Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Member
Time for a major garage clean out.
1930 Ford Open Pickup project. SOLD Next up is a sectioned 32 grille shell and insert, filled original. $450 ![]() 32-6 21 stud aluminum heads. for domed pistons i believe, no cracks that I could see. Minimal corrosion. $150. ![]() ![]() Model T hood, 26-7 I think, but I don't have one here to check it on. Nice shape, not perfect. $50 Pile of 32 headlight parts. 2 gutted buckets, 3 trim rings. $40 ![]() 1966 300hp 327 .030 over, RV cam, no accessory hole 1.94 double hump heads. Have a gasket set to go with it as it has been sitting in my garage for a couple years. $650 ![]() 1962 283, disassembled, nice builder, no cam. $80 ![]() See below for the rest of my garage clean out sale. Thanks, Dave
__________________
WANTED: 40-46 WL tanks, solo seat, 40 or 41 matched cases, misc. parts. Last edited by Carter; 09-18-2012 at 02:26 PM. |
#2 |
Alliance Member
Chevy 3 speed with Hurst Mystery shifter. Nice shape. $125
![]() 35-6, I think, perch bolts, good threads. $SOLD Mallory Dual Point for SBC, needs a gear, $25 ![]() F-1 steering box parts, housing, sector shaft and steering shaft, cut off at about 2 feet. $SOLD 2 nice 16" wires with good 6.00x16 tires $SOLD 2 21" 28-9 Model A wheels with NOS Sears whitewalls, tires are still in excellent shape. I mounted them on these wheels. $150 ![]() Decent pair of 30-31 front fenders, $SOLD More to come
__________________
WANTED: 40-46 WL tanks, solo seat, 40 or 41 matched cases, misc. parts. Last edited by Carter; 09-18-2012 at 02:28 PM. |
#3 |
Alliance Member
33-4 rear crossmember, nice. Has had a small bit of welding right around center bolt hole. $80.
![]() 37-41 and 42-6 axles, $40 each. ![]() Nice Model A wishbone. Can split for shipping. $70. ![]() 2 35-6 banjo rears. Will separate radius arms. $150 per axle complete, or $125 per pair of radius arms. ![]() Model A hydraulic brake mount. $25. ![]() Early Falcon door, Ranchero, Wagon, 2 dr. $50 ![]() Falcon 4 door roof. FREE. ![]() 1 inboard mount and 1 outboard mount hub for 40-48 Ford front. $25 each. ![]() Also, have 2 complete 37-38 rear axles for sale at $75 ea. Or, I will sell hubs for $50/pair and radius arms for $45/pr Model A engines and transmissions. $Engines sold, $40 and up for transmissions.
__________________
WANTED: 40-46 WL tanks, solo seat, 40 or 41 matched cases, misc. parts. Last edited by Carter; 08-31-2012 at 08:43 AM. |
#4 |
Alliance Member
Nice Mallory dual point with 2 piece cap and brass condensor. $75
![]() ![]() Wide 5 wheels, have 8, 4 have decent tires on them. wheels are $20/ea, 4 with tires are $80/pr. 2 tires are street tread, 2 are NDT military type tread. ![]() 17" wire wheels, all pretty nice. Would like to keep a few, but should have 6 to sell. $25 ea. ![]() Crusty B head(with large C on it) $25 ![]() 19" wheel, 1 bent spoke. $15 ![]() Model A transmissions, have 4 or 5 . $40-60 Farmer repaired late 28-late 29 front crossmember $20 ![]() ![]() Model A center crossmembers, have 3, $5 ea. ![]() complete 29 front axle, drum-drum, wishbone, etc. Upper one in picture $100 ![]() Also have connecting rods, flywheels, pressure plates, oil pans, valve covers, oil return pipes, starter and generator cores(no powerhouse) Last edited by Carter; 08-20-2012 at 10:25 PM. |
#5 |
Alliance Member
To the top again.
#6 |
Alliance Member
Reproduction 28/9 coupe panel below decklid. Looks just like my roadster piece but shorter. Has a little ding on the corner, can see it in top of 1st picture $40
![]() ![]() 1 single front hub and drum, hub outside the drum, nice shape. $40 ![]() Crusty set of front juice brake plates, early style(39-41) complete plus one extra bare rear plate $45 ![]() ![]() ![]() ![]() ![]() And a bump to the top. Make me an offer if you see anything you need. Dave
__________________
WANTED: 40-46 WL tanks, solo seat, 40 or 41 matched cases, misc. parts. Last edited by Carter; 09-18-2012 at 02:30 PM. |
#7 |
Alliance Member
To the top again.
Make an offer. |
#8 |
Alliance Member
To the top again.
Dave |
#9 |
Alliance Member
Bump.
#10 |
Alliance Member
To the top again
Sent from my DROID device using the TJJ mobile app
__________________
WANTED: 40-46 WL tanks, solo seat, 40 or 41 matched cases, misc. parts. |
#11 |
Alliance Member
Up again. More to come.
__________________
| Thread Tools | |
| Display Modes | |
