Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
Has anyone tried the Mooneys white wall toppers, I am considering some for my 56" Poncho wagon...would appreciate some feedback on how these have worked for you..right now I cant afford whitewalls but will consider in the future..right now will try them but before will need some info on them...Thanks guys!!
#2 |
Alliance Member
Are you referring to porter walls?,,,they are lame and don't lay flat against the tire. HRP
__________________
Tradition without intelligence is not worth having. T.S. Eliot '54 Ranch Wagon build photos |
#3 |
Alliance Member
we put some on an early El Camino, we used valcanizing fluid and roughed up the back side and the tire. we let them sit out in the Arizona sun 120 ish until they sat flat. they held and most people did not know they were fake WW. They got dirty and stained faster than real WWs. I would try and find something to give them a thick protective coating.
__________________
If your gonna be dumb, you gotta be tough |
#4 |
Old School HAMBer
Easy to spot and look "poserish" to me. Kinda like hemi valve covers on a small block chevy. Wait till you can get the real deal.
__________________
Some of you guys are so tight with your money, I bet you can stretch a penny to wire your car. |
#5 |
Alliance Member
I installed dozens of them in the 50/60s. If you want to look best and lay flat simply break the front bead and using no lubricant place the porta-wall over the rim evenly then reinflate the tire using a rubber mallet(cloth wrapped so as not to put black marks all over the porta wall) pound on the piece close to the rim as soon as the bead pops in place. Continue to pound the piece as you fill the tire with air. Important to use no lubricant and keep pounding, then stay away from curbs etc...............This was bias-ply tires radials weren't around in the U.S. yet.
__________________
I aint done nothin wrong
#6 |
Classified Editor
They gotta work better than rubberized whitewall tire paint. I painted the radials on my 55 Pontiac wagon...laid on about 4 coats over a peiod of 3 days...left Omaha for Minneapolis and hit the first rest stop about 20 miles out....EGAD! The radials had worked back and forth, heating the paint which melted and deposited itself in the wheelwells and down the sides of the car.
I hear the porta-wall-type covers will work back and forth on radials until they come apart. I'd go with a set of diamondbacks next time.
__________________
My wife says I never listen to her....at least that's what I think she said. |
#7 |
Senior Member
My mother had porta walls on one of her off topic cars a few years ago(beetle) they actually looked pretty legit, however, they chewed into the sidewall of the radial tire. Not sure if they just arent designed for radials or what. But i would never use them.....
__________________
I like real customs. |
#8 |
Had Porta-walls on a Classic Morris Mini, They looked good when I had the narrow Bias plys on it, but would not sit right on Radials.
__________________
Tradition is a guide, not a jailer - Somerset Maugham Narf! - Pinky |
#9 |
Alliance Member
They don't work well on Radial tires because radials have their strength in the tread, meaning the sidewalls flex a bit. Bias plies have their strength in the sidewalls, meaning the tread is the flexy part.
__________________
Good running 292 Y-Block needed! |
#10 |
Grenade Inspector
Thanks for the advice guys..anyone have any pictures with them on??
#11 |
Grenade Inspector
Bump
#12 |
Old School HAMBer
I ran them years ago and remember driving down the road and suddenly seeing a big chunk of whitewall fly up in the air. If you even lightly touched a curb it would cut them and that was the end of that portawall.
Wrinkes were also a problem. Don |
#13 |
As already mentioned, I wouldn't necessarily recommend them. However, I did run them on a 51 Ford I had a few years ago and thought they looked decent on an old beater pickup...But, they are no comparison to the real thing and have all the problems mentioned already. I didn't run them long enough to see any of the problems personally. Here are a couple pics.
__________________
H.A.M.B. Chapel Last edited by guthriesmith; 07-31-2012 at 06:41 AM. |
#14 |
Alliance Member
^^^^^^ Those appear to be on radials and look good ^^^^^. I ran 'em for years and with care had no problems on bias plies. Some put them on the inside on fenderless cars to have two-sided whitwall tires.
__________________
#15 | |
Alliance Member
Quote:
I used to find them on the side of the road alot when they were still popular, they used to fly off. When I collected a full set I would sell or give them to someone else.
__________________
If it don't make ya dirty it ain't yours No man crosses a chasm in two jumps |
#16 |
Yea, the ones on the Ford were on radials and it took me several tries to get them to lay flat. Once I got them on initially laying flat, they seemed to stay that way for at least the time I had them on. I didn't have them long enough to see if they wore into the sidewalls.
