Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
starting on 30 roadster project, gonna box frame, do suspension and steering and would like to have drive train all set in. my problem is budget and limited garage space dictates that I cant buy body untill Im ready to install it. any info in placement of my 52 flat v8 with 3 speed box will be appreciated. THANKS
#2 |
Grenade Inspector
here we go again. i would say if i had a frame and no body, and knew where the radiator sat, i would leave enough room for the fan to clear,maybe a couple inches, mount the engine, and worry about the firewall later
#3 | |
Alliance Member
Quote:
I was going to say look for the cowl mount holes and make the back of the engine even with the cowl mount holes than modify firewall to suite. But cayager's advioce is probably better then mine.
__________________
If it don't make ya dirty it ain't yours No man crosses a chasm in two jumps |
#4 |
Senior Member
The Tardel/Bishop book gives the dimensions for the mount locations. I don't have a copy but I'm sure at least half the guys on here do!
#5 |
Old School HAMBer
It is really not a great idea to build a frame and chassis without the body there to slip on and off occasionally to check fit and clearances. I know you said you have space and other limitations, but I can't imagine even beginning to build a car without the body sitting right there. No matter how you measure and check, something will come up and bite you, IMO.
Don |
#6 | |
Senior Member
Quote:
Bob |
#7 |
Agree - can't fit an engine between a firewall and a radiator without a firewall and a radiator.
#8 |
Senior Member
Find a cowl to mock up with. They are usually pretty inexspensive
#9 |
Old School HAMBer
Always best to have the body...but I'd say this is the best answer for your purposes...except for placement of the rear axle. But with some measurements from another Model A, you can do it. Welcome, and good luck.
__________________
Garage Sale Vintage Parts Priced To Sell! http://www.jalopyjournal.com/forum/s...d.php?t=801976 |
#10 |
Grenade Inspector
Ive ordered theTardel/Bishop book and am waiting for it to arrive and hopfully that will. help. I may try to get a rad and vega box and go from there. Thanks
#11 |
Alliance Member
If you follow the BT book measurement for measurement it will be wrong and your car will not fit together.
#12 |
Grenade Inspector
The T/D book is based on a '32 frame...keep that in mind. If you are using a Model A frame...the measurements won't work.
__________________
Buckle up! It makes it harder for the Aliens to suck you out of your car. |
#13 |
Alliance Member
Ummm....you might want to double check that.....looks like an A frame to me.....
#14 |
Alliance Member
No, the book is based on a Model A frame. They suggest a 32 as an acceptable alternative while still remaining an AV8.
__________________
Never argue with and idiot, people watching won't be able to tell the difference. Scott Sheehan Nightmares C.C. |
#15 | |
Senior Member
Quote:
Bob |
#16 |
Grenade Inspector
Ah....you're right. After looking again, I see they did use the A frame....in that case...never mind my last post. Brain farts.....
__________________
#17 |
Senior Member
I beg to differ! I've used the B/T layout along with the Wescott drawings that everybody bitches about to build at least two dozen "A" frames running flattys and they all fit up perfect. My old blue roadster was built to take a flatty but I ran it with the 283 bolted up to the B/T located '39 box using the same mounts, no problem.
#18 |
If you aren't going recess the firewall then wait until you get an old radiator and cowl for mockup. It is a tight fit without guessing where something should fit but doesn't. Save yourself work and frustration. But this is only my 2¢ ....
Vergil |
#19 | |
Old School HAMBer
Quote:
completely agree with this patience grasshopper..get the body than go from there
__________________
Goldchainers CC S.E. Michigan Chapter ![]() Charter Member Some guys could fuck up free lunch. |
#20 | ||
Alliance Member
Quote:
Quote:
__________________
An ol' dog and a Model A Coupe... What more could you want??? |
| Thread Tools | |
| Display Modes | |
