Reply
Thread Tools Display Modes
Old 08-24-2012, 01:04 PM   #1
31Vicky with a hemi
Alliance Member
31Vicky with a hemi's Avatar
Default paint ? kirker ULTRA-LOCKMetallic Control Additive / Basecoat Converter
Anybody ever use this ?
Better link
http://www.kirkerautomotive.com/html/ultra-lock.html
(About mid page here)
http://www.smartshoppersinc.com/kirk...urethanes.html
Here's why I'm asking- finally picked a color for a project and its 785.00 a gallon for the base. Plus 200 quart for second color . Plus clear . Its not that nice of a project !!!
I found nearly identical colors at summit in single stage AU for 100 a gallon and 20 a quart roughly. Two tone and SS isn't a good decision and I always get at least one dirt, baggers or orange peal in a SS job. Not a big deal because they are solid & get rubbed ..... BUT ....these are metalics so that's not going to happen.
Says it converts SS to a base coat , locks metalics and pearls, eliminates modeling & that needs cleared. Perfect right?
Oh yea summit paint is kirker product under private lable
That product would solve lots of problems and save me a boat load of $$.
Thanks
__________________
Thank you, I will be installing a breathalyzer on my keyboard
the hamb relay network
http://www.jalopyjournal.com/forum/g...hp?groupid=214
online   Reply With Quote
Old 08-24-2012, 01:27 PM   #2
man-a-fre
Senior Member
man-a-fre's Avatar
Default Re: paint ? kirker ULTRA-LOCKMetallic Control Additive / Basecoat Converter
I used kirker ultra glo hugger orange acrylic urethane on a 72 blazer and loved it,its going on 3 years in the sun and no fade and covered right away.previously i used ppg omni hugger orange and it took 4 passes to cover ,yeah i didnt value shade with the omni but i didnt value shade with the kirker either.I like the Kirker paint myself ,not a real fan of their fil primer,it has alot of shrinkage use spi for that,kirker epoxy seems real good.I have never used ultra lock yet but wouldnt be afraid to. Not a real fan of spraying there clear cant seem to keep orange peel out of it but the paint lays flat and has alot of depth without clear.
offline   Reply With Quote
Old 08-24-2012, 01:34 PM   #3
31Vicky with a hemi
Alliance Member
I liked the paint ive got from kirker in the past and the paint from summit too.
I'm specifically asking about the ULTRA-LOCK metallic control base coat converter
__________________
Old 08-24-2012, 08:19 PM   #4
henry29
Senior Member
henry29's Avatar
I have never used it, but I have seen it used.
The car was driven daily for two years after it was painted, it still looked the same with no clear peeling off the last time I seen it.
Looked like it sprayed just like base coat.
Old 08-24-2012, 08:37 PM   #5
Roger53
Grenade Inspector
I've used it on there silver met. For the out side And heres my but I jamed with out it first and then did the car. I 'll do with out it on the next one. I don.t think it's worth the cost.I feel the paint went on great with out it. And the same as someone else said on there clear little orange peely. Overall I give there paint a thumbs up. Roger
Old 08-24-2012, 08:39 PM   #6
tb33anda3rd
Old School HAMBer
tb33anda3rd's Avatar
buy a small amount and try it. paint under the hood, trunk or door jambs and see how you like it. the problem i had with kirker was not the durability, it was the coverage. i think the way they get the price down is to skimp on pigments, so you HAVE to match the primer to the color.
__________________
my favorite color is rust!
Old 08-24-2012, 08:52 PM   #7
31Vicky with a hemi
Alliance Member
Yea probably, the kirker color is speced for white sealer under coat.
I do plan on trying some, just looking for some feed back on the product.
1400.00 for base coat alone is kinda nuts for a driver.
If it works I'll be in at 200.00 for the base coat.
__________________
Old 08-24-2012, 08:58 PM   #8
tb33anda3rd
Old School HAMBer
i painted kirker yellow with a light gray primer. but i had touched up a couple spots with a dark gray primer. after three coats of color that wouldn't cover the dark gray i had to shoot over the spots with a light gray and then repaint. i did not save money.
__________________
Old 08-24-2012, 09:09 PM   #9
31Vicky with a hemi
Alliance Member
Uniform sealer coat or undercoat is nice with most paints, necessary with some , and imperative with others.
Some of those kirker colors are speced out with different color under coats.
Most spray out cards have white, lt gray, dark gray, and black so it makes a huge difference. Yellow probably more than most. Sometimes looking at a OEM yellow you can almost see thru it- weird.
__________________
Old 08-24-2012, 09:21 PM   #10
tb33anda3rd
Old School HAMBer
learned my lesson, fortunately, it was a snow plow for a friend, but i wanted it nice.
i painted twenty two steel drums for a junior high band [for free] and cringed when they showed up with two gallons of donated kirker red paint. i got the paint supplier to donate red primer and it came out fine. still have the tape, of the bands concert, the music teacher gave me for my effort.
__________________
Old 08-24-2012, 10:38 PM   #11
Olyspud
FNG
I painted my wife's '31 pickup with Kirker (My first paint job), and it turned out OK. The faults with the paint job were with my inexperience rather than any problem with the product. I did this in 2006 and it's still holding up well even though the car is a driver, not a trailer queen.
Click image for larger version
Old 08-24-2012, 10:46 PM   #12
Kirk Hanning
Senior Member
I usually only paint 1 car a year so the best that I can do is sweep & tarp up the garage. With that in mind using single stage paints generally means less coats. With bc/cc your looking at at least 6 or 7 coats of paint/clear where SS you may be able to get away with 3 with good paint. Your going to get dirt & junk in the paint, its inevitable, but putting on half as many coats surely cuts it down.
Old 08-25-2012, 06:13 AM   #13
tb33anda3rd
Old School HAMBer
the nice thing about the ULTRA-LOCK product, if it works, is you could paint door jambs and underbody stuff as a single stage, and then mix in the additive for the outer sheet metal and clear it. please let us know how it works.
__________________
Old 08-26-2012, 12:11 PM   #14
31Vicky with a hemi
Alliance Member
Up once more
__________________
Old 08-26-2012, 12:21 PM   #15
buikwag
buikwag's Avatar
Heres my 1956 Buick Wagon painted with Kirker single stage Acrylic Urethane Viper Red, and Arctic White. Painted the whole Wagon White first and then the Red over the White. Paint is now about 4 years old.
__________________
"It's not your Wife, It's not your Life, It's only MONEY"
______________________________________________
Over the Hill Gang - San Bernardino.CA
www.othg-sanbernardino.com
My Personal Web Site
http://mysite.verizon.net/jcox14/index.htm
Old 08-26-2012, 01:29 PM   #16
31Vicky with a hemi
Alliance Member
Wow that's nice!
__________________
Old 08-27-2012, 08:32 AM   #17
31Vicky with a hemi
Alliance Member
Up again for opinion, info & knowledge exchange
__________________
Old 08-27-2012, 12:28 PM   #18
31Vicky with a hemi
Alliance Member
OK. Everyone bashful?
__________________
Old 08-27-2012, 06:52 PM   #19
31Vicky with a hemi
Alliance Member
Yep, still looking for info.
Their tech department says its great
__________________
Old 08-27-2012, 07:52 PM   #20
tb33anda3rd
Old School HAMBer
your going to have to try it so WE can find out if it is any good.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