__________________
H.A.M.B. Chapel |
#17 |
FNG
![]() These are the Atlas branded ones. Make sure you keep the back of them greased with rubber grease or vasoline otherwise they will perish and tear off and also chafe the side walls of the tyres. Just replaced the front 2 and the last ones were on there for nearly 10 years. |
#18 |
Grenade Inspector
Thanks again...keep em pics coming!!
#19 |
Old School HAMBer
Used a lot of them back in the early 60's and liked them...but yes all the problems listed above "could" be a problem....I rarely had any problems with them....and think they are cool today on period correct cars that used them....
JMHO.. Cheers......... |
#20 |
Grenade Inspector
I have been running them on the '56 for over 5 years, no issues at all. The brand on my car are "Wegu", came from Germany of all places!
I'll buy actual wide whites when I can afford them, but for now I'm saving up for paint/interior updates.
__________________
[SIGPIC][/SIGPIC] |
#21 |
Grenade Inspector
What kind of tires are you using Royal Lancer??
#22 |
Senior Member
Bear-Foot (?), the maker of the "genuine" Port-A-Wall, sold Toppers. They made big whitewalls into the trendy new "inchwalls" with a ribbed black rubber ring installed just like the big one.
#23 |
Grenade Inspector
Anyone tried the ones Mooneys sell?
#24 |
Grenade Inspector
Bump
#25 |
Grenade Inspector
Anyone else with some advice??
#26 |
Get on YouTube, they got some good demos on mounting. I read that wheel width and tire size can make a hugh difference on the out come.
__________________
Why does everyone ask me if my car is a Tucker or Studebaker?? |
#27 |
Senior Member
Until i saw them "in action",..they seemed like a cool item....Nice, until the car is driven....... Gimme the real deals.....
4TTRUK |
#28 |
Grenade Inspector
Thanks..now 'm really gonna save up for the real deal whitewalls.
#29 |
Grenade Inspector
Your time's worth $$$. Sounds like a lot of wasted time for a mediocre look - and the look is the whole point, no? Maybe look for some used WWWs...? A lot of guys are going back to blackwalls these days and may be selling.
#30 |
I put my last set on my '41 SD in 1966. I put them on a set of 6:00 x 16 Sears 2 ply tires. They are still there (see photo) I'm not sure what I did to get them to lay flat but I remember it wasn't easy. I think I had to push the inner lip down into the rim so the Porta was sucked tight to the tire. Anyway the worked and they have lasted 46 years on the car. (46 YEARS?!? Holy Crap, Am I that old)
#31 |
Alliance Member
I just ditched the Porta-Walls that came installed on my Buick. They look like they wear out long before the tires and looked like hell, but who knows how long they were on there. Word of caution though, if they dry-out like mine had, they can be downright sharp on the edges...
__________________
'29 A Phaeton - '52 Champion - Dad's '58 Apache - Lost & Found '59 Scotsman Goodbye Dad, I love you. |
#32 |
Grenade Inspector
Im definetly saving up for the real deal!!
#33 |
Grenade Inspector
The smaller ones look better and are tucked up onto the tire more. I have one we use for display and it fools the heck out of people.
__________________
Wow its Peach...is it a 80's something? |
#34 |
Grenade Inspector
__________________
#35 |
Alliance Member
I think I'll stick with real white walls on my car but, I think port-a-walls look great on the trailer that I pull behind my motorcycle.
![]() ![]() These are the current offering from Moon. Doc
__________________
Renember, traffic lights set for 35 m.p.h. are also set for 70m.p.h. |
#36 |
Alliance Member
Anyone here have a regular whitewall ground back?
__________________
Road Devils - Texas RDFL |
#37 |
Grenade Inspector
Thanks for the Info... Always wondered myself!
#38 |
Alliance Member
I've got a couple sets of the old METAL port-a-walls hanging in my shop. Found them in the trunk of a 49 Plymouth years back. Talk about not looking user friendly! Really had never seen metal ones before I found these.
__________________
It's Not Just The Cars! It's A Lifestyle |
#39 |
FNG
anyone say, revive a thread???
![]() i am a noob to custom car culture but my first truck had 14" wheels with port-o-walls/ white wall toppers/ ww inserts and i have had no problems with them. they dont sit flat but still not too bad... and, later, had to buy new/used tires but they still worked fine on the new radials. i like em'. the only issue i had was the tire shop guy does not like to put them on... haha so now i have to learn to put them on myself
| Thread Tools | |
| Display Modes | |
