Reply
Thread Tools Display Modes
Old 09-22-2005, 01:00 PM   #1
Mule Farmer
Alliance Member
Mule Farmer's Avatar
Default stuck valve can you fix with out tear down
have a stuck valve can it be fixed without tearing the head off. the motor had been sitting a wile.
bret
offline   Reply With Quote
Old 09-22-2005, 01:05 PM   #2
AV8Paul
AV8Paul's Avatar
Default Re: stuck valve can you fix with out tear down
Quote:
bret
I've had good luck adding Marvel Mystery oil to the oil ( 1 Qt) and and 6 oz to the gas. Cleared up in a couple of days.
__________________
If it's too LOUD.
You're too OLD
Old 09-22-2005, 01:06 PM   #3
Bruce Lancaster
Alliance Member
bret
Flathead-overhead-whatever controls specifics, but if you can force the thing closed without bending or breaking anything and keep cycling it a few times with lots of oil, you can most likely get it functioning again. Use Marvl Mystery oil in oil and in gas for a while once it runs--magic unsticker stuff.
Be aware that valves are much easier to bend than you think...
__________________
Bruce
Old 09-22-2005, 01:11 PM   #4
Mule Farmer
Alliance Member
No I meen that its stuck stuck not sticking once and a while. Your idea seams like a good idea for a running motor that the valve that sticks once and a while but mine is stuck from sitting for a long time like maybe there is some rust on the valve and its stuck in the guide.
Thanks Bret
Old 09-22-2005, 01:19 PM   #5
chuckspeed
Alliance Member
chuckspeed's Avatar
bret
On a flattie, i've had luck with penetrating oil. If it's only a cylinder or two, you can get the motor runnin (REALLY rough, mind you) and the combination of heat and vibration will do the work of unstickin' for ya.
I did that with a '41 Merc for Pop a few years back. After sorting out all the other misc issues with the motor, I got it to run on 5 cylinders. A few minutes later - it was six. After ten minutes or so - the beastie was purrin' on all 8. Motor had been sittin' a good 15 years.
The smoke from the process - un-frickin'-believeable. Mom took a pic of Pop and I shortly after we got it lit; you can see us...just barely. I oughta scan it in.
If it's an OHV - you gotta cycle the valve by hand. Interference issues. I try to loosen it up with penetrating oil and tapping on the valve stem with a small ball peen hammer until the valve pops closed.
Old 09-22-2005, 04:38 PM   #6
286merc
Senior Member
If you get it running then slowly pour ATF down the carb while keeping the rpm up around 1000. Stand upwind. Use up to a full quart if necessary but let a little bit at a time blow itself out before adding more.
ATF both blows carbon off valves and stems as well as lubricate. I use it on everything from long stored muscle engines to lawn tractors. Did a 1962 Ford tractor last month that has sat in a field for 25 years; purrs like new now.
Old 09-22-2005, 04:48 PM   #7
sobastrace
Grenade Inspector
sobastrace's Avatar
I've never heard of using ATF. How slowly do you pour it. Just a string width stream or a bit more agressively?
-Spencer
Old 09-22-2005, 04:58 PM   #8
Paul
Editor
Paul's Avatar
do not do this it may fuck it up worse than it is,
(but it has worked for me more than once)
pull the rocker, or assembley, or head if it's a flatty
squirt your favorite penetrating oil on it,
getting the stem and guide good and wet
and smack it square on the valve
(head on the flat motor or end of stem on the overhead)
with a hammer,
don't beat it up, just shock it lose.
roll the motor over by hand untill the action looks good.
then crank it over with the starter till all the valves open and close like they're supposed to
Old 09-22-2005, 05:30 PM   #9
tommy
Old School HAMBer
tommy's Avatar
On a flatty, I used ATF in a spray bottle using the stream setting. You can give the stem a direct shot. Light pressue with a screwdriver and turn it over again. It took 3 or 4 attempts but it freed up after sleeping for 25 years.
For collapsed lifters on an old Pontiac, Rislone added to the oil. It took about 3 exits on the beltway before it cleared up. The Poncho only sat for 2 years.
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
Old 09-22-2005, 05:34 PM   #10
Squablow
Old School HAMBer
Squablow's Avatar
I'm thinkin' Bret's motor that he's asking about is the '54 Desoto 276 CI Hemi engine I sold him a few weeks ago. Not sure, though. I don't think he's got a flathead, but I could be wrong.
Old 09-22-2005, 07:56 PM   #11
HighSpeed LowDrag
HighSpeed LowDrag's Avatar
I have done just what 60's said. Its kind of a last resort before you have to tear it apart anyway. I've done it twice on different motors and not had a problem but there is some risk involved.
Old 09-22-2005, 08:47 PM   #12
Ayers Garage
Senior Member
Ayers Garage's Avatar
with a hammer,
60's, that was taught to me in Airframe and Powerplant school years ago. It's standard procedure on airplane engines with sticky valve. We didn't even remove the valve train sometimes.
Old 09-22-2005, 08:58 PM   #13
Mule Farmer
Alliance Member
Yep Squawblow right it a desoto hemi. I have been working on it some more tonite all I managed to do is screw it up more now I have the spring bottomed out. I have hosed it down with wd40. I guess I will give it few week and keep it wet with wd and see what happens. I was banging on it sort of lightly so hopefuly it will come free. If not I guess I will have to pull the head.
Thanks
bret
Old 09-22-2005, 09:08 PM   #14
Paul
Editor
Paul's Avatar
I told you not to
Old 09-22-2005, 09:19 PM   #15
Mule Farmer
Alliance Member
Your off the hook I didnt see your post untell after I screwed it up.
Bret
I told you not to
Old 09-22-2005, 10:22 PM   #16
Paul
Editor
Paul's Avatar
hahaha
prolly a good time to pull the heads anyway,
take a look around
might as well replace the timing chain and oil pump too
hmm?
Old 09-22-2005, 10:34 PM   #17
oldcarfart
Alliance Member
if OHV engine you can remover valve (rocker arm) cover, remove rocker arm, soak with kroil and tap with hammer using a piece of 2x4 between hammer and valve, go slow, be gentle
bret
__________________
Just an Old Car Fart living in Clinton, SC
1953 Chevy Pickup
Too many "projects" <grin>
Old 09-23-2005, 05:15 AM   #18
Mule Farmer
Alliance Member
what is kroil is it some typ of penetrating oil. would it work better than the wd40 i have been useing.
thanks bret
Old 09-23-2005, 08:34 AM   #19
Bruce Lancaster
Alliance Member
"No I meen that its stuck stuck not sticking once and a while. Your idea seams like a good idea for a running motor that the valve that sticks once and a while but mine is stuck from sitting for a long time like maybe there is some rust on the valve and its stuck in the guide."
That's what I was talking about--you gotta PUSH the thing shut (if it's moveable--sometimes engine just has to come apart), let the cam open it again, repeat, with lots of oil until valvespring can keep it down, then run with lots of MMO in tank and sump.
This isn't necessarily possible--if valve is truly rusted solid, go get the wrenches. On a hemi, I have no idea if you can find a way to push on valve head, but of course you can easily push in direction of more open, and with a little clever could figure out a way to pull up on it without too much violence. If it can be moved, it can be freed...
__________________
Bruce
Old 09-23-2005, 12:08 PM   #20
Big Pete
Grenade Inspector
Big Pete's Avatar
Run the engine, rev it up, squirt a water pistol down the carb....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
