Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Member
Its all about comfort I need some imput on what you feel is a great seat to go on a drive with and not feel like you need to take some advil everytime before or after you go for a ride. I want to replace the bench seat for some buckets in my 47 ford pickup .
Thanks for any imput |
#2 |
Senior Member
I would recommend taking measurements for what you have. For example I doubt you want the top of the seats to stick above the rear window. With that being said once you have an idea for measurements trying going to a pick a part. Most foreign cars, honda, toyota, mazda are good options as they are compact. My model A has buckets from a Dodge Neon. Your 47 has a fairly wide cab, so those may not work. Good luck.
__________________
Life ain't easy when your fat and greasy |
#3 |
Old School HAMBer
That is the trick, getting bucket seats from a modern car to look right in an older car. As motoandy mentioned, you don't want highbacks that stick up too far. Some cars have headrests that will pop off, lowering them down some.
You may want to hit the wrecking yard with a tape measure and see what fits and looks right to you. Don |
#4 |
Alliance Member
Years ago I put some Honda Accord seats in a 1940 Ford pickup, they were very comfortable, and fit well in the narrow cab. Isn't a 47 cab the same width as a 40?
#5 |
Late '80's Dodge Caravans had low back buckets that were very comfortable on long rides.
#6 |
Old School HAMBer
the problem with old pickups is the thickness of the back of the seat. You're replacement needs to have a thin back.
I used a late 80's Ford Ranger bench seat in my F1. Comfortable, thinner back than a stock seat by about 2 or 3 inches, still folds forward like the original. |
#7 |
Old School HAMBer
I just found this picture of the Fox Mustang seats I bought when I was building my Mustang. The headrest pops off, and these are pretty compact and come with sliders on the bottom. These are pretty much the same from 79-93.
Just something to give you an idea of what might fit. Don
#8 |
Old School HAMBer
We put a pair of late 90s Honda Accord leather upholstered buckets in the 32 3W Coupe. Comfortable, removeable headrests, driver side adjustable to death, passenger manual, also used the seat belts from the same car. Ought to be fine in a pickup.
#9 |
Alliance Member
My 37 sedan had Caravan front seats. If you don't have a gas tank under the seat to worry about, the height is perfect. Driver side is power, pax side has a storage bin underneath. Easily re-covered, headrest pulls out if you don't like them. Super comfy. Plentiful and cheap. Gary
__________________
Nostalgia isn't what it used to be. Change is inevitable, except from a vending machine. http://www.jalopyjournal.com/forum/a...p?albumid=2874 http://public.fotki.com/kitbashr/ |
#10 | |
Alliance Member
Quote:
Still when it's all said and done a properly redone stock seat is usually more comfortable in a pickup than most any other seat. I've probably had a dozen different seat setups in the 48 and the most comfortable was the original seat that a friend in Waco redid for me. Second was a 66 Olds Toronado seat that fit great after the truck was chopped and looked great in the truck but the foam fell apart and I got stupid and pulled it out rather than having it redone. what ever you use get a eat with backs that are pretty thin and don't lean back a long ways like the Camaro/Firebird seats that cut your legroom in half.
__________________
Definition of a "work car". One you have to work on all weekend so you can drive it to work the next week. |
#11 |
Grenade Inspector
The seats in my Altima are the most comfortable I've ever sat in. The driver seat has independent height adjustments for the front and back of the seat, adjustable lumbar, removable headrest, etc. I've driven cross country in the car a few times without issue. I love the way the seat wraps around you to hold you in place in tight corners.
The drawback is the look. I wouldn't put these in anything older than a late 60s muscle car... If that. If you don't have some nuts and bolts left when you get it back together, you did something wrong. -Papaw |
#12 |
Senior Member
The best vehicle seats I ever had were in my 78 Eldorado Biarrritz. After driving for 12 hours, it felt like I spent all day in my recliner. They are large and won't fit in a small vehicle.
The most uncomfortable seats were in a 2010 BMW that I drove from Minneapolis to St Louis because the owner had a sore back from driving from St Louis to Minneapolis.
__________________
Anything dropped while working on a vehicle will roll underneath to the exact center. |
#13 |
Alliance Member
Sorry. If you're all about comfort, go buy a new Mercedes. Sure, comfort is a concern since the majority of us here do like to drive our cars and not be beaten up by them. But the comfort needs to be within the bounds of traditional ideals, and Altima bucket seats and the like don't fit. Put some new foam and upholstery on your stock bench and enjoy. That's more than enough comfort than you'll ever need.
__________________
-'57 Joe Street Aces CC - New Jersey "When life knocks you down from first class to coach, fart a whole lot and really stink up the place...that'll show 'em." |
#14 |
Pontiac Fiero seats.
The earlier ones had speakers in the headrests that many rodders like. |
#15 |
Old School HAMBer
70's Mercedes buckets look old time and have removeabvle headrests
maybe a 220 or 280 model
#16 |
Alliance Member
Thank you
#17 |
Alliance Member
Also look into non-sport seats from an 82-88 BMW 5 series, the leather ones look almost like rolled and pleated and are very comfortable.
__________________
Good running 292 Y-Block needed! |
#18 |
Grenade Inspector
Find some old 65,66 Mustang seats. The repops work fine and you can find covers for them that will fit any look you want. They sell covers that don't have the mustang emblem on them. I had a 66 that was daily driver and they were comfy seats. The fox body seats were good too but don't have the correct look IMHO.
#19 |
FNG
the seats in my 47 ford pu are from an early 90's taurus. they are vey comfortable and fit well. couple hundred miles no problem. if you're at the junkyard, check pt cruiser seats too.
#20 |
Senior Member
I installed a pair of 88 Fiero seats in my Street Rod. If you are wide in the hip don't use them. I chose them for low seating position and they fully recline. Here is a pic.
__________________
My Avatar can flip-flop, when I switch hats, and I have a lot of hats. |
| Thread Tools | |
| Display Modes | |
