Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 07-19-2012, 02:33 PM   #1
94hoghead
Senior Member
94hoghead's Avatar
Default cutting torch pops
I'm having trouble with my new Harris cutting torch. Whenever I try to fine tune the tip to begin a cut, the torch begins to pop. The closer I get to having the cones nice and sharp, the faster the pops become until it finally blows the torch out. If I add just a light pressure on the lever with my thumb I can get the popping to stop. I've got the acetylene set at 5-7lbs and the oxygen at 40lbs. The tip has 6290-0 stamped into it and is nice and clean. I'm cutting 1/4 to 3/8 metal. any suggestions?
offline   Reply With Quote
Old 07-19-2012, 02:35 PM   #2
porknbeaner
Alliance Member
porknbeaner's Avatar
Default Re: cutting torch pops
Quote:
Check for air leaks.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 07-19-2012, 02:39 PM   #3
Jedidiah
Alliance Member
Jedidiah's Avatar
Tank settings sound good. Try opening the acetylene knob on the torch a little more before you turn on the oxygen.
Old 07-19-2012, 03:19 PM   #4
Rattle Trap
Grenade Inspector
Rattle Trap's Avatar
Check the seal on your tip.
Old 07-19-2012, 03:30 PM   #5
65standard
Grenade Inspector
65standard's Avatar
Try another tip.
__________________
Tony Nicholas
1953 Chevy 3100
1938 Ford COE
Old 07-19-2012, 09:34 PM   #6
Kiwi Kev
Old School HAMBer
Kiwi Kev's Avatar
I would turn the Oxygen down to 20lb. If that tip is size 0 I would step up to a 1. Find a chart that tells you tip size and gas pressure settings for different metal thicknesses. The main thing is to keep the tip perfectly clean.
__________________
That's MISTER low buck to you pal!
Old 07-20-2012, 01:44 PM   #7
hotrod428
Newbie
hotrod428's Avatar
yer suckin air someplace, tighten all the fittings.
__________________
http://hotrodsandbrakes.com/
Disc brake conversions for Studebaker Ford Mercury Edsel Thunderbird
Old 07-21-2012, 02:28 AM   #8
designs that work
Grenade Inspector
designs that work's Avatar
Had a shop teacher fill a balloon with acetylene, at six or seven pounds the balloon exploded. To be safe lower he acetylene to lower then 5 pounds. Not trying to be a wise guy, it is a real safety issue over five pounds.
__________________
Flathead Alternator Sling Shot Brackets
Old 07-21-2012, 03:43 AM   #9
Human Fly
Senior Member
Human Fly's Avatar
Dirty tip.
online   Reply With Quote
Old 07-21-2012, 05:59 AM   #10
Morgan91
Morgan91's Avatar
Default
Check for air leaks and Mabey less oxy
Old 07-21-2012, 06:13 AM   #11
bobss396
Old School HAMBer
bobss396's Avatar
Definitely too much oxygen. 20 should do it for cutting. Do you have a tip cleaner? If not they're cheap and a must-have. A clogged/dirty tip will also contribute to the popping.
Bob
__________________
Proud member of the "they closed my thread" HAMB crew. -- BobSS396
Old 07-21-2012, 06:35 AM   #12
bbc 1957 gasser
bbc 1957 gasser's Avatar
i had a new tip do that changed it out it was fine
__________________
buy ,sell ,trade old gas pumps, signs ,cans ..
restore gas pumps and cool old stuff....
Old 07-21-2012, 10:36 AM   #13
Engine man
Senior Member
Check the nut that holds the tip. It needs to be tight. Check to make sure that there isn't anything on the inside of the nut or tip preventing it from sealing.
__________________
Anything dropped while working on a vehicle will roll underneath to the exact center.
Old 07-21-2012, 10:45 AM   #14
JD Miller
Grenade Inspector
JD Miller's Avatar
buy a tip cleaner and use it to clean the tip. Use the proper size to run down in all hole in the tip to file burrs and sh*t out of there. Gas welding 101
__________________
Pinstriping-Truck Lettering
No Snivelers
Old 07-21-2012, 10:48 AM   #15
BobF
Grenade Inspector
BobF's Avatar
Check for air leaks, tight fittings.
I've always used 5 and 15 on the tanks for up to 1/2" mat'l just the way I was taught in HS metal shop a loooooong time ago
Old 07-21-2012, 11:29 AM   #16
hooliganshotrods
Grenade Inspector
hooliganshotrods's Avatar
3 psi acytelene and 30 psi O2.
Are you sure you are giving the torch enough acytelene before you add the oxygen?? That is usually why they backfire like what is happening to you. You want to be working in the smoke range with cutting but not to low. A good way to get the right amount is to light the acytelene and keep turning it up slowly on the needle valve on the torch until ALL the black smoke (carbon) clears, THEN turn it back a half turn on your needle valve into the smoke range.
Old 07-21-2012, 11:39 AM   #17
94hoghead
Senior Member
94hoghead's Avatar
The tip is new, plus I've cleaned it repeatedly just to make sure. Whats confusing me is that I can add a light pressure on the level and the popping will stop. I've tightened everything I can find and will adjust presures as per the chart HOTROD428 posted. Plus, I'm buy another tip this afternoon just cause.........I appreciate all the help and advice. Thanks guys.
Old 07-21-2012, 12:18 PM   #18
Engine man
Senior Member
I would say that the tip isn't getting a good seal between the cutting hole and the pre-heat section. When the fuel gets into the cutting hole, it burns when it gets out of the tip and the fire goes back into the tip causing the popping. When you press the handle to put oxygen through the cutting hole, the fire can't go back into the tip to cause the popping sound.
__________________
Old 07-21-2012, 12:47 PM   #19
metlmunchr
Grenade Inspector
Quote:
That'd be my best guess too. I've got Smith, Victor, and Airco torches but not familiar with Harris and their tip setup. If there are gaskets on the tips, I'd check to see how they look. Usually the retaining nut doesn't have to be all that tight to seal, but, especially on a Smith torch, if someone ever cranks down on the nut like a gorilla just one time then the gasket gets deformed and overtightening is the only way it'll ever seal in the future.
Old 07-21-2012, 01:03 PM   #20
GearheadsQCE
Grenade Inspector
GearheadsQCE's Avatar
Quote:
Acetelene becmes very unstable when released to the atmosphere at greater thatn 15 psi. I don't believe you could see the difference between 3 and 7 psi.
The later replies suggesting an internal restriction or bleed from the preheat to the cutting orfices make the most sense.
__________________
Gearhead's Quickchange Exchange
"My rear end is louder than yours"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
