Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Some of the detractors of belt driven cams complain about "interference" engines that suffer damage when a belt breaks. Not all are.
Seems like many of the popular V8s needed piston machining just to create safe running clearance if a very frisky cam is installed. Or, start missing on a few cylinders if my punk cousin downshifted his hot mom's stock V8 Mustang into second at full speed. So, if the chain broke or even wore and jumped a link or 3 the wrong way I'm guessing the pistons could whack the valves in more engines than suspected. Surely Ford 302s and inline 6s were among the ones that had plastic sprockets that would fail badly at mileages approaching 100K. |
#2 |
Old School HAMBer
SBFs will take the valves out if the chain breaks.
__________________
Confucious say Tennis elbow better than Tennis balls |
#3 |
Old School HAMBer
Both 5.0L Fox ponys I've bought new came with a double roller timing chain set...
__________________
***** God Bless the U.S. ***** |
#4 |
Alliance Member
Did you just call your aunt hot?
__________________
Every time you use it is one less time it's going to work. So use it up! |
#5 |
Alliance Member
__________________
HOT RODDING - It used to be about the cars, now it's just a freakin Fashion Show ![]() |
#6 |
Alliance Member
A majority of cars came with plastic tooth timing gears from the factory as they were a bit quieter then metal gears and didn't fostered the engine making noise complaints on new cars that a metal gear might.
And yes there are a number of non ohc cars that will bend a batch of valves if you loose a timing gear.
__________________
Definition of a "work car". One you have to work on all weekend so you can drive it to work the next week. |
#7 |
Alliance Member
That's all I got out of that too! LOL Something isn't hitting on all 8 but not sure if it's the motor or not! I take that back... Lets see a picture of your hot aunt, then we'll decide. |
#8 |
#9 |
Old School HAMBer
I lost a timimg belt on my OT Volvo. called a Volvo repair/parts place and this dingy lady answers the phone. always right, and always argumentative. quite the bitch.
first I ask for one of the guys, they are all busy, so I ask her if the 1976 2.1 is an interfereance motor or not. she doesn't know what this is, so I tell her some motors valves hit pistons when the belt goes, while others it does not. I would like to know which type this is. she tells me I have to bring it in and they will have a look. I explain it again what I am talking about and I get the same line. 2-3 times we go through this, I'm also asking to speak to someone else during all this with no response. finally as I was about to tell her she is a stupid so and so I just hung up. found out later this motor does not hit the valves when the belt breaks. that lady is crazy, it is not the first time i have had problems with her.
__________________
"everytime someone posts about an LS motor on the HAMB a vintage motor throws a rod through the pan" |
#11 |
Old School HAMBer
My daughter had the timing chain slip on the original plastic tooth sprocket. on her shit box 307 Chevy....bent some push rods and bent a few valves.
#12 |
Senior Member
Well then.........whats your granny like....?......Is she spry...?
__________________
"This job is just a skidmark in the drawers of life" Rusty Ole Pile of Shit Car Club |
#13 |
Old School HAMBer
__________________
Warning: This post may contain satire. "Sat ci sat bene" |
#14 |
Alliance Member
Lets see maybe you should have called him your stupid punk cousin if he can't drive no better than that. Any engine that jumps time can cause damage. The damage is not always the same either. Just because an engine has a 100 thousand miles doesn't mean its going to jump time.What is your point anyway. You throw your rice burner into second at top speed and see what happens to it.
#15 |
Grenade Inspector
Screw the engine...Let's see your hot aunt!
__________________
"I'm MAD DAMN IT!!!" |
#16 | |
Old School HAMBer
Location: Upstate New York, watching my New Yorker Rust
Quote:
I found out how to make a 301 Pontiac an interference motor. Throw a rod and bounce the piston off the valves and it comes down and interferes with the crank. But some replacement pistons can have different reliefs in them not because the motor is necessarily interference but because the pistons are made to fit multiple years where heads or valve angles were changed at different points in production, so they can sell one piston for all of them instead of two or three different ones.
__________________
"That was a time when America was great.. when the chrome was thick and the women were straight" - Michael Savage I have old cars for sale. PM me or check the classified. |
#17 |
Old School HAMBer
The term "interference motor" really only applies to engines that have a rubber band connecting the crankshaft to the camshaft. If it has a chain, it doesn't matter, because they don't generally break after 75,000 miles.
#18 |
Old School HAMBer
Most over head valve engines will bend valves if the timing chain/belt/gears let go.
Overhead valve engines have been around for 100 years. .
__________________
.. Wise men talk about ideas, ordinary men talk about things, fools talk about each other |
#19 |
Grenade Inspector
Get a flathead it does not have that problem.
#20 |
Old School HAMBer
I'm not sure I understand the question.
| Thread Tools | |
| Display Modes | |
