had a "steel" crank and a 4-bolt block with nodular iron caps... Not sure on the nickle content in the block... I've seen blocks that had "020" cast into the timing chain cavity...
Still a great lower end to work with for a hot rod motor..
__________________
Old 09-01-2012, 07:41 AM   #7
Hans' Rod & Cycle
Alliance Member
Hans' Rod & Cycle's Avatar
I used them all the time back in the day. I would polish the sides, then shot peen the entire rod with old rod bolts in place(and protectors for bearing surfaces of course), heat treat them in the oven and swap out the stock bolts with ARPs. they lived behind 500+hp street/strip motors all day.
Hans
__________________
Hans' Rod & Cycle
Texas/Norway
Old 09-01-2012, 07:46 AM   #8
Deuces
Old School HAMBer
These "x" rods have less material on the ends for weight balancing I believe... So they pretty much weigh the same as the car rods...
Damn, I wish I had some pics to post..
__________________
Old 09-01-2012, 07:53 AM   #9
BOBCRMAN
X rods and "0" rods were used for the "pink" rod cores. Different production processes than regular rods.. They were always in seperate baskets when on the assembly line floor. I used to be in the Chevrolet V-8 Van Slyke engine facility back in the day.
Early 68-69 production and some service rods were "dipped" in bearing material on small end for floating pins. Later went to press fit,.
Old 09-01-2012, 08:08 AM   #10
Deuces
Old School HAMBer
I remember reading an article once where they tried to hold .0003" on the L-88 bbc rod small ends and installed floater pins without using bushings... And they ended up scrapping that idea..
__________________
Old 09-01-2012, 08:16 AM   #11
Deuces
Old School HAMBer
Thumbs up Re: SBC 350 connecting rods...
Quote:
Hans
Always a "smart" idea to install those ARP's before "re-sizing" the BiG end on a Sunnen hone machine...
__________________
Old 09-01-2012, 09:02 AM   #12
GOSFAST
Grenade Inspector
GOSFAST's Avatar
If you're looking for the "stronger" rod, the "O" is much better choice!
I've placed a photo below of both side-by-side and you can see the difference on the beam rails.
You can also see the difference between the balance-pads, usually the thinner these pads are the stronger the rods are, most of the material is in the "body" of the rods.
Thanks, Gary in N.Y.
P.S. We get numerous requests still from the "resto" guys for the "O" rods, we are running low but I still have some on the shelf. They came in the "DZ" and the early "LT's".
Click image for larger version
Name:	SBC Conn Rods O-X.JPG
Old 09-01-2012, 01:37 PM   #13
aaggie
Alliance Member
Unless there is a rules reason that you have to use the stock rods why not just buy the Eagle or other aftermarket H-beam rods. They are stronger and come with ARP fasteners installed. I have built several SBCs using them and the machine shop always checks them first just to be sure. I have had no failures yet.
Old 09-01-2012, 02:00 PM   #14
RacerRick
Old School HAMBer
RacerRick's Avatar
H beam rods tend to be heavy - usually i the realm of around 50gms a rod. This will require rebalancing, and the H beams usually are not needed.
The stock replacement I beam rods like those from SCAT are the way to go these day for anything less than a race motor. They are forged out of 4340, have an improved design, are made to better tolerances, are much stronger, weigh the same, come with ARP bolts, and are brand new. Can't go wrong for under $200. Costs more than that to rework a set of stock rods these days.
__________________
Building cars from scrap since 1992!
Old 09-01-2012, 04:31 PM   #15
Deuces
Old School HAMBer
Quote:
Because I'm a cheapskate...
Plus those stock rods were forged and machined here in the United States...
Unlike some of the aftermarket rods...
__________________
Old 09-01-2012, 04:37 PM   #16
Deuces
Old School HAMBer
Oh, I don't know...
I don't mind working with a set of stockers...
Didn't you know that all the scat stuff is made overseas???..
I think a set of stock rods if prepped right can handle 8000 RPM's all day long...
__________________
Old 09-01-2012, 05:05 PM   #17
Deuces
Old School HAMBer
Thanks for the pic Gary...
I learned something new today... About the "O" rods ...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
